ORG 0000H LJMP START ORG 000BH INC 20H ;中断服务,中断计数器加1 MOV TH0,#0D8H MOV TL0,#0EFH ;12M晶振,形成10毫秒中断 RETI START: MOV SP,#50H MOV TH0,#0D8H MOV TL0,#0EFH MOV TMOD,#01H MOV IE,#82H Mu: Mov p3,#0ffh SETB P1.2 lcall key MUSIC0: NOP MOV 20H,#00H ;中断计数器清0 MOV B,#00H ;表序号清0 MUSIC1: NOP CLR A MOVC A,@A+DPTR ;查表取代码 MOV P3,A JZ MU JZ END0 ;是00H,则结束 CJNE A,#0FFH,MUSIC5 LJMP MUSIC3 MUSIC5: NOP MOV R6,A INC DPTR MOV A,B MOVC A,@A+DPTR ;取节拍代码送R7 MOV R7,A SETB TR0 ;启动计数 MUSIC2: NOP CPL P1.2 MOV A,R6 MOV R3,A LCALL DEL MOV A,R7 CJNE A,20H,MUSIC2 ;中断计数器(20H)=R7否? ;不等,则继续循环 MOV 20H,#00H ;等于,则取下一代码 INC DPTR ; INC B LJMP MUSIC1 MUSIC3: NOP CLR TR0 ;休止100毫秒 MOV R2,#0DH MUSIC4: NOP MOV R3,#0FFH LCALL DEL DJNZ R2,MUSIC4 INC DPTR LJMP MUSIC1 END0: NOP MOV R2,#64H ;歌曲结束,延时1秒后继续 MUSIC6: MOV R3,#00H LCALL DEL DJNZ R2,MUSIC6 LJMP mu DEL: NOP DEL3: MOV R4,#02H DEL4: NOP DJNZ R4,DEL4 NOP DJNZ R3,DEL3 RET Key: Key1: Mov a,P2 Mov P0,a Cjne a,#0feh,key2 Mov dptr,#mu_tab1;;表头地址送DPTR Ljmp MUSIC0 Key2: Mov a,P2 Mov P0,a Cjne a,#0fdh,key3 Mov dptr,#mu_tab2 ;;表头地址送DPTR Ljmp MUSIC0 Key3: Sjmp key NOP Mu_tab1: db 26h,20h,20h,20h,20h,20h,26h,10h,20h,10h,20h,80h,26h,20h,30h,20h db 30h,20h,39h,10h,30h,10h,30h,80h,26h,20h,20h,20h,20h,20h,1ch,20h db 20h,80h,2bh,20h,26h,20h,20h,20h,2bh,10h,26h,10h,2bh,80h,26h,20h db 30h,20h,30h,20h,39h,10h,26h,10h,26h,60h,40h,10h,39h,10h,26h,20h db 30h,20h,30h,20h,39h,10h,26h,10h,26h,80h,26h,20h,2bh,10h,2bh,10h db 2bh,20h,30h,10h,39h,10h,26h,10h,2bh,10h,2bh,20h,2bh,40h,40h,20h db 20h,10h,20h,10h,2bh,10h,26h,30h,30h,80h,18h,20h,18h,20h,26h,20h db 20h,20h,20h,40h,26h,20h,2bh,20h,30h,20h,30h,20h,1ch,20h,20h,20h db 20h,80h,1ch,20h,1ch,20h,1ch,20h,30h,20h,30h,60h,39h,10h,30h,10h db 20h,20h,2bh,10h,26h,10h,2bh,10h,26h,10h,26h,10h,2bh,10h,2bh,80h db 18h,20h,18h,20h,26h,20h,20h,20h,20h,60h,26h,10h,2bh,20h,30h,20h db 30h,20h,1ch,20h,20h,20h,20h,80h,26h,20h,30h,10h,30h,10h,30h,20h db 39h,20h,26h,10h,2bh,10h,2bh,20h,2bh,40h,40h,10h,40h,10h,20h,10h db 20h,10h,2bh,10h,26h,30h,30h,80h,00H mu_tab2: DB 18H, 30H, 1CH, 10H DB 20H, 40H, 1CH, 10H DB 18H, 10H, 20H, 10H DB 1CH, 10H, 18H, 40H DB 1CH, 20H, 20H, 20H DB 1CH, 20H, 18H, 20H DB 20H, 80H, 0FFH, 20H DB 30H, 1CH, 10H , 18H DB 20H, 15H, 20H , 1CH DB 20H, 20H, 20H , 26H DB 40H, 20H , 20H , 2BH DB 20H, 26H, 20H , 20H DB 20H, 30H , 80H , 0FFH DB 20H, 20H, 1CH , 10H DB 18H, 10H, 20H , 20H DB 26H, 20H , 2BH , 20H DB 30H, 20H , 2BH , 40H DB 20H, 20H , 1CH , 10H DB 18H, 10H, 20H, 20H DB 26H, 20H , 2BH, 20H DB 30H, 20H, 2BH , 40H DB 20H, 30H, 1CH , 10H DB 18H, 20H , 15H , 20H DB 1CH, 20H , 20H , 20H DB 26H, 40H, 20H , 20H DB 2BH, 20H, 26H , 20H DB 20H, 20H, 30H , 80H DB 20H, 30H, 1CH , 10H DB 20H, 10H, 1CH , 10H DB 20H, 20H, 26H , 20H DB 2BH, 20H, 30H , 20H DB 2BH, 40H, 20H , 15H DB 1FH, 05H, 20H , 10H DB 1CH, 10H, 20H , 20H DB 26H, 20H, 2BH , 20H DB 30H, 20H, 2BH , 40H DB 20H, 30H, 1CH , 10H DB 18H, 20H , 15H , 20H DB 1CH, 20H , 20H , 20H DB 26H, 40H, 20H , 20H DB 2BH, 20H, 26H , 20H DB 20H, 20H, 30H, 30H DB 20H, 30H, 1CH, 10H DB 18H, 40H, 1CH, 20H DB 20H, 20H, 26H, 40H DB 13H, 60H, 18H , 20H DB 15H, 40H, 13H , 40H DB 18H, 80H, 00H END
