操作对象为一24C02
#include "STM32Lib\\stm32f10x.h"
#include "hal.h"
//#define AT24C01A //24C01A,I2C时序和往后的24C02一样
#define AT24C01 //24C01,I2C的时序和普通的有点不同
#define EEPROM_ADDR 0xA0
#define I2C_PAGESIZE 4 //24C01/01A页缓冲是4个
void I2C_Configuration(void)
I2C_InitTypeDef I2C_InitStructure;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1,ENABLE);
/* PB6,7 SCL and SDA */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD;
GPIO_Init(GPIOB, &GPIO_InitStructure);
I2C_DeInit(I2C1);
I2C_InitStructure.I2C_Mode = I2C_Mode_I2C;
I2C_InitStructure.I2C_DutyCycle = I2C_DutyCycle_2;
I2C_InitStructure.I2C_OwnAddress1 = 0x30;
I2C_InitStructure.I2C_Ack = I2C_Ack_Enable;
I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
I2C_InitStructure.I2C_ClockSpeed = 100000;//100K速度
I2C_Cmd(I2C1, ENABLE);
I2C_Init(I2C1, &I2C_InitStructure);
/*允许1字节1应答模式*/
I2C_AcknowledgeConfig(I2C1, ENABLE);
**函数名:I2C_ReadS
**功能:读取24C02多个字节
**注意事项:24C02是256字节,8位地址,A0-A2固定为0,从器件地址为EEPROM_ADDR
void I2C_ReadS_24C(u8 addr ,u8* pBuffer,u16 no)
if(no==0)
return;
while(I2C_GetFlagStatus(I2C1, I2C_FLAG_BUSY));
/*允许1字节1应答模式*/
/* 发送起始位 */
I2C_GenerateSTART(I2C1, ENABLE);
while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_MODE_SELECT));/*EV5,主模式*/
#ifdef AT24C01A
/*发送器件地址(写)*/
I2C_Send7bitAddress(I2C1, EEPROM_ADDR, I2C_Direction_Transmitter);
while (!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
/*发送地址*/
I2C_SendData(I2C1, addr);
while (!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED));/*数据已发送*/
/*起始位*/
/*器件读*/
I2C_Send7bitAddress(I2C1, EEPROM_ADDR, I2C_Direction_Receiver);
while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED));
#else
/*发送器件地址(读)24C01*/
I2C_Send7bitAddress(I2C1, addr<<1, I2C_Direction_Receiver);
#endif
while (no)
if(no==1)
I2C_AcknowledgeConfig(I2C1, DISABLE); //最后一位后要关闭应答的
I2C_GenerateSTOP(I2C1, ENABLE); //发送停止位
while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_RECEIVED)); /* EV7 */
*pBuffer = I2C_ReceiveData(I2C1);
pBuffer++;
/* Decrement the read bytes counter */
no--;
//再次允许应答模式
**函数名:I2C_Standby_24C
**功能:24C是否准备好再写入的判断
**注意事项:本函数可以理解为:判忙
就是不停发地址 直到器件有应答
void I2C_Standby_24C(void)
vu16 SR1_Tmp;
do
/*起始位*/
/*读SR1*/
SR1_Tmp = I2C_ReadRegister(I2C1, I2C_Register_SR1);
/*器件地址(写)*/
#ifdef AT24C01A
#else
I2C_Send7bitAddress(I2C1, 0, I2C_Direction_Transmitter);
#endif
}while(!(I2C_ReadRegister(I2C1, I2C_Register_SR1) & 0x0002));
/*清除应答错误标志*/
I2C_ClearFlag(I2C1, I2C_FLAG_AF);
/*停止位*/
**函数名:I2C_ByteWrite_24C
**功能:写一个字节
**注意事项:字写入同样需要调用忙判断
void I2C_ByteWrite_24C(u8 addr,u8 dat)
/* 起始位 */
#ifdef AT24C01A
/* 发送器件地址(写)*/
while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
/*发送地址*/
while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED));
#else
I2C_Send7bitAddress(I2C1, addr<<1, I2C_Direction_Transmitter);
#endif
/* 写一个字节*/
I2C_SendData(I2C1, dat);
/* 停止位*/
I2C_Standby_24C();
**函数名:I2C_PageWrite_24C
**功能:写入一页(以内)
**注意事项:此函数供群写入调用
void I2C_PageWrite_24C(u8 addr,u8* pBuffer, u8 no)
/*起始位*/
#ifdef AT24C01A
/*器件地址(写)*/
/*写地址值*/
while(! I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED));
#else
#endif
while(no--)
I2C_SendData(I2C1, *pBuffer);
pBuffer++;
/*停止位*/
**函数名:I2C_WriteS_24C
**功能:页写入24C
**注意事项:24C02最多允许一次写入8个字节
void I2C_WriteS_24C(u8 addr,u8* pBuffer, u16 no)
u8 temp;
//1.先把页不对齐的部分写入
temp=addr % I2C_PAGESIZE;
if(temp)
temp=I2C_PAGESIZE-temp;
I2C_PageWrite_24C(addr,pBuffer, temp);
no-=temp;
addr+=temp;
pBuffer+=temp;
I2C_Standby_24C();
//2.从页对齐开始写
while(no)
if(no>=I2C_PAGESIZE)
I2C_PageWrite_24C(addr,pBuffer, I2C_PAGESIZE);
no-=I2C_PAGESIZE;
addr+=I2C_PAGESIZE;
pBuffer+=I2C_PAGESIZE;
I2C_Standby_24C();
else
I2C_PageWrite_24C(addr,pBuffer, no);
no=0;
I2C_Standby_24C();
//测试用
void I2C_Test(void)
u8 i;
u8 I2c_Buf[128];
I2C_Standby_24C();
//填充缓冲
for(i=0;i<128;i++)
I2c_Buf[i]=i;
//写
I2C_WriteS_24C(1,I2c_Buf,120);
//清缓冲
for(i=0;i<128;i++)
I2c_Buf[i]=0;
//读
I2C_ReadS_24C(1,I2c_Buf,80);
for(i=1;i<120;i++)
if(I2c_Buf[i]!=i)
while(1);
就看这里 确定是否正常~!
其实 都是 while 这种 硬等待 导致屡次调不通 务必加入 超时判断。
简单的像
i=0;
while((!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED))&&i<12000);i++
关键字:STM32 I2C 硬使用『本文转载自网络,版权归原作者所有,如有侵权请联系删除』
