//使用12MHz晶振,P0口输出段码,P2口作列扫描,用共阳LED数码管
#include "reg51.h"
code char dis_7[11]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0xff};
/* 共阳LED段码表 "0" "1" "2" "3" "4" "5" "6" "7" "8" "9" "不亮" */
code char sCAN_con[8]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f}; // 列扫描控制字
data char disdata[6]={0x00,0x00,0x00,0x00,0x00,0x00};//计时单元数据初值,共6个
data char dis[8]={0x00,0x00,0x00,0x00,0x00,0x00,0x0a,0x00};//显示单元数据,共6个数据
data char con1s=0x00,con04s=0x00,con=0X00; //1秒定时用
sbit key0=0x90;
sbit key1=0x91;
sbit key2=0x92;
//1毫秒延时程序//
delay1ms(int t)
int i,j;
for(i=0;i
// 键扫描子程序 //
keyscan()
EA=0;
if(key0==0)
delay1ms(10);
while(key0==0);
if(dis[con]==10)
{dis[7]=dis[con];dis[con]=dis[6];dis[6]=dis[7];}
con++;TR0=0;ET0=0;TR1=1;ET1=1;
if(con>=6)
{con=0;TR1=0;ET1=0;TR0=1;ET0=1;}
if(con!=0)
if(key1==0)
delay1ms(10);
while(key1==0);
disdata[con]++;
if(disdata[con]>=10)
{disdata[con]=0;}
dis[con]=disdata[con];dis[6]=0x0a;
if(con!=0)
if(key2==0)
delay1ms(10);
while(key2==0);
if(disdata[con]==0)
{disdata[con]=0x09;}
else {disdata[con]--;}
EA=1;
//扫描程序//
scan()
char k;
for(k=0;k<6;k++)
P0=dis_7[dis[k]];P2=scan_con[k];delay1ms(1);P2=0xff;
//初始化程序//
clearmen()
int i;
for(i=0;i<6;i++)
dis[i]=disdata[i];}
TH0=0x3C;TL0=0xB0;// ;50MS定时初值(T0计时用)
TH1=0x3C;TL1=0xB0;// ;50MS定时初值(T1计时用)
TMOD=0X11;ET0=1;ET1=1;TR1=0;TR0=1;EA=1;//
//主程序//
main()
clearmen();
while(1)
scan();
keyscan();
//1秒中断处理程序 //
void time_intt0(void) interrupt 1
ET0=0;TR0=0;TH0=0x3C;TL0=0xB0;TR0=1;
con1s++;
if(con1s==20)
con1s=0x00;
disdata[0]++;
if(disdata[0]>=10)
disdata[0]=0;disdata[1]++;
if(disdata[1]>=6)
disdata[1]=0;disdata[2]++;
if(disdata[2]>=10)
disdata[2]=0;disdata[3]++;
if(disdata[3]>=6)
disdata[3]=0;disdata[4]++;
if(disdata[4]>=10)
disdata[4]=0;disdata[5]++;
if(disdata[5]==2 )
if(disdata[4]==4)
disdata[4]=0;disdata[5]=0;
dis[0]=disdata[0];dis[1]=disdata[1];dis[2]=disdata[2];
dis[3]=disdata[3];dis[4]=disdata[4];dis[5]=disdata[5];
ET0=1;
//0.4秒闪烁中断程序 //
void time_intt1(void) interrupt 3
EA=0;TR1=0;TH1=0x3C;TL1=0xB0;TR1=1;
con04s++;
if(con04s==8)
con04s=0x00;
EA=1;
