//------------2_8数码管键调时带小数点功能
#include
#define uchar unsigned char
#define uint unsigned int
#define P0_1 PORTA |= (1<<0)
#define P0_0 PORTA &=~ (1<<0)
#define P1_1 PORTA |= (1<<1)
#define P1_0 PORTA &=~ (1<<1)
#define P2_1 PORTA |= (1<<2)
#define P2_0 PORTA &=~ (1<<2)
#define P3_1 PORTA |= (1<<3)
#define P3_0 PORTA &=~ (1<<3)
#define P4_1 PORTA |= (1<<4)
#define P4_0 PORTA &=~ (1<<4)
#define P5_1 PORTA |= (1<<5)
#define P5_0 PORTA &=~ (1<<5)
#define P6_1 PORTA |= (1<<6)
#define P6_0 PORTA &=~ (1<<6)
#define P7_1 PORTA |= (1<<7)
#define P7_0 PORTA &=~ (1<<7)
uchar i,m,h;
uint j;
uchar led_discode[]={0xc0,0xf9,0xa4,0xb0,0x99,
0x92,0x82,0xf8,0x80,0x90,0xbf,0xef,}; //共阳数码管数字码
void delay(uint mS) //微秒
uchar x,y;
for(x=0;x
void init(void) //初始化PORUT口
DDRA=0XFF; //LED IO口设为输出
PORTA=0X00;
DDRB |=0X10; //PB4设为输出
PORTB|=0X10; //关闭PB4外接的LED
DDRC=0XFF; //数码管段选设为输出
PORTC=0X00;
DDRF |=0X03; //LED及数码管锁存IO口设为输出
PORTF|=0X0E;
PORTF&=0xF7; //锁存数据关闭数码管
DDRD=0;//全部设为输入
PORTD=0xff;//全部上拉
PIND=0xff;//设初始值
void playh(uchar h)
PORTC = led_discode[h/10] ;
P0_1;
delay(1);
P0_0;
PORTC =tablee[h%10];
P1_1;
delay(1);
P1_0;
PORTC = led_discode[10] ;
P2_1;
delay(1);
P2_0;
void key1(void)
if(PIND == 0xfe) //按键扫描函数----------加键
delay(5);
if(PIND == 0xfe)
while(PIND == 0xfe);
m++;
void key2(void)
if(PIND == 0xfd) //按键扫描函数----------减键
delay(5);
if(PIND == 0xfd)
while(PIND == 0xfd) play(i);
h++;
void main (viod)
init() ;
while(1)
key1();
key2();
j=300;
while(j--)
play(i); //显示函数
i++;
if(i==60)
i=0; //如果秒计满60,将秒计数变量清0
m++; //分钟计数变量加1
if(m == 60)
m=0; //如果分钟计满60,将分钟计数变量清0
h++; //小时计数变量加1
if(h == 24)
h=0; //如果小时计满24,将小时计数变量清0
