根据扫描键盘返回的键值编码查键值编码表,从而得到键值并送数码管显示。
开机时,数码管显示“-”。
当键按下时,数码管显示按下键的键值,蜂鸣器响一声。*/
#include
#include
#define uchar unsigned char
#define uint unsigned int
sbit BEEP = P3^6; //蜂鸣器驱动线
uchar key;
unsigned char code disp_code[]={
0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,
0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e,0xbf};
unsigned char code key_code[]={
0xee,0xde,0xbe,0x7e,0xed,0xdd,0xbd,0x7d,
0xeb,0xdb,0xbb,0x7b,0xe7,0xd7,0xb7,0x77 };
延时子函数
void delayms(uint ms)
uchar t;
while(ms--)
for(t = 0; t < 120; t++);
x*0.14MS 延时子函数
void delay0(uchar x)
uchar i;
while(x--)
for (i = 0; i<13; i++) {;}
蜂鸣器驱动子函数
void beep()
uchar i;
for (i=0;i<180;i++)
delay0(5);
BEEP=!BEEP; //BEEP取反
BEEP=1; //关闭蜂鸣器
delayms(250); //延时
键盘扫描子函数
uchar keyscan()
uchar scan1,scan2,keycode,j;
P1=0xf0;
scan1=P1;
if((scan1&0xf0)!=0xf0) //判键是否按下
delayms(30); //延时30ms
scan1=P1;
if((scan1&0xf0)!=0xf0) //二次判键是否按下
P1=0x0f;
scan2=P1;
keycode=scan1|scan2; //组合成键编码
for(j=0;j<=15;j++)
if(keycode== key_code[j]) //查表得键值
key=j;
return(key);
else P1=0xff;
return (16);
判键是否按下子函数
void keydown()
P1=0xf0;
if((P1&0xf0)!=0xf0)
keyscan();
P0=disp_code[key];
beep();
主函数
main()
P0 = 0xbf;
P2 = 0x7f; //数码管显示"-"
P1 = 0xff;
while(1)
keydown();
