单片机 > 单片机程序设计 > 详情
PIC单片机滚动码解码C程序
发布时间:2025-12-19 发布时间:
//  Interrupt based receive routine
//  Compiled using HiTech PIC C compiler v.7.93
#define CLOCK           4       // MHz
#define TE            400       // us
#define OVERSAMPLING    3
#define PERIOD          TE/OVERSAMPLING*4/CLOCK
#define NBIT            65      // number of bit to receive -1(HCS300 66-1=65)
unsigned char B[9];             // receive buffer
static byte  RFstate;           // receiver state
static sbyte RFcount;           // timer counter
static byte  Bptr;              // receive buffer pointer
static byte  BitCount;          // received bits counter
word   XTMR;                    // 16 bit extended timer
volatile bit RFFull;            // buffer full
volatile bit RFBit;             // sampled RF signal
#define TRFreset    0
#define TRFSYNC     1
#define TRFUNO      2
#define TRFZERO     3
#define HIGH_TO     -10         // longest high Te
#define LOW_TO       10         // longest low  Te
#define SHORT_HEAD   20         // shortest Thead accepted 2,7ms
#define LONG_HEAD    45         // longest Thead accepted 6,2ms
#pragma int_rtcc       // install as interrupt handler (comment for HiTech!)
void interrupt rxi(void)  //this routine gets called every time TMR0 overflows
    RFBit = RFIn;               // sampling RF pin verify!!!
    TMR0 -= PERIOD;             // reload
    T0IF = 0;
    XTMR++;                     // extended 16 long timer update
    if (RFFull)                 // avoid overrun
    {    return;}
    switch( RFstate)            // state machine main switch
    case TRFUNO:
        if ( RFBit)
        { // while high
            RFcount--;
            if ( RFcount < HIGH_TO)
                RFstate = TRFreset;      // reset if too long
        else
        { // falling edge detected  ----+
                RFstate= TRFZERO;
        break;
    case TRFZERO:
        if ( RFBit)
        { // rising edge detected     +----
            RFstate= TRFUNO;
            B[Bptr] >>= 1;              // rotate
            if ( RFcount >= 0)
            {    B[Bptr]+=0x80; }       // shift in bit
            RFcount = 0;                // reset length counter
            if ( ( ++BitCount & 7) == 0)
            {    Bptr++;    }           // advance one byte
            if (BitCount == NBIT)
                RFstate = TRFreset;     // finished receiving
                RFFull = TRUE;
        else
        { // still low
            RFcount++;
            if ( RFcount >= LOW_TO)     // too long low
                RFstate = TRFSYNC;      // fall back into RFSYNC state
                Bptr = 0;               // reset pointers, while keep counting on
                BitCount = 0;
        break;
    case TRFSYNC:
        if ( RFBit)
        { // rising edge detected  +---+                +---..
            if ( ( RFcount < SHORT_HEAD) || ( RFcount >= LONG_HEAD))
                RFstate = TRFreset;
                break;                  // too short/long, no header
            else
                RFcount =0;             // restart counter
                RFstate= TRFUNO;  //合适的长低电平信号出现
        else
        { // still low
            RFcount++;
        break;
    case TRFreset:      //初始状态
    default:
        RFstate = TRFSYNC;          // reset state machine in all other cases
        RFcount = 0;
        Bptr = 0;
        BitCount = 0;
        break;
    } // switch
} // rxi
void InitReceiver()
    T0IF = 0;
    T0IE = 1;                   // TMR0 overflow interrupt
    GIE = 1;                    // enable interrupts
    RFstate = TRFreset;         // reset state machine in all other cases
    RFFull = 0;                 // start with buffer empty
    XTMR = 0;                   // start extende
关键字:PIC单片机  滚动码解码
stm32f4 - 时钟树分析配置
