仿真原理图如下
单片机源程序如下:
#include
sbit wr=P3^6;
sbit rd=P3^2;
sbit key0=P1^0;
sbit key1=P1^1;
sbit key2=P1^2;
sbit key3=P1^3;
sbit key4=P1^4;
unsigned char flag;//flag为0、1、2、3、4时分别为正弦波、方波、三角波、梯形波、锯齿波
unsigned char const code ZXB_code[256]={
0x80,0x83,0x86,0x89,0x8c,0x8f,0x92,0x95,0x98,0x9c,0x9f,0xa2,
0xa5,0xa8,0xab,0xae,0xb0,0xb3,0xb6,0xb9,0xbc,0xbf,0xc1,0xc4,
0xc7,0xc9,0xcc,0xce,0xd1,0xd3,0xd5,0xd8,0xda,0xdc,0xde,0xe0,
0xe2,0xe4,0xe6,0xe8,0xea,0xec,0xed,0xef,0xf0,0xf2,0xf3,0xf4,
0xf6,0xf7,0xf8,0xf9,0xfa,0xfb,0xfc,0xfc,0xfd,0xfe,0xfe,0xff,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xfe,
0xfd,0xfc,0xfc,0xfb,0xfa,0xf9,0xf8,0xf7,0xf6,0xf5,0xf3,0xf2,
0xf0,0xef,0xed,0xec,0xea,0xe8,0xe6,0xe4,0xe3,0xe1,0xde,0xdc,
0xda,0xd8,0xd6,0xd3,0xd1,0xce,0xcc,0xc9,0xc7,0xc4,0xc1,0xbf,
0xbc,0xb9,0xb6,0xb4,0xb1,0xae,0xab,0xa8,0xa5,0xa2,0x9f,0x9c,
0x99,0x96,0x92,0x8f,0x8c,0x89,0x86,0x83,0x80,0x7d,0x79,0x76,
0x73,0x70,0x6d,0x6a,0x67,0x64,0x61,0x5e,0x5b,0x58,0x55,0x52,
0x4f,0x4c,0x49,0x46,0x43,0x41,0x3e,0x3b,0x39,0x36,0x33,0x31,
0x2e,0x2c,0x2a,0x27,0x25,0x23,0x21,0x1f,0x1d,0x1b,0x19,0x17,
0x15,0x14,0x12,0x10,0xf,0xd,0xc,0xb,0x9,0x8,0x7,0x6,0x5,0x4,
0x3,0x3,0x2,0x1,0x1,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,
0x0,0x1,0x1,0x2,0x3,0x3,0x4,0x5,0x6,0x7,0x8,0x9,0xa,0xc,0xd,
0xe,0x10,0x12,0x13,0x15,0x17,0x18,0x1a,0x1c,0x1e,0x20,0x23,
0x25,0x27,0x29,0x2c,0x2e,0x30,0x33,0x35,0x38,0x3b,0x3d,0x40,
0x43,0x46,0x48,0x4b,0x4e,0x51,0x54,0x57,0x5a,0x5d,0x60,0x63,
0x66,0x69,0x6c,0x6f,0x73,0x76,0x79,0x7c
}; //用于生成正弦
unsigned char keyscan() //键盘扫描函数
unsigned char keyscan_num,temp;
P1=0xff;
temp=P1;
if(~(temp&0xff))
if(key0==0)
keyscan_num=1;
else if(key1==0)
keyscan_num=2;
else if(key2==0)
keyscan_num=3;
else if(key3==0)
keyscan_num=4;
else if(key4==0)
keyscan_num=5;
else
keyscan_num=0;
return keyscan_num;
void init_DA0832()//DA芯片准备函数
rd=0;
wr=0;
void ZXB()//正弦波函数
unsigned int i;
do{
P2=ZXB_code[i];
i=i+1;
}while(i<256);
void FB()//方波
EA=1;
ET0=1;
TMOD=1;
TR0=1;
TH0=0xff;
TL0=0x83;
void SJB()//三角波
P2=0x00;
do{
P2=P2+1;
}while(P2<0xff);
P2=0xff;
do{
P2=P2-1;
}while(P2>0x00);
P2=0x00;
void JCB()//锯齿波
P2=0x00;
do{
P2=P2+1;
}while(P2<=0xff);
void TXB()//梯形波
unsigned char i;
P2=0x00;
do{
P2=P2+1;
}while(P2<0xff);
P2=0xff;
for(i=255;i>0;i--)
P2=0xff;
do{
P2=P2-1;
}while(P2>0x00);
P2=0x00;
void main()
init_DA0832();
do
flag=keyscan();
}while(!flag);//等待按键按下
while(1)
switch(flag)
case 1:
do{
flag=keyscan();
ZXB();
}while(flag==1);
break;
case 2:
FB();
do{
flag=keyscan();
}while(flag==2);
TR0=0;
break;
case 3:
do{
flag=keyscan();
SJB();
}while(flag==3);
break;
case 4:
do{
flag=keyscan();
TXB();
}while(flag==4);
break;
case 5:
do{
flag=keyscan();
JCB();
}while(flag==5);
break;
default:
flag=keyscan();
break;
void timer0(void) interrupt 1
P2=~P2;
TH0=0xff;
TL0=0x83;
TR0=1;
