1. 注册软中断当然是通过open_softirq
例子如下:
void __init init_timers(void)
int err = timer_cpu_notify(&timers_nb, (unsigned long)CPU_UP_PREPARE,
(void *)(long)smp_processor_id());
init_timer_stats();
BUG_ON(err == NOTIFY_BAD);
register_cpu_notifier(&timers_nb);
open_softirq(TIMER_SOFTIRQ, run_timer_softirq);
void open_softirq(int nr, void (*action)(struct softirq_action *))
softirq_vec[nr].action = action;
软中断TIMER_SOFTIRQ的中断处理函数为:run_timer_softirq
之所以成为softirq,是因为这些中断是由硬件中断来间接触发的,如何间接触发的呢:
硬件中断处理函数-->对软中断的相应位置位-->唤醒ksoftirqd线程-->执行软中断的中断处理函数
2. 硬件中断如何通过置位唤醒ksoftirqd线程
timer interrupt handler->
timer_tick->
update_process_times->
run_local_timers->
hrtimer_run_queues()和raise_softirq(TIMER_SOFTIRQ)->
raise_softirq_irqoff->
__raise_softirq_irqoff { or_softirq_pending(1UL << (nr)); }
即(local_softirq_pending() |= (x))
3. 如何执行软中断的action
对于TIMER_SOFTIRQ来说,每次system clock产生中断时,即一个tick 到来时,在system clock的中断处理函数中会调用run_local_timers来设置TIMER_SOFTIRQ触发条件;也就是当前CPU对应的irq_cpustat_t结构体中的__softirq_pending成员的第TIMER_SOFTIRQ个BIT被置为1。 而当这个条件满足时,ksoftirqd线程(入口函数run_ksoftirqd,cpu_callback:kthread_create(run_ksoftirqd, hcpu, "ksoftirqd/%d", hotcpu);)会被唤醒,然后按照下面的流程调用TIMER_SOFTIRQ在数组softirq_vec中注册的action,即run_timer_softirq。
run_ksoftirqd--->do_softirq--->__do_softirq--->softirq_vec[TIMER_SOFTIRQ].action
static int run_ksoftirqd(void * __bind_cpu)
set_current_state(TASK_INTERRUPTIBLE);
while (!kthread_should_stop()) {
preempt_disable();
if (!local_softirq_pending()) {
preempt_enable_no_resched();
schedule();
preempt_disable();
__set_current_state(TASK_RUNNING);
while (local_softirq_pending()) {
/* Preempt disable stops cpu going offline.
If already offline, we'll be on wrong CPU:
don't process */
if (cpu_is_offline((long)__bind_cpu))
goto wait_to_die;
do_softirq();
cond_resched();
preempt_disable();
rcu_sched_qs((long)__bind_cpu);
preempt_enable();
return 0;
wait_to_die:
preempt_enable();
/* Wait for kthread_stop */
schedule();
return 0;
