virt_net.c驱动:
// 参考 drivers\net\cs89x0.c
#include "linux/module.h"
#include "linux/errno.h"
#include "linux/netdevice.h"
#include "linux/etherdevice.h"
#include "linux/kernel.h"
#include "linux/types.h"
#include "linux/fcntl.h"
#include "linux/interrupt.h"
#include "linux/ioport.h"
#include "linux/in.h"
#include "linux/skbuff.h"
#include "linux/slab.h"
#include "linux/spinlock.h"
#include "linux/string.h"
#include "linux/init.h"
#include "linux/bitops.h"
#include "linux/delay.h"
#include "linux/ip.h"
#include "asm/system.h"
#include "asm/io.h"
#include "asm/irq.h"
static struct net_device *vnet_dev;
static void emulator_rx_packet(struct sk_buff *skb, struct net_device *dev)
// 参考LDD3
unsigned char *type;
struct iphdr *ih;
__be32 *saddr, *daddr, tmp;
unsigned char tmp_dev_addr[ETH_ALEN];
struct ethhdr *ethhdr;
struct sk_buff *rx_skb;
// 从硬件读出/保存数据
// 对调"源/目的"的mac地址
ethhdr = (struct ethhdr *)skb->data;
memcpy(tmp_dev_addr, ethhdr->h_dest, ETH_ALEN);
memcpy(ethhdr->h_dest, ethhdr->h_source, ETH_ALEN);
memcpy(ethhdr->h_source, tmp_dev_addr, ETH_ALEN);
// 对调"源/目的"的ip地址
ih = (struct iphdr *)(skb->data + sizeof(struct ethhdr));
saddr = &ih->saddr;
daddr = &ih->daddr;
tmp = *saddr;
*saddr = *daddr;
*daddr = tmp;
//((u8 *)saddr)[2] ^= 1; // change the third octet (class C)
//((u8 *)daddr)[2] ^= 1;
type = skb->data + sizeof(struct ethhdr) + sizeof(struct iphdr);
//printk("tx package type = x\n", *type);
// 修改类型, 原来0x8表示ping
*type = 0; // 0表示reply
ih->check = 0; // and rebuild the checksum (ip needs it)
ih->check = ip_fast_csum((unsigned char *)ih,ih->ihl);
// 构造一个sk_buff
rx_skb = dev_alloc_skb(skb->len + 2);
skb_reserve(rx_skb, 2); // align IP on 16B boundary
memcpy(skb_put(rx_skb, skb->len), skb->data, skb->len);
// Write metadata, and then pass to the receive level
rx_skb->dev = dev;
rx_skb->protocol = eth_type_trans(rx_skb, dev);
rx_skb->ip_summed = CHECKSUM_UNNECESSARY; // don't check it
dev->stats.rx_packets++;
dev->stats.rx_bytes += skb->len;
// 提交sk_buff
netif_rx(rx_skb);
static int virt_net_send_packet(struct sk_buff *skb, struct net_device *dev)
static int cnt = 0;
printk("virt_net_send_packet cnt = %d\n", ++cnt);
// 对于真实的网卡, 把skb里的数据通过网卡发送出去
netif_stop_queue(dev); // 停止该网卡的队列
// ...... // 把skb的数据写入网卡
// 构造一个假的sk_buff,上报
emulator_rx_packet(skb, dev);
dev_kfree_skb (skb); // 释放skb
netif_wake_queue(dev); // 数据全部发送出去后,唤醒网卡的队列
// 更新统计信息
dev->stats.tx_packets++;
dev->stats.tx_bytes += skb->len;
return 0;
static const struct net_device_ops virt_netdev_ops = {
.ndo_start_xmit = virt_net_send_packet,
static int virt_net_init(void)
// 1. 分配一个net_device结构体
vnet_dev = alloc_netdev(0, "vnet%d", ether_setup); // alloc_etherdev
// 2. 设置
vnet_dev->netdev_ops = &virt_netdev_ops;
// 设置MAC地址
vnet_dev->dev_addr[0] = 0x08;
vnet_dev->dev_addr[1] = 0x89;
vnet_dev->dev_addr[2] = 0x89;
vnet_dev->dev_addr[3] = 0x89;
vnet_dev->dev_addr[4] = 0x89;
vnet_dev->dev_addr[5] = 0x11;
// 设置下面两项才能ping通
vnet_dev->flags |= IFF_NOARP;
vnet_dev->features |= NETIF_F_NO_CSUM;
// 3. 注册
//register_netdevice(vnet_dev);
register_netdev(vnet_dev);
return 0;
static void virt_net_exit(void)
unregister_netdev(vnet_dev);
free_netdev(vnet_dev);
module_init(virt_net_init);
module_exit(virt_net_exit);
MODULE_AUTHOR("thisway.diy@163.com,17653039@qq.com");
MODULE_LICENSE("GPL");
