1、增加nand_flash.c 文件:cpu/arm920t/s3c24x0/nand_flash.c
#include
#if (CONFIG_COMMANDS & CFG_CMD_NAND) && !defined(CFG_NAND_LEGACY)
#include
#include
DECLARE_GLOBAL_DATA_PTR;
#define S3C2410_NFSTAT_READY (1<<0)
#define S3C2410_NFCONF_nFCE (1<<11)
#define S3C2440_NFSTAT_READY (1<<0)
#define S3C2440_NFCONT_nFCE (1<<1)
static void s3c2410_nand_select_chip(struct mtd_info *mtd, int chip)
S3C2410_NAND * const s3c2410nand = S3C2410_GetBase_NAND();
if (chip == -1) {
s3c2410nand->NFCONF |= S3C2410_NFCONF_nFCE;
} else {
s3c2410nand->NFCONF &= ~S3C2410_NFCONF_nFCE;
static void s3c2410_nand_hwcontrol(struct mtd_info *mtd, int cmd)
struct nand_chip *chip = mtd->priv;
switch (cmd) {
case NAND_CTL_SETNCE:
case NAND_CTL_CLRNCE:
printf("%s: called for NCE/n", __FUNCTION__);
break;
case NAND_CTL_SETCLE:
chip->IO_ADDR_W = (void *)&s3c2410nand->NFCMD;
break;
case NAND_CTL_SETALE:
chip->IO_ADDR_W = (void *)&s3c2410nand->NFADDR;
break;
default:
chip->IO_ADDR_W = (void *)&s3c2410nand->NFDATA;
break;
static int s3c2410_nand_devready(struct mtd_info *mtd)
return (s3c2410nand->NFSTAT & S3C2410_NFSTAT_READY);
static void s3c2440_nand_select_chip(struct mtd_info *mtd, int chip)
S3C2440_NAND * const s3c2440nand = S3C2440_GetBase_NAND();
if (chip == -1) {
s3c2440nand->NFCONT |= S3C2440_NFCONT_nFCE;
} else {
s3c2440nand->NFCONT &= ~S3C2440_NFCONT_nFCE;
static void s3c2440_nand_hwcontrol(struct mtd_info *mtd, int cmd)
switch (cmd) {
break;
chip->IO_ADDR_W = (void *)&s3c2440nand->NFCMD;
break;
chip->IO_ADDR_W = (void *)&s3c2440nand->NFADDR;
break;
default:
chip->IO_ADDR_W = (void *)&s3c2440nand->NFDATA;
break;
static int s3c2440_nand_devready(struct mtd_info *mtd)
return (s3c2440nand->NFSTAT & S3C2440_NFSTAT_READY);
static void s3c24x0_nand_inithw(void)
#define TACLS 0
#define TWRPH0 4
#define TWRPH1 2
if (gd->bd->bi_arch_number == MACH_TYPE_SMDK2410)
s3c2410nand->NFCONF = (1<<15)|(1<<12)|(1<<11)|(TACLS<<8)|(TWRPH0<<4)|(TWRPH1<<0);
else
s3c2440nand->NFCONF = (TACLS<<12)|(TWRPH0<<8)|(TWRPH1<<4);
s3c2440nand->NFCONT = (1<<4)|(0<<1)|(1<<0);
void board_nand_init(struct nand_chip *chip)
s3c24x0_nand_inithw();
if (gd->bd->bi_arch_number == MACH_TYPE_SMDK2410) {
chip->IO_ADDR_R = (void *)&s3c2410nand->NFDATA;
chip->hwcontrol = s3c2410_nand_hwcontrol;
chip->dev_ready = s3c2410_nand_devready;
chip->select_chip = s3c2410_nand_select_chip;
chip->options = 0;
} else {
chip->IO_ADDR_R = (void *)&s3c2440nand->NFDATA;
chip->hwcontrol = s3c2440_nand_hwcontrol;
chip->dev_ready = s3c2440_nand_devready;
chip->select_chip = s3c2440_nand_select_chip;
chip->options = 0;
chip->eccmode = NAND_ECC_SOFT;
#endif
2、同时修改该目录下的 Makefile:29 行
COBJS = i2c.o interrupts.o serial.o speed.o \
usb_ohci.o nand_flash.o
3、在 include/s3c24x0.h 中定义 S3C2440_NAND 结构体:168 行
typedef struct {
S3C24X0_REG32 NFCONF;
S3C24X0_REG32 NFCONT;
S3C24X0_REG32 NFCMD;
S3C24X0_REG32 NFADDR;
S3C24X0_REG32 NFDATA;
S3C24X0_REG32 NFMECCD0;
S3C24X0_REG32 NFMECCD1;
S3C24X0_REG32 NFSECCD;
S3C24X0_REG32 NFSTAT;
S3C24X0_REG32 NFESTAT0;
S3C24X0_REG32 NFESTAT1;
S3C24X0_REG32 NFMECC0;
S3C24X0_REG32 NFMECC1;
S3C24X0_REG32 NFSECC;
S3C24X0_REG32 NFSBLK;
S3C24X0_REG32 NFEBLK;
} S3C2440_NAND;
4、同时在 include/s3c2410.h 中添加:100 行
static inline S3C2440_NAND * const S3C2440_GetBase_NAND(void)
return (S3C2440_NAND * const)S3C2410_NAND_BASE;
5、配置文件include/configs/100ask24x0.h,增加如下32个宏。
#define CFG_NAND_BASE 0
#define CFG_MAX_NAND_DEVICE 1
#define NAND_MAX_CHIPS 1
6、修改配置文件 include/configs/dong2440.h,增加 NAND 命令,81 行
#define CONFIG_COMMANDS \
(CONFIG_CMD_DFL | \
CFG_CMD_CACHE | \
CFG_CMD_NAND | \
CFG_CMD_REGINFO | \
CFG_CMD_DATE | \
CFG_CMD_ELF)
最后
make clean
make all
