#include
//定义共阳极字型码0123456789-
unsigned char code dispcode[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xbf};
unsigned char time[]={0,0,0,0,0,0,0,0};//用来储存时间
unsigned char date[]={0,0,0,0,0,0,0,0};//用来储存日期
SYSTEMTIME time1; //在ds1302.h文件中已经定义了一个名字为SYSTEMTIME的结构体,在这里我们定义一个变量名
//为time的SYSTEMTIME结构体
void delay(unsigned char i) //延时子程序
unsigned char j;
while((i--)!=0)
for(j=123;j>0;j--);
unsigned char button_time(n,x,y) //时钟调整子程序
unsigned char n,x,y;
if(P1_7==0)
delay(50);
if(P1_7==0)
n++;
if(n==x)
n=0;
while(P1_7==0);
if(P1_5==0)
delay(50);
if(P1_5==0)
if(n==0)
n=y;
else
n--;
while(P1_5==0);
return n;
unsigned char button_date(n,x,y) //日期调整子程序
if(P1_7==0)
delay(50);
if(P1_7==0)
n++;
if(n==x)
n=1;
while(P1_7==0);
if(P1_5==0)
delay(50);
if(P1_5==0)
if(n==1)
n=y;
else
n--;
while(P1_5==0);
return n;
void display(second10,second1,minute10,minute1,hour10,hour1) //显示子程序
unsigned char second10,second1,minute10,minute1,hour10,hour1;
P2=0xfe;
P0=dispcode[second10];//显示秒的十位
delay(1);
P2=0xfd;
P0=dispcode[second1]; //显示秒的个位
delay(1);
P2=0xfb;
P0=dispcode[10]; //显示"-"
delay(1);
P2=0xf7;
P0=dispcode[minute10];//显示分的十位
delay(1);
P2=0xef;
P0=dispcode[minute1]; //显示分的个位
delay(1);
P2=0xdf;
delay(1);
P2=0xbf;
P0=dispcode[hour10]; //显示时的十位
delay(1);
P2=0x7f;
P0=dispcode[hour1]; //显示时的个位
delay(1);
void main()
unsigned char flag;
Initial_DS1302(); //初始化DS1302这个时钟芯片,
while(1)
DS1302_GetTime(&time1); //读取时间参数
time[5]=(time1.Second)%10; //把秒的个位数据存入time[5]
time[4]=(time1.Second)/10; //把秒的十位数据存入time[4]
time[3]=(time1.Minute)%10; //把分的个位数据存入time[3]
time[2]=(time1.Minute)/10; //把分的十位数据存入time[2]
time[1]=(time1.Hour)%10; //把时的个位数据存入time[1]
time[0]=(time1.Hour)/10; //把时的十位数据存入time[0]
date[5]=(time1.Day)%10;
date[4]=(time1.Day)/10;
date[3]=(time1.Month)%10;
date[2]=(time1.Month)/10;
date[1]=(time1.Year)%10;
date[0]=(time1.Year)/10;
if(P1_4==0) //如果按下Time Start键一下,时钟开始正常显示时间,再按一下,显示日期
delay(50);
if(P1_4==0)
flag++;
if(flag>1)
flag=0;
while(P1_4==0);
if(P1_6==0) //如果按下Time Set键一下,开始显示日期,再按一下进入日期跟时钟的调节模式
delay(50);
if(P1_6==0)
flag++;
if(flag>7)
flag=0;
while(P1_6==0);
switch(flag)
case 0:display(time[0],time[1],time[2],time[3],time[4],time[5]); //调用子函数display,把存入数组time的数据给显示出来
break;
case 1:display(date[0],date[1],date[2],date[3],date[4],date[5]); //调用子函数display,把存入数组date的数据给显示出来
break;
case 2:time1.Year=button_date(time1.Year,100,99); //调整年
DS1302_SetTime(0x8c,time1.Year);
display(date[0],date[1],10,10,10,10);
break;
case 3:time1.Month=button_date(time1.Month,13,12); //调整月
DS1302_SetTime(0x88,time1.Month);
display(10,10,date[2],date[3],10,10);
break;
case 4:time1.Day=button_date(time1.Day,32,31); //调整日
DS1302_SetTime(0x86,time1.Day);
display(10,10,10,10,date[4],date[5]);
break;
case 5:time1.Hour=button_time(time1.Hour,24,23); //调整时
DS1302_SetTime(0x84,time1.Hour);
display(time[0],time[1],10,10,10,10);
break;
case 6:time1.Minute=button_time(time1.Minute,60,59); //调整分
DS1302_SetTime(0x82,time1.Minute);
display(10,10,time[2],time[3],10,10);
break;
case 7:time1.Second=button_time(time1.Second,60,59); //调整秒
DS1302_SetTime(0x80,time1.Second);
display(10,10,10,10,time[4],time[5]);
break;
