#include
#include "./delay/delay.h"
sbit SCL = P2^0;
sbit SDA = P2^1;
bit ack = 0;
unsigned char flag = 1;
#define LCDPORT P0
#define LCD_WRITE_DATA 1
#define LCD_WRITE_COM 0
sbit RS = P2^4;
sbit RW = P2^5;
sbit E = P2^6;
#define SUCC 0
#define ERR 1
void iic_start()
SDA = 1; //先操作SDA,在操作SCL
SCL = 1;
delay_us(1);
SDA = 0;
delay_us(1);
SCL = 0; //钳住总线
void iic_stop()
SDA = 0;
SCL = 1;
delay_us(1);
SDA = 1;
delay_us(1);
SCL = 0; //钳住总线
bit iic_send_byte(unsigned char byte) //发送数据,先发送高位,再发送低位 只发送一个字节
unsigned char i;
for(i = 0; i < 8; i++)
SDA = byte & 0x80; //与上为非0时,SDA = 1; 与上为0时,SDA = 0;
SCL = 1;
delay_us(1); //延时1us
SCL = 0;
byte <<= 1;
SCL = 1;
SDA = 1;
delay_us(2);
if(0 == SDA)
ack = 1;
else
ack = 0;
SCL = 0;
return ack;
unsigned char iic_rcv_byte() //接收数据
unsigned char i;
unsigned char temp = 0;
unsigned char a;
SDA = 1;
SCL = 0;
delay_us(1);
SCL = 1;
if(SDA)
a = 0x01;
else
a = 0;
temp |= (a << (7 - i));
delay_us(1);
SCL = 0;
return temp;
void iic_ack() //响应信号
SDA = 0; //拉低数据总线
SCL = 1; //时钟总线拉高
delay_us(1);
SCL = 0; //钳住总线
void iic_noack() //非响应信号
SDA = 1; //释放数据总线
SCL = 1; //拉高时钟总线
delay_us(1);
SCL = 0; //钳住总线
unsigned char AT24c02_send_byte(unsigned char devaddr, unsigned char romaddr, unsigned char *s, unsigned char num) //发送字符串
unsigned char i;
iic_start(); //起始信号
iic_send_byte(devaddr); //写硬件地址
if(0 == ack) //等待响应
return ERR;
iic_send_byte(romaddr); //写物理地址
if(0 == ack) //等待响应
return ERR;
for(i = 0; i < num; i++) //发送num个字符
iic_send_byte(*s); //逐个字节发送
if(0 == ack)
return ERR;
s++;
iic_stop();
return SUCC;
unsigned char AT24c02_rcv_byte(unsigned char devaddr, unsigned char romaddr, unsigned char *s, unsigned char num)
unsigned char i;
iic_start();
delay_us(10);
if(0 == ack) //等待响应
return ERR;
if(0 == ack) //等待响应
return ERR;
iic_start();
iic_send_byte(devaddr + 1);
if(0 == ack) //等待响应
return ERR;
for(i = 0; i < num -1; i++) //开始读数据
*s = iic_rcv_byte();
iic_ack();
s++;
iic_noack();
delay_us(10);
iic_stop();
return SUCC;
void lcd1602_write(unsigned char byte, unsigned char flag)
if(flag)
RS = 1;
else
RS = 0;
RW = 0;
E = 1;
LCDPORT = byte;
delay_ms(5);
E = 0;
void lcd_init()
delay_ms(15);
lcd1602_write(0x38,LCD_WRITE_COM);
delay_ms(5);
delay_ms(5);
delay_ms(5);
delay_ms(5);
lcd1602_write(0x08,LCD_WRITE_COM);
delay_ms(5);
lcd1602_write(0x01,LCD_WRITE_COM);
delay_ms(5);
lcd1602_write(0x06,LCD_WRITE_COM);
delay_ms(5);
lcd1602_write(0x0c,LCD_WRITE_COM);
delay_ms(5);
void lcd_dis_char(unsigned char x, unsigned char y, unsigned char *str)
if((x > 15) || (y > 1))
return ;
if(0 == y)
lcd1602_write(0x80 + x, LCD_WRITE_COM);
else
lcd1602_write(x + 0xc0,LCD_WRITE_COM);
while(*str != '')
lcd1602_write(*str , LCD_WRITE_DATA);
str++;
void main()
//unsigned char i;
unsigned char test[10] = {'0','1','2','3','4','5','6','7','8','9'};
unsigned char temp[11];
lcd_init();
AT24c02_send_byte(0xae,100,test,10);
delay_s(1);
AT24c02_rcv_byte(0xae,100,temp,10);
temp[10] = '';
lcd_dis_char(0,0,temp);
lcd_dis_char(0,1,temp);
while(1)
