flash的初始化,解锁flash和清除一些flash的异常状态标识
uint16_t MEM_If_Init_FS(void)
HAL_FLASH_Unlock();
__HAL_FLASH_CLEAR_FLAG(FLASH_FLAG_EOP | FLASH_FLAG_OPERR | FLASH_FLAG_WRPERR |
FLASH_FLAG_PGAERR | FLASH_FLAG_PGPERR | FLASH_FLAG_PGSERR);
uint16_t MEM_If_DeInit_FS(void)
HAL_FLASH_Lock();
flash 的檫除操作
uint16_t MEM_If_Erase_FS(uint32_t start_Add,uint32_t end_Add)
/* USER CODE BEGIN 3 */
uint32_t UserStartSector;
uint32_t SectorError;
FLASH_EraseInitTypeDef pEraseInit;
/* Unlock the Flash to enable the flash control register access *************/
MEM_If_Init_FS();
/* Get the sector where start the user flash area */
UserStartSector = GetSector(start_Add);
pEraseInit.TypeErase = TYPEERASE_SECTORS;
pEraseInit.Sector = UserStartSector;
pEraseInit.NbSectors = GetSector(end_Add)-UserStartSector+1 ;
pEraseInit.VoltageRange = VOLTAGE_RANGE_3;
if (HAL_FLASHEx_Erase(&pEraseInit, &SectorError) != HAL_OK)
/* Error occurred while page erase */
return (1);
return (USBD_OK);
/* USER CODE END 3 */
擦除操作,先解锁,然后清空所需flash所在sector。注意这里的sector使用GetSector()函数获取的,是一个整型数字(对于F4就是0~11)。
其中的NbSectors是需要清除的sector的个数。
下面是获取sector的编号
我们先按照用户手册上写的在文件usbd_dfu_if.h中define一些需要用到的sector起始地址
#define ADDR_FLASH_SECTOR_0 ((uint32_t)0x08000000) /* Base @ of Sector 0, 16 Kbyte */
#define ADDR_FLASH_SECTOR_1 ((uint32_t)0x08004000) /* Base @ of Sector 1, 16 Kbyte */
#define ADDR_FLASH_SECTOR_2 ((uint32_t)0x08008000) /* Base @ of Sector 2, 16 Kbyte */
#define ADDR_FLASH_SECTOR_3 ((uint32_t)0x0800C000) /* Base @ of Sector 3, 16 Kbyte */
#define ADDR_FLASH_SECTOR_4 ((uint32_t)0x08010000) /* Base @ of Sector 4, 64 Kbyte */
#define ADDR_FLASH_SECTOR_5 ((uint32_t)0x08020000) /* Base @ of Sector 5, 128 Kbyte */
#define ADDR_FLASH_SECTOR_6 ((uint32_t)0x08040000) /* Base @ of Sector 6, 128 Kbyte */
#define ADDR_FLASH_SECTOR_7 ((uint32_t)0x08060000) /* Base @ of Sector 7, 128 Kbyte */
#define ADDR_FLASH_SECTOR_8 ((uint32_t)0x08080000) /* Base @ of Sector 8, 128 Kbyte */
#define ADDR_FLASH_SECTOR_9 ((uint32_t)0x080A0000) /* Base @ of Sector 9, 128 Kbyte */
#define ADDR_FLASH_SECTOR_10 ((uint32_t)0x080C0000) /* Base @ of Sector 10, 128 Kbyte */
#define ADDR_FLASH_SECTOR_11 ((uint32_t)0x080E0000) /* Base @ of Sector 11, 128 Kbyte */
再在usbd_dfu_if.c文件末尾添加函数:
* @brief Gets the sector of a given address
* @param Address: Flash address
* @retval The sector of a given address
static uint32_t GetSector(uint32_t Address)
uint32_t sector = 0;
if((Address < ADDR_FLASH_SECTOR_1) && (Address >= ADDR_FLASH_SECTOR_0))
sector = FLASH_SECTOR_0;
else if((Address < ADDR_FLASH_SECTOR_2) && (Address >= ADDR_FLASH_SECTOR_1))
sector = FLASH_SECTOR_1;
else if((Address < ADDR_FLASH_SECTOR_3) && (Address >= ADDR_FLASH_SECTOR_2))
sector = FLASH_SECTOR_2;
else if((Address < ADDR_FLASH_SECTOR_4) && (Address >= ADDR_FLASH_SECTOR_3))
sector = FLASH_SECTOR_3;
else if((Address < ADDR_FLASH_SECTOR_5) && (Address >= ADDR_FLASH_SECTOR_4))
sector = FLASH_SECTOR_4;
else if((Address < ADDR_FLASH_SECTOR_6) && (Address >= ADDR_FLASH_SECTOR_5))
sector = FLASH_SECTOR_5;
else if((Address < ADDR_FLASH_SECTOR_7) && (Address >= ADDR_FLASH_SECTOR_6))
sector = FLASH_SECTOR_6;
else if((Address < ADDR_FLASH_SECTOR_8) && (Address >= ADDR_FLASH_SECTOR_7))
sector = FLASH_SECTOR_7;
else if((Address < ADDR_FLASH_SECTOR_9) && (Address >= ADDR_FLASH_SECTOR_8))
sector = FLASH_SECTOR_8;
else if((Address < ADDR_FLASH_SECTOR_10) && (Address >= ADDR_FLASH_SECTOR_9))
sector = FLASH_SECTOR_9;
else if((Address < ADDR_FLASH_SECTOR_11) && (Address >= ADDR_FLASH_SECTOR_10))
sector = FLASH_SECTOR_10;
else
sector = FLASH_SECTOR_11;
return sector;
flash写入操作
uint16_t MEM_If_Write_FS(uint8_t *src, uint8_t *dest, uint32_t Len)
uint32_t i = 0;
for(i = 0; i < Len; i+=4)
/* Device voltage range supposed to be [2.7V to 3.6V], the operation will
be done by byte */
if(HAL_FLASH_Program(FLASH_TYPEPROGRAM_WORD, (uint32_t)(dest+i), *(uint32_t*)(src+i)) == HAL_OK)
/* Check the written value */
if(*(uint32_t *)(src + i) != *(uint32_t*)(dest+i))
/* Flash content doesn't match SRAM content */
return 2;
else
/* Error occurred while writing data in Flash memory */
return 1;
return (HAL_OK);
flash读出操作
uint8_t *MEM_If_Read_FS (uint8_t *src, uint8_t *dest, uint32_t Len)
/* Return a valid address to avoid HardFault */
/* USER CODE BEGIN 4 */
uint32_t i = 0;
uint8_t *psrc = src;
for(i = 0; i < Len; i++)
dest[i] = *psrc++;
return HAL_OK;
/* USER CODE END 4 */
