sixth_drv.c驱动源码:
#include "linux/device.h"
#include "linux/interrupt.h"
#include "linux/module.h"
#include "linux/kernel.h"
#include "linux/fs.h"
#include "linux/init.h"
#include "linux/delay.h"
#include "linux/irq.h"
#include "asm/uaccess.h"
#include "asm/irq.h"
#include "asm/io.h"
#include "mach/gpio.h"
#include "linux/poll.h"
static struct class *sixthdrv_class;
volatile unsigned long *gph2con;
volatile unsigned long *gph2dat;
volatile unsigned long *gph3con;
volatile unsigned long *gph3dat;
static DECLARE_WAIT_QUEUE_HEAD(button_waitq);
// 中断事件标志, 中断服务程序将它置1,sixth_drv_read将它清0
static volatile int ev_press = 0;
static struct fasync_struct *button_async;
struct pin_desc{
unsigned int pin;
unsigned int key_val;
// 键值: 按下时, 0x01, 0x02, 0x03, 0x04
// 键值: 松开时, 0x81, 0x82, 0x83, 0x84
static unsigned char key_val;
// 键值: 按下时, 0x01, 0x02, 0x03, 0x04, 0x05
// 键值: 松开时, 0x81, 0x82, 0x83, 0x84, 0x85
struct pin_desc pins_desc[5] = {
{S5PV210_GPH2(3), 0x01},
{S5PV210_GPH3(0), 0x02},
{S5PV210_GPH3(1), 0x03},
{S5PV210_GPH3(2), 0x04},
{S5PV210_GPH3(3), 0x05},
//static atomic_t canopen = ATOMIC_INIT(1); //定义原子变量并初始化为1
static DECLARE_MUTEX(button_lock); //定义互斥锁
// 确定按键值
static irqreturn_t buttons_irq(int irq, void *dev_id)
struct pin_desc * pindesc = (struct pin_desc *)dev_id;
unsigned int pinval;
pinval = gpio_get_value(pindesc->pin);
if (pinval)
// 松开
key_val = 0x80 | pindesc->key_val;
else
// 按下
key_val = pindesc->key_val;
ev_press = 1; // 表示中断发生了
wake_up_interruptible(&button_waitq); // 唤醒休眠的进程
kill_fasync (&button_async, SIGIO, POLL_IN);
return IRQ_RETVAL(IRQ_HANDLED);
static int sixth_drv_open(struct inode *inode, struct file *file)
#if 0
if (!atomic_dec_and_test(&canopen))
atomic_inc(&canopen);
return -EBUSY;
#endif
if (file->f_flags & O_NONBLOCK)
if (down_trylock(&button_lock))
return -EBUSY;
else
// 获取信号量
down(&button_lock);
// 注册中断
request_irq(IRQ_EINT(19), buttons_irq, IRQF_TRIGGER_FALLING|IRQF_TRIGGER_RISING,
"K4", &pins_desc[0]);
request_irq(IRQ_EINT(24), buttons_irq, IRQF_TRIGGER_FALLING|IRQF_TRIGGER_RISING,
"K5", &pins_desc[1]);
request_irq(IRQ_EINT(25), buttons_irq, IRQF_TRIGGER_FALLING|IRQF_TRIGGER_RISING,
"K6", &pins_desc[2]);
request_irq(IRQ_EINT(26), buttons_irq, IRQF_TRIGGER_FALLING|IRQF_TRIGGER_RISING,
"K7", &pins_desc[3]);
request_irq(IRQ_EINT(27), buttons_irq, IRQF_TRIGGER_FALLING|IRQF_TRIGGER_RISING,
"K8", &pins_desc[4]);
return 0;
ssize_t sixth_drv_read(struct file *file, char __user *buf, size_t size, loff_t *ppos)
if (size != 1)
return -EINVAL;
if (!ev_press)
return -EAGAIN;
else
// 如果没有按键动作, 休眠
wait_event_interruptible(button_waitq, ev_press);
// 如果有按键动作, 返回键值
copy_to_user(buf, &key_val, 1);
ev_press = 0;
return 1;
int sixth_drv_close(struct inode *inode, struct file *file)
//atomic_inc(&canopen);
free_irq(IRQ_EINT(19), &pins_desc[0]);
free_irq(IRQ_EINT(24), &pins_desc[1]);
free_irq(IRQ_EINT(25), &pins_desc[2]);
free_irq(IRQ_EINT(26), &pins_desc[3]);
free_irq(IRQ_EINT(27), &pins_desc[4]);
up(&button_lock);
return 0;
static unsigned sixth_drv_poll(struct file *file, poll_table *wait)
unsigned int mask = 0;
poll_wait(file, &button_waitq, wait); // 不会立即休眠
if (ev_press)
mask |= POLLIN | POLLRDNORM;
return mask;
static int sixth_drv_fasync (int fd, struct file *filp, int on)
printk("driver: sixth_drv_fasync\n");
return fasync_helper (fd, filp, on, &button_async);
static struct file_operations sencod_drv_fops = {
.owner = THIS_MODULE, // 这是一个宏,推向编译模块时自动创建的__this_module变量
.open = sixth_drv_open,
.read = sixth_drv_read,
.release = sixth_drv_close,
.poll = sixth_drv_poll,
.fasync = sixth_drv_fasync,
int major;
static int sixth_drv_init(void)
major = register_chrdev(0, "sixth_drv", &sencod_drv_fops);
sixthdrv_class = class_create(THIS_MODULE, "sixth_drv");
device_create(sixthdrv_class, NULL, MKDEV(major, 0), NULL, "buttons"); // /dev/buttons
gph2con = (volatile unsigned long *)ioremap(0xe0200c40, 16);
gph2dat = gph2con + 1;
gph3con = (volatile unsigned long *)ioremap(0xE0200C60, 16);
gph3dat = gph3con + 1;
return 0;
static void sixth_drv_exit(void)
unregister_chrdev(major, "sixth_drv");
device_destroy(sixthdrv_class, MKDEV(major, 0));
class_destroy(sixthdrv_class);
iounmap(gph2con);
iounmap(gph3con);
return 0;
module_init(sixth_drv_init);
module_exit(sixth_drv_exit);
MODULE_LICENSE("GPL");
sixthdrvtest.c测试程序:
#include "sys/types.h"
#include "sys/stat.h"
#include "fcntl.h"
#include "stdio.h"
#include "poll.h"
#include "signal.h"
#include "unistd.h"
#include "fcntl.h"
// sixthdrvtest
int fd;
void my_signal_fun(int signum)
read(fd, &key_val, 1);
printf("key_val: 0x%x\n", key_val);
int main(int argc, char **argv)
int ret;
int Oflags;
//signal(SIGIO, my_signal_fun);
fd = open("/dev/buttons", O_RDWR | O_NONBLOCK);
if (fd < 0)
printf("can't open!\n");
return -1;
//fcntl(fd, F_SETOWN, getpid());
//Oflags = fcntl(fd, F_GETFL);
//fcntl(fd, F_SETFL, Oflags | FASYNC);
while (1)
ret = read(fd, &key_val, 1);
printf("key_val: 0x%x, ret = %d\n", key_val, ret);
sleep(5);
return 0;
