#define uchar unsigned char
#define uint unsigned int
unsigned char code smg_du[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x00};
unsigned char code smg_we[]={0x08,0x18,0x28,0x38,0x48,0x58,0x68,0x78};
uchar irtime;
uchar startflag;
uchar irdata[33];
uchar bitnum;
uchar irreceok;
uchar ircode[4];
uchar irprosok;
uchar disp[8];
//延时函数,在12MHz的晶振频率下
//大约50us的延时
void delay_50us(uint t)
uchar j;
for(;t>0;t--)
for(j=19;j>0;j--);
//延时函数,在12MHz的晶振频率下
//大约50ms的延时
void delay_50ms(uint t)
uint j;
for(;t>0;t--)
for(j=6245;j>0;j--);
void timer0init(void)
TMOD=0x02;
TH0=0x00;
TL0=0x00;
ET0=1;
EA=1;
TR0=1;
void int0init(void)
IT0=1;
EX0=1;
EA=1;
void irwork(void)
disp[0]=ircode[0]/16;
disp[1]=ircode[0]%16;
disp[2]=ircode[1]/16;
disp[3]=ircode[1]%16;
disp[4]=ircode[2]/16;
disp[5]=ircode[2]%16;
disp[6]=ircode[3]/16;
disp[7]=ircode[3]%16;
void display(void)
uchar i;
for(i=0;i<8;i++)
P1=smg_du[disp[i]];
P2=smg_we[i];
delay_50us(20);
void irpros(void)
uchar k,i,j;
uchar value;
k=1;
for(j=0;j<4;j++)
for(i=0;i<8;i++)
value=value>>1;
if(irdata[k]>6)
value=value | 0x80;
k++;
ircode[j]=value;
irprosok=1;
void main()
timer0init();
int0init();
while(1)
if(irreceok)
irpros();
irreceok=0;
if(irprosok)
irwork();
irprosok=0;
display();
void timer0 () interrupt 1
irtime++;
void int0 () interrupt 0
if(startflag)
if(irtime>32) //检测引导码
bitnum=0;
irdata[bitnum]=irtime;
irtime=0;
bitnum++;
if(bitnum==33)
bitnum=0;
irreceok=1;
else
startflag=1;
irtime=0;
