#include "STM32Lib\\stm32f10x.h" void Tim1_Configuration(void) { TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; TIM_OCInitTypeDef TIM_OCInitStructure; GPIO_InitTypeDef GPIO_InitStructure; /* PA8设置为功能脚(PWM) */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOA, &GPIO_InitStructure); RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1,ENABLE);
TIM_DeInit(TIM1); /*TIM1时钟配置*/ TIM_TimeBaseStructure.TIM_Prescaler = 72; //预分频(时钟分频)72M/72=1000K TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //向上计数 TIM_TimeBaseStructure.TIM_Period = 2000; //装载值 1000k/2000=500hz TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; TIM_TimeBaseStructure.TIM_RepetitionCounter = 0x0; TIM_TimeBaseInit(TIM1,&TIM_TimeBaseStructure); /* Channel 1 Configuration in PWM mode */ TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2; //PWM模式2 TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; //正向通道有效 TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Disable;//反向通道无效 TIM_OCInitStructure.TIM_Pulse = 300; //占空时间 TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low; //输出极性 TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High; //互补端的极性 TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set; TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset; TIM_OC1Init(TIM1,&TIM_OCInitStructure); //通道1 /* TIM1 counter enable */ TIM_Cmd(TIM1,ENABLE); /* TIM1 Main Output Enable */ TIM_CtrlPWMOutputs(TIM1,ENABLE); } //设置捕获寄存器1 void SetT1Pwm1(u16 pulse) { TIM1->CCR1=pulse; } |
