主机:WIN7
开发环境:MDK4.23
MCU:STM32F103CBT6
源代码:
配置:
//---------------------串口功能配置--------------------- //打开串口对应的外设时钟 RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 , ENABLE); //启动DMA时钟 RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE); //DMA发送中断设置 NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel4_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 3; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); //DMA1通道4配置 DMA_DeInit(DMA1_Channel4); //外设地址 DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)(&USART1->DR); //内存地址 DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)Uart_Send_Buffer; //dma传输方向单向 DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST; //设置DMA在传输时缓冲区的长度 DMA_InitStructure.DMA_BufferSize = 100; //设置DMA的外设递增模式,一个外设 DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; //设置DMA的内存递增模式 DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; //外设数据字长 DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte; //内存数据字长 DMA_InitStructure.DMA_MemoryDataSize = DMA_PeripheralDataSize_Byte; //设置DMA的传输模式 DMA_InitStructure.DMA_Mode = DMA_Mode_Normal; //设置DMA的优先级别 DMA_InitStructure.DMA_Priority = DMA_Priority_High; //设置DMA的2个memory中的变量互相访问 DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; DMA_Init(DMA1_Channel4,&DMA_InitStructure); DMA_ITConfig(DMA1_Channel4,DMA_IT_TC,ENABLE); //使能通道4 //DMA_Cmd(DMA1_Channel4, ENABLE); //初始化参数 //USART_InitStructure.USART_BaudRate = DEFAULT_BAUD; USART_InitStructure.USART_WordLength = USART_WordLength_8b; USART_InitStructure.USART_StopBits = USART_StopBits_1; USART_InitStructure.USART_Parity = USART_Parity_No; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; USART_InitStructure.USART_BaudRate = DEFAULT_BAUD; //初始化串口 USART_Init(USART1,&USART_InitStructure); //TXE发送中断,TC传输完成中断,RXNE接收中断,PE奇偶错误中断,可以是多个 USART_ITConfig(USART1,USART_IT_RXNE,ENABLE); //配置UART1中断 NVIC_PriorityGroupConfig(NVIC_PriorityGroup_3); NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; //通道设置为串口1中断 NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2; //中断占先等级0 NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1; //中断响应优先级0 NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //打开中断 NVIC_Init(&NVIC_InitStructure); //初始化 //采用DMA方式发送 USART_DMACmd(USART1,USART_DMAReq_Tx,ENABLE); //启动串口 USART_Cmd(USART1, ENABLE); //设置IO口时钟 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO, ENABLE); //串口1的管脚初始化 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; //管脚9 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz; //选择GPIO响应速度 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出 GPIO_Init(GPIOA, &GPIO_InitStructure); //TX初始化 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; //管脚10 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz; //选择GPIO响应速度 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //浮空输入 GPIO_Init(GPIOA, &GPIO_InitStructure); //RX初始化 //设置IO口时钟 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB | RCC_APB2Periph_AFIO, ENABLE); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0; //管脚9 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz; //选择GPIO响应速度 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出
//串口1DMA方式发送中断 void DMA1_Channel4_IRQHandler(void) { //清除标志位 DMA_ClearFlag(DMA1_FLAG_TC4); //DMA_ClearITPendingBit(DMA1_FLAG_TC4); //DMA1->IFCR |= DMA1_FLAG_TC4; //关闭DMA DMA_Cmd(DMA1_Channel4,DISABLE); //DMA1_Channel4->CCR &= ~(1<<0); //允许再次发送 Flag_Uart_Send = 0; }
//串口DMA发送测试 Uart_Send_Buffer[0] = 1; Uart_Send_Buffer[1] = 2; Uart_Send_Buffer[2] = 3; Uart_Send_Buffer[3] = 4; Uart_Send_Buffer[4] = 5; i = 1; while (1) { //检查串口是否可以发送 while (Flag_Uart_Send); Flag_Uart_Send = 1; //设置传输数据长度 DMA_SetCurrDataCounter(DMA1_Channel4,i); //打开DMA DMA_Cmd(DMA1_Channel4,ENABLE); i++; if (i > 5) { i = 1; } }
