// 功能:1602显示PS2键盘第1类按键的键值,显示单个按键字母小写及数字和标点,不考虑组合键。
// 指示灯: 接收按键值 P30(run) 取反。 键盘上电P31亮,接收按键值,P31灭。
#include
sbit PS2CLK=P3^3; // PS2时钟
sbit PS2DATA=P3^4; // PS2数据
sbit RUN=P3^0; // 运行标志指示灯
sbit P31=P3^1; // 运行标志指示灯
#define lcd_bus P0 // 数据总线
sbit rs =P2^0; //数据&指令选择,H:写数据,L:写指令
sbit rw =P2^1; //读&写选择,H:read,L:write
sbit e =P2^2; //读写使能
sbit bf =P0^7; //忙闲状态标志位,H:内部正执行操作,L:空闲
void chk_busy(void);//检测LCD忙闲
void init_lcd(void);//LCD初始化
void wr_comm(unsigned char comm); //写指令
void wr_comm_no(unsigned char comm);//写指令,不检测忙闲
void wr_data(unsigned char dat); // 写数据
void wr_str(unsigned char *p); //显示字符串
unsigned char rd_lcd(void);//读LCD数据
void delayus(unsigned char us);//延时子程序 us
void delayms(unsigned int ms); //延时子程序 ms
unsigned char bitnum=0; // 中断接收键盘数据位的个数
unsigned char keyval=0; // 存放按键值
unsigned char keynum=0; // 存放中断接收键盘数据的个数
unsigned char key[3]={0,0,0}; // 存放按键的1B通码和2B断码
unsigned char lcdbuf[2]={'0',0}; //
unsigned char code unshifted[][2]= //shift键没按下译码表
0x0e,'`',
0x15,'q',
0x16,'1',
0x1a,'z',
0x1b,'s',
0x1c,'a',
0x1d,'w',
0x1e,'2',
0x21,'c',
0x22,'x',
0x23,'d',
0x24,'e',
0x25,'4',
0x26,'3',
0x29,' ',
0x2a,'v',
0x2b,'f',
0x2c,'t',
0x2d,'r',
0x2e,'5',
0x31,'n',
0x32,'b',
0x33,'h',
0x34,'g',
0x35,'y',
0x36,'6',
0x39,',',
0x3a,'m',
0x3b,'j',
0x3c,'u',
0x3d,'7',
0x3e,'8',
0x41,',',
0x42,'k',
0x43,'i',
0x44,'o',
0x45,'0',
0x46,'9',
0x49,'.',
0x4a,'/',
0x4b,'l',
0x4c,';',
0x4d,'p',
0x4e,'-',
0x52,'\'',
0x54,'[',
0x55,'=',
0x5b,']',
0x5d,'\\',
0x61,'
0x69,'1',
0x6b,'4',
0x6c,'7',
0x70,'0',
0x71,'.',
0x72,'2',
0x73,'5',
0x74,'6',
0x75,'8',
0x79,'+',
0x7a,'3',
0x7b,'-',
0x7c,'*',
0x7d,'9',
0,0
unsigned char code shifted[][2]= //shift键按下译码表
0x0e,'~',
0x15,'Q',
0x16,'!',
0x1a,'Z',
0x1b,'S',
0x1c,'A',
0x1d,'W',
0x1e,'@',
0x21,'C',
0x22,'X',
0x23,'D',
0x24,'E',
0x25,'$',
0x26,'#',
0x29,' ',
0x2a,'V',
0x2b,'F',
0x2c,'T',
0x2d,'R',
0x2e,'%',
0x31,'N',
0x32,'B',
0x33,'H',
0x34,'G',
0x35,'Y',
0x36,'^',
0x39,'L',
0x3a,'M',
0x3b,'J',
0x3c,'U',
0x3d,'&',
0x3e,'*',
0x41,'
0x42,'K',
0x43,'I',
0x44,'O',
0x45,')',
0x46,'(',
0x49,'>',
0x4a,'?',
0x4b,'L',
0x4c,':',
0x4d,'P',
0x4e,'_',
0x52,'"',
0x54,'{',
0x55,'+',
0x5b,'}',
0x5d,'|',
0x61,'>',
0x69,'1',
0x6b,'4',
0x6c,'7',
0x70,'0',
0x71,'.',
0x72,'2',
0x73,'5',
0x74,'6',
0x75,'8',
0x79,'+',
0x7a,'3',
0x7b,'-',
0x7c,'*',
0x7d,'9',
0,0
/*------------------LCD初始化-----------------*/
void init_lcd(void)
wr_comm_no(0x38); //不检测忙闲
delayms(5);
wr_comm_no(0x38);
delayms(5);
wr_comm_no(0x38);
delayms(5);
wr_comm_no(0x38);
delayms(5);
wr_comm(0x38); // 设定LCD为16*2显示,5*7点阵,8位数据接口,检测忙信号
delayus(3); // 延时11us
wr_comm(0x08); // 关闭显示,检测忙信号
delayus(3);
wr_comm(0x01); // 显示清屏,检测忙信号
delayus(3);
wr_comm(0x06); // 显示光标自动右移,整屏不移动,检测忙信号
delayus(3);
wr_comm(0x0c); //开显示,不显示光标,检测忙信号
delayus(3);
/*--------------检测LCD忙闲---------------*/
void chk_busy(void)
lcd_bus=0xff;
rs=0;
rw=1;
e=1;
while(bf==1);
e=0;
/*------------写命令到LCD--------------*/
chk_busy();
rs=0;//H:写数据,L:写指令
rw=0;
e=0;
lcd_bus=comm;//内容
delayus(3);
e=1;
e=0;
/*------------写命令到LCD不检测忙闲--------------*/
rs=0;//H:写数据,L:写指令
rw=0;
e=0;
lcd_bus=comm;//内容
delayus(3);
e=1;
e=0;
/*------------写数据到LCD--------------*/
chk_busy();
rs=1;//H:写数据,L:写指令
rw=0;
e=0;
lcd_bus=dat;//内容
delayus(3);
e=1;
e=0;
/*--------------读LCD数据---------------*/
unsigned char rd_data;
chk_busy();//检测忙闲
rs=1;
rw=1;
e=1;
rd_data=lcd_bus;
e=0;
return rd_data;
/*-------------写字符串----------------*/
void wr_str(unsigned char *s)
while(*s>0) //字符串以0结束
wr_data(*s);
s++;
/*---------------延时子程序us----------------*/
while(--us); // 一个循环2us
/*---------------延时子程序ms----------------*/
void delayms(unsigned int ms) //延时 n ms
while(ms)
int i;
i=110;
while(i--);
ms=ms-1;
void kbinter(void) interrupt 2
RUN=~RUN;
EX1=0; // 关外部中断1
if((bitnum>0)&&(bitnum<9)) // 保留接收数据的第1到第8位,即D0-D7,去掉起始位、校验位、停止位
keyval=keyval>>1; // 先接收到的是数据的D0位
if(PS2DATA==1)
keyval=keyval|0x80;
bitnum++; // 中断1次,位数加1
while(!PS2CLK); //等待PS2CLK拉高
if(bitnum>10) // 接收完1帧数据(11位)
bitnum=0;
key[keynum]=keyval; // 保存接收到的数据
keynum++;
if(keyval==0xaa) // 键盘上电,lcd显示A,P31亮。
P31=0; // P31亮
keynum=0;
lcdbuf[0]='A';
EX1=1; // 开外部中断1
void main()
unsigned char i;
delayms(20);
init_lcd(); //LCD初始化
wr_comm(0x80); //第一行第一个字符地址
wr_str("Tai shan Dian Zi");
EA=1; // 开总中断
EX1=1; // 开外部中断1
IT1=1; // 外部中断1下降沿触发
while(1)
if(keynum==3) // 接收3个字节数据,1B通码,2B断码
P31=1; // P31灭
keynum=0;
i=0;
while((key[0]!=unshifted[i][0])&&(unshifted[i][0]!=0)) // 查表,将按键值转换成字符,便于1602显示
i++;
lcdbuf[0]=unshifted[i][1];
wr_comm(0xc0); // 第二行第一个字符地址
wr_str(lcdbuf);
