#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#define DEVICE_NAME "led1"
unsigned long GPIOK_VA_BASE ;
#define GPIOK_CON0 GPIOK_VA_BASE
#define GPIOK_CON1 GPIOK_VA_BASE+0X4
#define GPIOK_DAT GPIOK_VA_BASE+ 0X8
#define GPIOK_PUD GPIOK_VA_BASE +0XC
#define GPIOK_PA_BASE 0X7F008800
struct resource led_resource = {
.name = "led io-mem ",
.start = GPIOK_PA_BASE,
.end = GPIOK_PA_BASE +0X10,
.flags = IORESOURCE_MEM,
static void led_pin_setup(void)
unsigned long start = led_resource.start;
unsigned long size = led_resource.end - led_resource.start;
unsigned long tmp;
request_mem_region(start,size,led_resource.name);
GPIOK_VA_BASE = (unsigned long)ioremap(start,size);
printk ("<1> [GPIOK_VA_BASE = 0x%lx]n", GPIOK_VA_BASE);
tmp = readl(GPIOK_CON0);
tmp = (tmp & ~(0xffffu<<16))|(0x1111u<<16);
writel(tmp,GPIOK_CON0);
tmp = readl(GPIOK_DAT);
tmp |= (0xf <<4);
writel(tmp,GPIOK_DAT);
static void led_pin_release(void)
iounmap((void*)GPIOK_VA_BASE);
release_mem_region(led_resource.start,led_resource.end - led_resource.start);
static unsigned long led_getdata(void)
return ((readl(GPIOK_DAT)>>4)& 0XF);
static void led_setdata(int data)
unsigned long temp;
temp = readl(GPIOK_DAT);
temp = ~(0xF<<4) | ((data&0xF)<<4);
writel(temp,GPIOK_DAT);
static ssize_t led_read(struct file *filp, char __user *buf, size_t size, loff_t *ppos)
int ret = 0;
char buffer[1];
memset(buffer,0,sizeof(buffer));
buffer[0] = (char)led_getdata() ;
if(copy_to_user(buf,buffer,size))
ret = -EFAULT;
return size;
static ssize_t led_write(struct file *flip,const char __user *buf,size_t size,loff_t *ppos)
int ret = 0;
unsigned long buffer[1];
if(copy_from_user(buffer,buf,size))
printk("errorn");
ret = -EFAULT;
else{
led_setdata(0x00);
led_setdata((int )buffer[0]);
return ret;
static struct file_operations dev_fops ={
.owner = THIS_MODULE,
.read = led_read,
.write = led_write,
static struct miscdevice misc ={
.minor = MISC_DYNAMIC_MINOR,
.name = DEVICE_NAME,
.fops = &dev_fops,
static int __init dev_init(void)
int ret;
led_pin_setup();
ret = misc_register(&misc);
printk(DEVICE_NAME"initialize minor =%dn",misc.minor);
return ret;
static void __exit dev_exit(void)
led_pin_release();
misc_deregister(&misc);
module_init(dev_init);
module_exit(dev_exit);
MODULE_LICENSE("GPL");
MODULE_AUTHOR("GOAT.ZHOU");
以上的是led的驱动文件,以write 向led里写数据,read读取led的状态。
以下的是测试程序 led_app.c
#include
#include
#include
#include
#include
#include
#include
char binstr_to_int(char *binstr)
char ret = 0, i = 0;
char bnum[5];
memset(bnum, '0', 4);
int len = strlen(binstr);
if (len > 4)
strcpy(bnum, binstr+len-4);
else
strcpy(bnum+4-len, binstr);
for (i=0; i<4; i++) {
ret <<= 1;
ret += (bnum[i]=='0'? 1: 0);
return ret;
int main(int argc, char *argv[])
int fd;
unsigned char buff[1];
fd = open("/dev/led1",O_RDWR);
if(fd == -1){
printf("open dev error");
_exit(EXIT_FAILURE);
buff[0] = binstr_to_int(argv[1]);
write(fd,buff,sizeof(buff));
memset(buff,0,sizeof(buff));
printf("%dn", read(fd,buff,sizeof(buff)));
printf("%d",(int)buff[0]);
close(fd);
return 0;
