仿真原理图如下
原理图
单片机源程序如下:
#include
#include
#include
#include "main.h"
#include "LCD1602.h"
#include "HX711.h"
#include "eeprom52.h"
#define uchar unsigned char
#define uint unsigned int
unsigned long HX711_Buffer = 0;
unsigned long Weight_Maopi = 0;
unsigned long Weight_Maopi_0 = 0;
long Weight_Shiwu = 0;
unsigned int qupi=0;
//键盘处理变量
unsigned char keycode;
unsigned char key_press_num=0;
uint GapValue,GapValue1;
//定义标识
volatile bit FlagTest = 0; //定时测试标志,每0.5秒置位,测完清0
volatile bit FlagKeyPress = 0; //有键按下标志,处理完毕清0
//校准参数
//因为不同的传感器特性曲线不是很一致,因此,每一个传感器需要矫正这里这个参数才能使测量值很准确。
//当发现测试出来的重量偏大时,增加该数值。
//如果测试出来的重量偏小时,减小改数值。
//该值可以为小数
//#define GapValue 349
sbit LED=P1^1;
sbit ROW1=P3^0;
sbit ROW2=P3^1;
sbit ROW3=P3^2;
sbit ROW4=P3^3;
volatile bit ClearWeighFlag = 0; //传感器调零标志位,清除0漂
/******************把数据保存到单片机内部eeprom中******************/
void write_eeprom()
SectorErase(0x2000);
GapValue1=GapValue&0x00ff;
byte_write(0x2000, GapValue1);
GapValue1=(GapValue&0xff00)>>8;
byte_write(0x2001, GapValue1);
byte_write(0x2060, a_a);
/******************把数据从单片机内部eeprom中读出来*****************/
void read_eeprom()
GapValue = byte_read(0x2001);
GapValue = (GapValue<<8)|byte_read(0x2000);
a_a = byte_read(0x2060);
/**************开机自检eeprom初始化*****************/
void init_eeprom()
read_eeprom(); //先读
if(a_a != 1) //新的单片机初始单片机内问eeprom
GapValue = 3500;
a_a = 1;
write_eeprom(); //保存数据
//显示重量,单位kg,两位整数,三位小数
void Display_Weight()
LCD1602_write_com(0x80+0x40+8);
if(Weight_Shiwu/10000==0)
LCD1602_write_data(' ');
else
LCD1602_write_data(Weight_Shiwu/10000 + 0x30);
LCD1602_write_data(Weight_Shiwu%10000/1000 + 0x30);
LCD1602_write_data('.');
LCD1602_write_data(Weight_Shiwu%1000/100 + 0x30);
LCD1602_write_data(Weight_Shiwu%100/10 + 0x30);
LCD1602_write_data(Weight_Shiwu%10 + 0x30);
//定时器0初始化
void Timer0_Init()
ET0 = 1; //允许定时器0中断
TMOD = 1; //定时器工作方式选择
TL0 = 0xb0;
TH0 = 0x3c; //定时器赋予初值
TR0 = 1; //启动定时器
//定时器0中断
void Timer0_ISR (void) interrupt 1 using 0
uchar Counter;
TL0 = 0xb0;
//每0.5秒钟刷新重量
Counter ++;
if (Counter >= 10)
FlagTest = 1;
Counter = 0;
//按键响应程序,参数是键值
//返回键值:
// 7 8 9 10(清0)
// 4 5 6 11(删除)
// 1 2 3 12(未定义)
// 14(未定义) 0 15(.) 13(确定价格)
void KeyPress()
if(ROW1==0) //去皮键
Delay_ms(5);
if(ROW1==0)
// Get_Maopi();
if(qupi==0)
qupi=Weight_Shiwu;
else
qupi=0;
Buzzer=0;
Delay_ms(50);
Buzzer=1;
while(ROW1==0);
if(ROW2==0) //加
Delay_ms(5);
if(ROW2==0)
while(!ROW2)
key_press_num++;
if(key_press_num>=100)
key_press_num=0;
while(!ROW2)
if(GapValue<10000)
GapValue+=10;
Buzzer=0;
Delay_ms(10);
Buzzer=1;
Delay_ms(10);
Get_Weight();
Delay_ms(10);
if(key_press_num!=0)
key_press_num=0;
if(GapValue<10000)
GapValue++;
Buzzer=0;
Delay_ms(50);
