The LTC®3731H is a PolyPhase® synchronous step-down switching regulator controller that drives all N-channel external power MOSFET stages in a phase-lockable fixed frequency architecture. The LTC3731H is rated for operation up to 140 degree C junction temperature. The 3-phase controller drives its output stages with 120 degree uf020phase separation at frequencies up to 600kHz per phase to minimize the RMS current losses in both the input and output filter capacitors. The 3-phase technique effectively triples the fundamental frequency, improving transient response while operating each controller at an optimal frequency for efficiency and ease of thermal design. Light load efficiency is optimized by using a choice of output Stage Shedding or Burst Mode operation.
The precision reference supports output voltages from 0.6V to 6V. Current foldback provides protection for the external MOSFETs under short-circuit or overload conditions.Please refer to the LTC3731 data sheet for 0 C to 70 C and
–40 C to 85 C rated versions.
LTC3731H主要特性:
■ 3-Phase Current Mode Controller with Onboard MOSFET Drivers
■ 5% Output Current Matching Optimizes Thermal Performance and Size of Inductors and MOSFETs
■ 2% VREF Accuracy Over Temperature up to 140 C
■ Reduced Power Supply Induced Noise
