CNY17
Optocoupler.
A |1 +--+ 6| B
K |2 CNY17 5| C
|3 4| E
HDSP-L101, HDSP-L201, HDSP-5401, TC07-11
Common row anode 5x7 dot matrix LED display.
Col1 |1 +--+ 12| Row1
Row3 |2 11| Row2
Col2 |3 5x7 10| Col3
Row5 |4 LED 9| Row4
Row6 |5 8| Col5
Row7 |6 7| Col4
HDSP-L103, HDSP-L203, HDSP-5403
Common row cathode 5x7 dot matrix LED display.
Row1 |1 +--+ 12| Col5
Row2 |2 11| Row3
Col2 |3 5x7 10| Row4
Col1 |4 LED 9| Col4
Row6 |5 8| Row5
Row7 |6 7| Col3
TIL111, TIL112, TIL116, TIL117, TIL118, TIL124, TIL125, TIL126
Optocoupler.
A |1 +--+ 6| B
K |2 5| C
|3 4| E
TIL113, TIL119
Optocoupler with darlington transistor output configuration.
A |1 +--+ 6| B
K |2 5| C
|3 4| E
TIL192
Dual optocouplers.
1A |1 +--+ 8| 1C
1K |2 7| 1E
2A |3 TIL192 6| 2C
2K |4 5| 2E
TIL193
Quad optocouplers.
1A |1 +--+ 16| 1C
1K |2 15| 1E
2A |3 14| 2C
2K |4 TIL 13| 2E
3A |5 193 12| 3C
3K |6 11| 3E
4A |7 10| 4C
4K |8 9| 4E
TIL198
Dual optocouplers with darlington outputs.
1A |1 +--+ 8| 1C
1K |2 7| 1E
2A |3 TIL198 6| 2C
2K |4 5| 2E
TIL199
Quad optocouplers with darlington outputs.
1A |1 +--+ 16| 1C
1K |2 15| 1E
2A |3 14| 2C
2K |4 TIL 13| 2E
3A |5 199 12| 3C
3K |6 11| 3E
4A |7 10| 4C
4K |8 9| 4E
TIL308
7-segment display with built-in latch and driver, left hand decimal point.
Displays 0-9,A,C,E,F with D as blank, and B as dash/minus sign.
Qb |1 +--+ 16| VCC
Qc |2 15| D0
Qd |3 14| Qdp
Qa |4 TIL 13| /LT
/LE |5 308 12| Ddp
D2 |6 11| /BL
D3 |7 10| D1
GND |8 9|
TIL311
Dot-matrix hexadecimal display with built-in latch and driver, left and right hand decimal point.
VDD is the LED supply, usually the same as VCC and must be 5V. DPL and DPR are direct connections to the catodes of the decimal points (no drivers, no current limiter in between).
VCC |1 +--+ 14| VDD
D1 |2 13| D2
D0 |3 12| D3
DPL |4 TIL |
/LE |5 311 10| DPR
GND |7 8| BL
HDSP-M401, HDSP-4501, HDSP-5101
Col1 |1 +--+ 18| Row1
Row3 |3 16| Row2
Col2 |4 15| Col4
| 5x7 LED |
Row5 |6 matrix 13| Row4
Row6 |8 11| Col5
Row7 |9 10| Col3
HDSP-M403, HDSP-4503, HDSP-5103
Row1 |1 +--+ 18| Col5
Col3 |3 16| Row2
Row3 |4 15| Row4
| 5x7 LED |
Col1 |6 matrix 13| Row5
Col2 |8 11| Col4
Row7 |9 10| Row6
