//ADEN置位即启动ADC ,否则ADC功能关闭。在转换过程中关闭ADC将立即中止正在进行的转换。同时ADEN清零会将ADIE(AD结束中断使能)清除。另外工作在连续模式下如果没有对ADEN清零则AD采样一直运行。
#include "main.h"
#define HOT_MUX 4
#define MIX_MUX 5
#define POWER_MUX 7
#define AD_PORT PORTA
#define AD_DIR DDRA
//采集次数
#define HOT_SAMP_CNT 4
#define MIX_SAMP_CNT 4
#define POWER_SAMP_CNT 4
unsigned char AD_READY = 0;
volatile unsigned int buf[8];
volatile unsigned int AD_hot_result = 0;
volatile unsigned int AD_mix_result = 0;
volatile unsigned int AD_power_result = 0;
void ADC_Init(void)
AD_PORT &= ~(1<
SFIOR = 0x00; //连续转换模式
ADCSRA = (1<
#pragma interrupt_handler ADC_ISR:15
void ADC_ISR(void)
unsigned int temp = 0;
static unsigned int sum = 0;
static unsigned char cnt = 0;
static unsigned char AD_status = 0;
if (cnt == 0) //切换通道时第一个数据必须舍弃
cnt = 1;
ADCSR|=(1<
return;
temp = ADCL;
temp |= (unsigned int)ADCH<<8;
sum += temp;
switch(AD_status)
case 0:
if (++cnt > HOT_SAMP_CNT)
AD_status++;
ADMUX = (1<
cnt = 0;
sum = 0;
break;
case 1:
if (++cnt > MIX_SAMP_CNT)
AD_status++;
ADMUX = (1<
cnt = 0;
sum = 0;
break;
case 2: //电源电压
if (++cnt > POWER_SAMP_CNT)
AD_status = 1;
ADMUX = (1<
cnt = 0;
sum = 0;
AD_READY = 1;
ADCSR &= ~(1<
return;
break;
ADCSR|=(1<
unsigned int Res_Matrixing_Temper(unsigned int temp)
float Rt = 0;
float T_inv = 0;
float temper = 0;
Rt = (float)50000*temp/(1024-temp);
T_inv = log(Rt/50000)/3950 + 1/298.15;
temper = (1/T_inv -273.15)*10 + 0.5;
return ((unsigned int)temper);
void get_AD_result(void)
unsigned int t1 = 0;
float T_inv = 0;
float Rt = 0;
float temp = 0;
if (AD_READY == 1)
AD_READY = 0;
t1 = Res_Matrixing_Temper(AD_hot_result);
buf[0] = t1/100;
buf[1] = t1/10%10;
buf[2] = t1%10;
t1 = Res_Matrixing_Temper(AD_mix_result);
buf[3] = t1/100;
buf[4] = t1/10%10;
buf[5] = t1%10;
