产品说明
描述
Dolphin is a Frequency Hopping Spread Spectrum (FHSS) Wireless UART chipset for the 902-928 MHz US ISM Band. The Dolphin chipset consists of the TRF6903 RF transciever and the digital baseband ASIC DBB03A and comes FCC pre-certified.
DOLPHIN-HP-EVM is the evaluation kit for the High Power Dolphin chipset. With this hardware the user is able to demonstrate, test, and evaluate two way point-to-point communication. The evaluation kit contains:
Two High Power daughter cards
Two Interface cards
Two RS-232 Serial Cables to connect to a computer
Graphical evaluation software
All applicable literature and data sheet
To demonstrate the broADCast capability of the Dolphin chipset, an additional adder kit is available. Please see DOLPHIN-LP-ADDER for a low power adder kit, or DOLPHIN-HP-ADDER for a high power adder kit.
特性
Hardware Features:
Chipset Solution - TRF6903 RF Transceiver and DBB03 Digital Baseband ASIC (firmware in ROM-based program memory)
FHSS FSK operation in the 902-928 MHz US ISM band
Fastest frequency hopping solution available resulting in fast acquisition and less power consumption. (Channel lock time of 200µs; No calibration needed when frequency hopping)
Evaluation software or system micro can be used to evaluate/program the Dolphin chipset using a defined host-interface protocol
+23 dBm output Power
2.7-3.6 V operation
RF bit rate of 38.4 kbps
50 hopping channels and multiple hop tables
FCC pre-certified per testing at LS Compliance
