bsp_exti.h
#ifndef __EXTI_H
#define __EXTI_H
#include "stm32f4xx.h"
//引脚定义
#define KEY1_INT_GPIO_PORT GPIOA
#define KEY1_INT_GPIO_CLK RCC_AHB1Periph_GPIOA
#define KEY1_INT_GPIO_PIN GPIO_Pin_0
#define KEY1_INT_EXTI_PORTSOURCE EXTI_PortSourceGPIOA
#define KEY1_INT_EXTI_PINSOURCE EXTI_PinSource0
#define KEY1_INT_EXTI_LINE EXTI_Line0
#define KEY1_INT_EXTI_IRQ EXTI0_IRQn
#define KEY1_IRQHandler EXTI0_IRQHandler
#define KEY2_INT_GPIO_PORT GPIOC
#define KEY2_INT_GPIO_CLK RCC_AHB1Periph_GPIOC
#define KEY2_INT_GPIO_PIN GPIO_Pin_13
#define KEY2_INT_EXTI_PORTSOURCE EXTI_PortSourceGPIOC
#define KEY2_INT_EXTI_PINSOURCE EXTI_PinSource13
#define KEY2_INT_EXTI_LINE EXTI_Line13
#define KEY2_INT_EXTI_IRQ EXTI15_10_IRQn
#define KEY2_IRQHandler EXTI15_10_IRQHandler
void EXTI_Key_Config(void); //中断按键配置
#endif /* __EXTI_H */
/*********************************************END OF FILE**********************/
bsp.exti.c
#include "./key/bsp_exti.h"
* 配置嵌套向量中断控制器
static void NVIC_Configuration(void)
/* 创建一个NVIC中断控制器 */
NVIC_InitTypeDef NVIC_InitStructure;
/* 配置NVIC为优先级组1 */
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
/* 配置抢占优先级:1 */
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
/* 配置子优先级:1 */
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
/* 使能中断通道 */
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
/* 配置中断源:按键1 */
NVIC_InitStructure.NVIC_IRQChannel = KEY1_INT_EXTI_IRQ;
NVIC_Init(&NVIC_InitStructure);
/* 配置中断源:按键2 */
NVIC_InitStructure.NVIC_IRQChannel = KEY2_INT_EXTI_IRQ;
* 配置PA0为线中断口,并设置中断优先级
EXTI_InitTypeDef EXTI_InitStructure;
/* 开启按键GPIO的时钟 */
RCC_AHB1PeriphClockCmd(KEY1_INT_GPIO_CLK|KEY2_INT_GPIO_CLK ,ENABLE);
/* 是能SYSCFG时钟 */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE);
/* 配置NVIC */
NVIC_Configuration();
/* 选择按键1的引脚 */
GPIO_InitStructure.GPIO_Pin = KEY1_INT_GPIO_PIN;
/* 设置引脚为输入模式 */
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
/* 设置引脚不上拉也不下拉 */
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
/* 使用上面的结构体初始化按键1 */
GPIO_Init(KEY1_INT_GPIO_PORT, &GPIO_InitStructure);
/* 连接EXIT中断源到key1引脚 */
SYSCFG_EXTILineConfig(KEY1_INT_EXTI_PORTSOURCE,KEY1_INT_EXTI_PINSOURCE);
/* 选择EXIT中断源 */
EXTI_InitStructure.EXTI_Line = KEY1_INT_EXTI_LINE;
/* 中断模式 */
EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
/* 下降沿触发 */
EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising;
/* 使能中断/事件线 */
EXTI_InitStructure.EXTI_LineCmd = ENABLE;
/* 使用上面结构体初始化中断 */
EXTI_Init(&EXTI_InitStructure);
/* 选择按键2的引脚 */
GPIO_InitStructure.GPIO_Pin = KEY2_INT_GPIO_PIN;
/* 使用上面的结构体初始化按键2 */
GPIO_Init(KEY2_INT_GPIO_PORT, &GPIO_InitStructure);
/* 连接EXIT中断源到key2引脚 */
SYSCFG_EXTILineConfig(KEY2_INT_EXTI_PORTSOURCE,KEY2_INT_EXTI_PINSOURCE);
/* 选择EXIT中断源 */
EXTI_InitStructure.EXTI_Line = KEY2_INT_EXTI_LINE;
/* 上升沿触发 */
EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
