单片机 > 单片机程序设计 > 详情
用GCC写的AT24C64接口程序
发布时间:2024-10-22 发布时间:
// AT24C64 support functions using ATMEGA's TWI
// PIN-WP is hard-wired to GND
// fuctions work better outside interrupt routines
// by MXH, 2003/07/30
#include "DStruct.h"
#include
// CONSTANTS DEFINITION FOR EEPROM
#define EEADDR        0
#define EEWR        0
#define EERD        1
// TWINT *NOT* set after STOP condition is sent
// check status?
// TWSTO is cleared by hardware
#define TwiStop()    TWCR = _BV(TWINT) | _BV(TWEN) | _BV(TWSTO)
#define TwiStart()    TWCR = _BV(TWINT) | _BV(TWEN) | _BV(TWSTA)
#define TWI_STATUS    (TWSR & 0xF8)
BYTE byEEWait;
// implementation
BOOL EEPStart(BYTE addr, BOOL bWrite)
    byEEWait = 10;    // 90~100ms
poll_ack:
    TwiStart();
    while (!(TWCR & (1<        if ( byEEWait == 0 ){
            return FALSE;
    if ((TWI_STATUS != TW_START)&&(TWI_STATUS != TW_REP_START))
        goto poll_ack;
    //byEEWait = 3;    // 20~30ms
    // send SLA+R/W
    TWDR = addr | bWrite;
    TWCR = (1<    while (!(TWCR & (1<        if( byEEWait == 0 ){
            TwiStop();
            return FALSE;
    if( EEWR == bWrite ){    // MT mode
        //if(TWI_STATUS != TW_MT_SLA_ACK)
        switch(TWI_STATUS){
            case TW_MT_SLA_ACK:
                break;
            case TW_MT_SLA_NACK:
                goto poll_ack;
            default:
                TwiStop();
                return FALSE;
    }else{                    // MR mode
        if(TWI_STATUS != TW_MR_SLA_ACK)
            return FALSE;
    return TRUE;
BYTE EEPWrite( WORD uiAddress, WORD uiLen, void *pBuf ) //using 0
    unsigned int i,j,uICnt;
    if( uiLen == 0 ) return 0;
    uiCnt = 0;
//    uiEnd = uiAddress + uiLen;
    i = uiAddress;
    do{
        if(!EEPStart(0xA0|EEADDR,EEWR)){    //PollAck() is built-in
            return 0;
        TWDR = (BYTE)((i>>8)&0x00ff);        // MSB of address
        TWCR = (1<        byEEWait = 3;    // 20~30ms
                return FALSE;
        if(TWI_STATUS != TW_MT_DATA_ACK){
            return FALSE;
        TWDR = (BYTE)(i&0x00ff);            // LSB of address
                return FALSE;
            return FALSE;
        // write data
        for( j=0; j<32; j++ ){
            TWDR = ((BYTE*)pBuf)[uiCnt];
                    return FALSE;
                return FALSE;
            i++;
            uiCnt++;
            if(( 0 == i%32 )||( uiCnt == uiLen )){
                TwiStop();
                break;
    }while( uiCnt //    while( !PollAck());
    return 1;
BYTE EEPRead( WORD uiAddress, WORD uiLen, void *pBuf )
    UINT i;
    if ( uiLen == 0 ) return 0;
        return 0;             //↑
    }    // not RD but write device address to the Chip
    TWDR = (BYTE)(( uiAddress >> 8) & 0x00ff );    //((BYTE*)(&uiAddress))[1];    // MSB of address
            return FALSE;
    if (TWI_STATUS != TW_MT_DATA_ACK)
        return FALSE;
    TWDR = (BYTE)( uiAddress & 0x00ff );    //((BYTE*)(&uiAddress))[0];        // LSB of address
            return FALSE;
        return FALSE;
    if(!EEPStart(0xA0+EEADDR,EERD)){    //PollAck()){
        return 0;             //↑
    }// ??? how to read?
    for ( i=0; i        TWCR = _BV(TWINT)|_BV(TWEN)|_BV(TWEA);
                return FALSE;
        if (TWI_STATUS != TW_MR_DATA_ACK)
            return FALSE;
        ((BYTE*)pBuf)[i] = TWDR;    // EEInByte();
    TWCR = _BV(TWINT) | _BV(TWEN);    // send NACK to inDICate final byte
            return FALSE;
    //if (TWI_STATUS != TW_MR_DATA_ACK)
    //    return FALSE;
    TwiStop();
    return 1;
关键字:GCC  AT24C64  接口程序
