采用快速PWM方式,通过按键设置OCR1A的值,从而改变占空比;
当数值超出界限时,以了LED和LCD的方式报警;
输出经过滤波可以得到直流信号,改变占空比,输出不一样。
仿真原理图如下
单片机源程序如下:
#define MAIN_C
#include "includes.h"
/*PWM*/
/*晶振为4MHz*/
/*利用Timer1的OC1A脚输出占空比可调的信号*/
/*通过按键控制OCR1A的值*/
#define PwmOut PD5 //A通道的PWM输出
#define OCR OCR1A
#define KeyUp PA0 //增大PWM值的按键
#define KeyDown PA1 //减小PWM值的按键
#define Above PA2 //设置位值过高指示
#define Below PA3 //设置位值过低指示
#define STEP 64 //定义按键时的步进值
int OcrReg = 1024; //OCR1A初始值
int Icr1Reg = 0x7ff; //PWM的计数顶部值 Icr1Reg = 2047
//unsigned char *show = "0000";
unsigned char temp;
void init(void) //初始化函数
//比较匹配时清零,计数到最大时置位OC1A
TCCR1A |= (1<
//11位分辨率,快速PWM模式,使用系统时钟作为计数时钟
TCCR1B |= (1<
ICR1 = Icr1Reg;
OCR = 0 ;
DDRD |= (1<
DDRA |= (1<
DDRA &= ~((1<
PORTA |= (1<
PORTA |= (1<
//TIMSK |= (1<
//SREG |= (1<<7); //开全局中断
void ShowValue(int value)
unsigned char *temp = "0000";
temp[0] = value/1000 + 0x30;
value = value%1000;
temp[1] = value/100 +0x30;
value = value%100;
temp[2] = value/10 + 0x30;
value = value%10;
temp[3] = value + 0x30;
ClearLine(2);
LCD_DisplayString(2,1,"OCR1A = ");
LCD_DisplayString(2,9,temp);
void main(void)
unsigned char i;
init();
Init_LCD();
OCR = OcrReg;
LCD_DisplayString(1,1,"PWM test");
ShowValue(OcrReg);
while(1)
if(!(PINA&(1<
delay_nms(10); //按键消抖
if(!(PINA&(1<
while(!(PINA&(1<
if(OcrReg >= (Icr1Reg+1))
for(i=0;i<5;i++)
PORTA ^= (1<
delay_nms(200);
ClearLine(2);
LCD_DisplayString(2,1,"Value MAX!");
else
PORTA |= (1<
OcrReg += STEP;
OCR = OcrReg;
ShowValue(OcrReg);
if(!(PINA&(1<
if(!(PINA&(1<
while(!(PINA&(1<
if(OcrReg <= 0)
for(i=0;i<5;i++)
PORTA ^= (1<
delay_nms(200);
ClearLine(2);
LCD_DisplayString(2,1,"Value MIN!");
else
PORTA |= (1<
OcrReg -= STEP;
OCR = OcrReg;
ShowValue(OcrReg);
//比较中断子程序,可以用来产生正弦波
/*#pragma vector = TIMER1_COMPA_vect
__interrupt void CompA_isr( void )
OcrReg = st[j];
OCR = OcrReg;
j++;
if(j>88)
j = 0;
