#include
#define KEYPORT P1
#include "./delay/delay.h"
sbit seg_select = P2^0; //段选
sbit bit_select = P2^1; //位选
#define SEGPORT P0
unsigned char segdata[10] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
unsigned char bitdata[8] = {0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
unsigned char TempData[2];
void display(void)
static unsigned char i = 0;
SEGPORT = 0x0; //消除重影
seg_select = 1;
seg_select = 0;
SEGPORT = 0xff;
bit_select = 1;
bit_select = 0;
SEGPORT = TempData[i];
seg_select = 1;
seg_select = 0;
SEGPORT = bitdata[i];
bit_select = 1;
bit_select = 0;
i++;
if(2 == i)
i = 0;
void timer0_init(void) //中断函数
EA = 1; //打开总中断
TMOD |= 0x01; //设置定时器工作方式
TH0 = (65536 - 2000) / 256;
TL0 = (65536 - 2000) % 256;
ET0 = 1; //打开定时器中断允许
TR0 = 1;
void timer0_isr(void) interrupt 1 //中断服务程序
display();
unsigned char key_scan(void)
unsigned char keyvalue;
KEYPORT = 0xf0;
if(0xf0 != KEYPORT) // 有按键按下
delay_ms(10);
if(0xf0 != KEYPORT) //确实有按键按下
//KEYPORT &= 0xfo;
KEYPORT = 0xfe;
if(0xfe != KEYPORT)
keyvalue = KEYPORT;
while(0xfe != KEYPORT); //有按键抬起
delay_ms(10);
while(0xfe != KEYPORT); //确实有按键抬起
return keyvalue;
KEYPORT = 0xfd;
if(0xfd != KEYPORT)
KEYPORT = 0xfb;
if(0xfb != KEYPORT)
KEYPORT = 0xf7;
if(0xf7 != KEYPORT)
return 0xff;
unsigned key_prc()
unsigned char keynum;
keynum = key_scan();
switch(keynum)
case 0x7e: return 0; break;
case 0xbe: return 1; break;
case 0xde: return 2; break;
case 0xee: return 3; break;
default: return 0xff; break;
void main()
unsigned char key;
timer0_init();
while(1)
key = key_prc();
if(0xff != key)
TempData[0] = segdata[key / 16];
TempData[1] = segdata[key % 16];
/*********delay.c*******/
void delay_us(unsigned char t)
while(--t);
void delay_ms(unsigned char t)
while(t--)
delay_us(245);
delay_us(245);
void delay_s(unsigned char t)
while(t--)
delay_ms(200);
delay_ms(200);
delay_ms(200);
delay_ms(200);
delay_ms(200);
/*******delay.h******/
#ifndef _DELAY_H_
#define _DELAY_H_
extern void delay_us(unsigned char t);
extern void delay_ms(unsigned char t);
extern void delay_s(unsigned char t);
#endif
