趁热打铁,在上一PIC32MZ UDP ethernet bootloader的基础上我又完成了采用TCP协议的PIC32MZ ethernet bootloader。两款ethernet bootloader基本架构都一样,数据包格式也一样。TCP ethernet bootloader 也分两部分,我将他们命名为PhnLoader_v4.0和PhnBoot_v4.0。
PhnLoader_v4.0
PhnLoader_v4.0 是PC端host 程序。
运行环境:Window + .NET Framework 4.5
开发语言:C#
通信类型:TCP Server
IP 地址: 192.168.1.105
端口号: 8720
UI 如下:
主要代码如下:
try { while (loaderReader.Peek() >= 0) { pBarLoading.PerformStep(); recordLine = loaderReader.ReadLine(); if (recordLine.Contains(EXTEND_TOKEN) == true) { if (recordLine.Contains(USER_ID_TOKEN) == true) { isNextLineUserID = true; continue; } //else if (recordLine.Contains(CONFIG_BITS_TOKEN) == true) //{ // const int ADDR_U_START_INDEX = 9; // const int ADDR_U_LENGTH = 4; // string addrU = recordLine.Substring(ADDR_U_START_INDEX, ADDR_U_LENGTH); // loaderUpperAddr = Convert.ToInt32(addrU, 16) <
PhnBoot_v4.0
PhnBoot_v4.0 是单片机端Boot 程序。
运行环境:PIC32MZ EC Starter Kit
开发语言:C 语言 (Microchip XC32 free)
通信类型:TCP Client
IP 地址: 192.168.1.123
端口号: 随机生成
主要代码段:
switch (GenTCPSt) { case SM_HOME: ARPResolve(&ServerNode.IPAddr); startTime = TickGet(); GenTCPSt++; break; case SM_ARPed: if (TickGet() - startTime = BUFFER_MAX) { TCPGetArray(MySock,frameBuffer,BUFFER_MAX); if (!TCPIsGetReady(MySock)) TCPDiscard(MySock); //take care of packet splicing if (frameBuffer[0] == STX && frameBuffer[BUFFER_MAX - 1] == ETX) {// for(i=0;i= BUFFER_MAX) { Uart_Putc('.'); TCPPutArray(MySock, frameBuffer, BUFFER_MAX); TCPFlush(MySock); } startTime = TickGet(); GenTCPSt = SM_TCPGET; } else { printf("xx"); // for debug GenTCPSt = SM_CLOSE; } break; case SM_CLOSE: printf("done\r\n"); // for debug TCPDisconnect(MySock); MySock = INVALID_SOCKET; GenTCPSt = SM_HOME; TRISCSET = 0x2000; // RC13 Input LATCCLR = 0x6000; // Clear LATC LATHCLR = (1<<2); TRISHSET = (1<<2); INTDisableInterrupts(); T1CON = 0; IEC0CLR = _IEC0_T1IE_MASK; ETHCON1 = 0; ETHCON2 = 0; CoreT_DelayMs(1); U1MODE = 0x0; U1STA = 0x0; (*((void(*)(void))USER_APP_RESET_ADDRESS))(); break; } }
如何使用PhnLoader_v4.0和PhnBoot_v4.0
1. 使用XC32编译PhnBoot_v4.0(编译前,需先修改linker script, 需要设置Optimization level为1)。
2. 使用pickit3烧录PhnBoot_v4.0的Hex文件到目标板中。
3. 拔除pickit3烧录器
4. 连接目标板和PC到同一局域网,设置PC的IP地址,打开PhnLoader_v4.0,选择TCP协议,端口号,IP地址。
5. 点击PhnLoader_v4.0用户界面上的“.."按钮加载需要烧录的应用程序Hex文件(编译前,需先修改linker script)
6. 重启目标板,等到LED3 灯亮了,立刻在PhnLoader_v4.0界面上点击Download按钮。如果超时未点击Download按钮,会自动跳转到上次烧录的应用程序中去。
7. 烧录完毕,再次重启目标板, 数秒后目标板开始正常运行应用程序。
之后每次更新应用程序,只需重复步骤 4 ~ 7 就可以了。注意,整个烧录过程未能实现User ID/Configuration Bits的烧写,所以需要保持应用程序的Configuration Bits和Bootloader的Configuration Bits一致。
关键字:TCP协议 PIC32MZ ethernet bootloader
