DHT11温度湿度采集原理图:
DHT11的单片机源程序:
#include
#define uint unsigned int
#define uchar unsigned char
#include
typedef bit BOOL ;
sbit io = P1^1 ;//(口线定义)
sbit bee=P1^0;
sbit rs = P2^5 ;
sbit rw = P2^6 ;
sbit ep = P2^7 ;
bit flag_300ms ;
sbit K1=P1^2;
sbit K2=P1^3;
sbit K3=P1^4;
uchar yemian=0;//(定义变量)
uchar flat=1;
uchar data_byte;
uchar RH,RL,TH,TL;
uchar WenDu,ShiDu;//报警的温度和湿度
#include "eeprom52.h"
/****************************延时程序****************************/
void delay(uchar ms)
{ // 延时子程序
uchar i ;
while(ms--)
for(i = 0 ; i<250;i++) ;
void delay1()//延时10us
uchar i;
i--;
i--;
i--;
i--;
i--;
i--;
void longdelay(uchar s) //长延时
while(s--)
delay(20) ;
/******************把数据保存到单片机内部eeprom中******************/
void write_eeprom()
SectorErase(0x2000);
byte_write(0x2000, WenDu);
byte_write(0x2001, ShiDu);
byte_write(0x2060, a_a);
/******************把数据从单片机内部eeprom中读出来*****************/
void read_eeprom()
WenDu = byte_read(0x2000);
ShiDu = byte_read(0x2001);
a_a = byte_read(0x2060);
/**************开机自检eeprom初始化*****************/
void init_eeprom()
read_eeprom(); //先读
if(a_a != 2) //新的单片机初始单片机内问eeprom
WenDu = 30;
ShiDu = 80;
a_a = 2;
write_eeprom();
/********************报警程序部分*******************/
void warn() //报警函数
if(TH>=WenDu) //检测的温度高于设定温度报警值
bee=0; //报警
if(RH>=ShiDu) //检测的湿度高于设定的湿度值
bee=0; //报警
if( TH
bee=1; //停止报警
/************************LCD模块******************************************/
BOOL lcd_bz()//测试LCD忙碌状态
BOOL result ;
rs = 0 ;
rw = 1 ;
ep = 1 ;
result = (BOOL)(P0 & 0x80) ;
ep = 0 ;
return result ;
void write_cmd(uchar cmd)// 写指令
while(lcd_bz()) ;
rs = 0 ;
rw = 0 ;
ep = 0 ;
P0 = cmd ;
ep = 1 ;
ep = 0 ;
void write_addr(uchar addr)//写地址
write_cmd(addr|0x80) ;
void write_byte(uchar dat)//写字节
while(lcd_bz()) ;
rs = 1 ;
rw = 0 ;
ep = 0 ;
P0 = dat ;
ep = 1 ;
ep = 0 ;
void lcd_init()// 初始化
write_cmd(0x38) ;
delay(1);
write_cmd(0x08) ;
delay(1);
write_cmd(0x01) ;
delay(1);
write_cmd(0x06) ;
delay(1);
write_cmd(0x0c) ;
delay(1);
void display(uchar addr, uchar q)//在某一地址上显示一字节
delay(1) ;
write_addr(addr) ;
write_byte(q) ;
delay(1) ;
/*********************** DHT11测试模块***************************************/
void start()//开始信号
io=1;
delay1();
io=0;
delay(20);//>18ms
io=1;
delay1();//20-40us
delay1();
delay1();
delay1();
delay1();
uchar receive_byte()//接收一个字节
uchar i,temp,count;
for(i=0;i<8;i++)
temp=0;
delay1();delay1();delay1();delay1();
if(io==1)temp=1;
count=2;
while((io)&&count++);
if(count==1)break;
data_byte<<=1;
data_byte|=temp;
return data_byte;
void receive()//接收数据
uchar T_H,T_L,R_H,R_L,check,num_check;
uchar count;
start();//开始信号
io=1;
if(!io)//读取DHT11响应信号
R_H=receive_byte();
R_L=receive_byte();
T_H=receive_byte();
T_L=receive_byte();
check=receive_byte();
io=0;//拉低延时50us
delay1();delay1();delay1();delay1();delay1();
io=1;
num_check=R_H+R_L+T_H+T_L;
if(num_check=check)
RH=R_H;
RL=R_L;
TH=T_H;
TL=T_L;
check=num_check;
void showw() // 问候语函数
lcd_init(); //初始化
delay(10);
display(0x05,'W');
display(0x06,'e');
display(0x07,'l');
display(0x08,'c');
display(0x09,'o');
display(0x0a,'m');
display(0x0b,'e');
delay(250); //短暂延时
delay(250);
delay(250);
display(0x40,' ') ;
display(0x41,
