一、输入捕获介绍
输入捕获模式可以用来测量脉冲宽度或者测量频率。
除了基本定时器,通用和高级均有输入捕获功能。
TIMx_CCMR1(捕获/比较模式寄存器) - 通道1和2的控制
TIMx_CCMR2(捕获/比较模式寄存器) - 通道3和4的控制
二、脉宽测量实现超声波测距
当然还需要配合printf一起使用,
#include "timer.h"
#include
/*TIM3_CH3输入捕获初始化*/
TIM_ICInitTypeDef TIM3_ICInitStructure;
void TIM3_Cap_Init(u16 arr,u16 psc)
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
NVIC_InitTypeDef NVIC_InitStructure;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE); //使能TIM3时钟
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE); //使能GPIOB时钟
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD; //PB0 输入
GPIO_Init(GPIOB, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //PB1输出
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz; //2M
//初始化定时器3 TIM3
TIM_TimeBaseStructure.TIM_Period = arr; //设定计数器自动重装值
TIM_TimeBaseStructure.TIM_Prescaler =psc; //预分频器
TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; //设置时钟分割:TDTS = Tck_tim
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //TIM向上计数模式
TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure); //根据TIM_TimeBaseInitStruct中指定的参数初始化TIMx的时间基数单位
//初始化TIM3输入捕获参数
TIM3_ICInitStructure.TIM_Channel = TIM_Channel_3; //CC1S=01 选择输入端 IC3映射到TI3上
TIM3_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising; //上升沿捕获
TIM3_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI;
TIM3_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1; //配置输入分频,不分频
TIM3_ICInitStructure.TIM_ICFilter = 0x00;//配置输入滤波器 不滤波
TIM_ICInit(TIM3, &TIM3_ICInitStructure);
//中断分组初始化
NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn; //TIM3中断
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2; //先占优先级2级
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; //从优先级0级
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道被使能
NVIC_Init(&NVIC_InitStructure); //根据NVIC_InitStruct中指定的参数初始化外设NVIC寄存器
TIM_ITConfig(TIM3,TIM_IT_Update|TIM_IT_CC3,ENABLE);//允许更新中断 ,允许CC3IE捕获中断
TIM_Cmd(TIM3,ENABLE ); //使能定时器3
/*超声波回波接收函数*/
u32 Distance;
u16 TIM3CH3_CAPTURE_STA,TIM3CH3_CAPTURE_VAL;
void Read_Distane(void)
PBout(1)=1;
delay_us(15);
PBout(1)=0;
if(TIM3CH3_CAPTURE_STA&0X80)//成功捕获到了一次高电平
Distance=TIM3CH3_CAPTURE_STA&0X3F;
Distance*=65536; //溢出时间总和
Distance+=TIM3CH3_CAPTURE_VAL; //得到总的高电平时间
Distance=Distance*170/1000;
printf("%d \r\n",Distance);
TIM3CH3_CAPTURE_STA=0; //开启下一次捕获
/*超声波回波脉宽读取中断*/
void TIM3_IRQHandler(void)
u16 tsr;
tsr=TIM3->SR;
if((TIM3CH3_CAPTURE_STA&0X80)==0)//还未成功捕获
if(tsr&0X01)//溢出
if(TIM3CH3_CAPTURE_STA&0X40)//已经捕获到高电平了
if((TIM3CH3_CAPTURE_STA&0X3F)==0X3F)//高电平太长了
TIM3CH3_CAPTURE_STA|=0X80;//标记成功捕获了一次
TIM3CH3_CAPTURE_VAL=0XFFFF;
else
TIM3CH3_CAPTURE_STA++;
if(tsr&0x08)//捕获3发生捕获事件
if(TIM3CH3_CAPTURE_STA&0X40) //捕获到一个下降沿
TIM3CH3_CAPTURE_STA|=0X80; //标记成功捕获到一次高电平脉宽
TIM3CH3_CAPTURE_VAL=TIM3->CCR3; //获取当前的捕获值.
TIM3->CCER&=~(1<<9); //CC1P=0 设置为上升沿捕获
else //还未开始,第一次捕获上升沿
TIM3CH3_CAPTURE_STA=0; //清空
TIM3CH3_CAPTURE_VAL=0;
TIM3CH3_CAPTURE_STA|=0X40; //标记捕获到了上升沿
TIM3->CNT=0; //计数器清空
TIM3->CCER|=1<<9; //CC1P=1 设置为下降沿捕获
TIM3->SR=0;//清除中断标志位
主函数
#include "config.h"
#include "led.h"
#include "key.h"
#include "timer.h"
#include "motor.h"
#include "usart.h"
#include
int main(void)
uart_init(115200);
printf("HelloWorld\r\n");
TIM3_Cap_Init(0XFFFF,72-1);
while(1)
Read_Distane();
delay_ms(200);
当时学习的时候也有疑惑的地方,TIM3_ICInitStructure.TIM_Channel = TIM_Channel_3; //CC1S=01 选择输入端 IC3映射到TI3上后来在手册P291找到了相应的答案!!!
