_# 我从github上下载了libopencm3的源码,编译的时候报错:
GENHDR efm32/efm32g/irq.json
:没有那个文件或目录
make【1】:***[efm32/efm32g/irq.json.genhdr] 错误127
请问如何解决**___
以下为Makefile文件:
## This file is part of the libopencm3 project.
## Copyright (C) 2009 Uwe Hermann
## This library is free software: you can redistribute it and/or modify
## it under the terms of the GNU Lesser General Public License as published by
## the Free Software Foundation, either version 3 of the License, or
## (at your option) any later version.
## This library is distributed in the hope that it will be useful,
## but WITHOUT ANY WARRANTY; without even the implied warranty of
## MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
## GNU Lesser General Public License for more details.
## You should have received a copy of the GNU Lesser General Public License
## along with this library. If not, see .
PREFIX ?= arm-none-eabi
#PREFIX ?= arm-elf
STYLECHECK := scripts/checkpatch.pl
STYLECHECKFLAGS := --no-tree -f --terse --mailback
DESTDIR ?= /usr/local
INCDIR := $(DESTDIR)/$(PREFIX)/include
LIBDIR := $(DESTDIR)/$(PREFIX)/lib
SHAREDIR := $(DESTDIR)/$(PREFIX)/share/libopencm3/scripts
INSTALL := install
space:=
space+=
SRCLIBDIR:= $(subst $(space),\$(space),$(realpath lib))
TARGETS:= stm32/f0 stm32/f1 stm32/f2 stm32/f3 stm32/f4 stm32/l0 stm32/l1 \
lpc13xx lpc17xx lpc43xx/m4 lpc43xx/m0 lm3s lm4f \
efm32/efm32tg efm32/efm32g efm32/efm32lg efm32/efm32gg \
sam/3a sam/3n sam/3s sam/3u sam/3x \
vf6xx
# Be silent per default, but 'make V=1' will show all compiler calls.
ifneq ($(V),1)
Q := @
# Do not print "Entering directory ...".
MAKEFLAGS += --no-print-directory
endif
IRQ_DEFN_FILES := $(shell find . -name 'irq.json')
STYLECHECKFILES := $(shell find . -name '*.[ch]')
all: build
build: lib
%.genhdr:
@printf " GENHDR $*\n";
@./scripts/irq2nvic_h ./$*;
%.cleanhdr:
@printf " CLNHDR $*\n";
@./scripts/irq2nvic_h --remove ./$*
LIB_DIRS:=$(wildcard $(addprefix lib/,$(TARGETS)))
$(LIB_DIRS): $(IRQ_DEFN_FILES:=.genhdr)
@printf " BUILD $@\n";
$(Q)$(MAKE) --directory=$@ SRCLIBDIR="$(SRCLIBDIR)"
lib: $(LIB_DIRS)
$(Q)true
install: lib
@printf " INSTALL headers\n"
$(Q)$(INSTALL) -d $(INCDIR)/libopencm3
$(Q)$(INSTALL) -d $(INCDIR)/libopencmsis
$(Q)$(INSTALL) -d $(LIBDIR)
$(Q)$(INSTALL) -d $(SHAREDIR)
$(Q)cp -r include/libopencm3*.ld $(LIBDIR)
@printf " INSTALL scripts\n"
$(Q)$(INSTALL) -m 0644 scripts/*.scr $(SHAREDIR)
html doc:
$(Q)$(MAKE) -C doc html
clean: $(IRQ_DEFN_FILES:=.cleanhdr) $(LIB_DIRS:=.clean) $(EXAMPLE_DIRS:=.clean) doc.clean styleclean
%.clean:
$(Q)if [ -d $* ]; then \
printf " CLEAN $*\n"; \
$(MAKE) -C $* clean SRCLIBDIR="$(SRCLIBDIR)" || exit $?; \
fi;
stylecheck: $(STYLECHECKFILES:=.stylecheck)
styleclean: $(STYLECHECKFILES:=.styleclean)
# the cat is due to multithreaded nature - we like to have consistent chunks of text on the output
%.stylecheck: %
$(Q)if ! grep -q "* It was generated by the irq2nvic_h script." $* ; then \
$(STYLECHECK) $(STYLECHECKFLAGS) $* > $*.stylecheck; \
if [ -s $*.stylecheck ]; then \
cat $*.stylecheck; \
else \
rm -f $*.stylecheck; \
fi; \
fi;
%.styleclean:
$(Q)rm -f $*.stylecheck;
LDTESTS :=$(wildcard ld/tests/*.data)
genlinktests: $(LDTESTS:.data=.ldtest)
%.ldtest:
@if ./scripts/genlinktest.sh $* >/dev/null; then\
printf " TEST OK : $*\n"; \
else \
printf " TEST FAIL : $*\n"; \
fi;
.PHONY: build lib $(LIB_DIRS) install doc clean generatedheaders cleanheaders stylecheck genlinktests
开始使用libopencm3来开发stm32很方便,但是当前该项目还在进行中,无法很顺心的使用,无奈在编译arm-none-eabi-gcc的时候没有编译官方库,只得下载stm32的官方库(V3.5),由于在gcc下的开发经验有限,卡在了启动文件(使用汇编编写)和链接脚本上了。好在stm32官方库中提供了启动文件(我使用的是startup_stm32f10x_md.s)和链接脚本(在gcc-ride7文件夹下的stm32f10x_flash_extsram.ld),启动文件可以直接使用,但是链接脚本需要修改,首先要修改FLASH和RAM的起始地址和大小,还有最高堆栈地址_estack,根据自己的stm32f103c8分别修改成0x08000000,0x20000000,0x20004e20后编译可运行
其实现在对于gcc的这一套编译过程还不是很了解,还有汇编在C语言中的地位似乎还是非常重要的,通过研究链接脚本可以知道。
完成配置工作,接下来就是采用该库进行编程了,希望一起顺利,PWM产生-->PWM捕捉测量脉宽,先完成这个简单的工作把^_^
