PowerPSoC Intelligent LED Driver:CY8CLED04G01,CY8CLED03G01,CY8CLED03D01, CY8CLED03D02, CY8CLED04D01, CY8CLED04D02
The PowerPSoC family incorporates programmable system-on-chip technology with the best in class power electronics controllers and switching devices to create easy to use power-system-on-chip solutions for lighting applications.
All PowerPSoC family devices are designed to replace traditional MCUs, system ICs, and the numerous discrete components that surround them. PowerPSoC devices feature high performance power electronics including 1A 2 MHz power FETs, hysteretic controllers, current sense amplifiers, and PrISM/PWM modulators to create a complete power electronics solution for LED power management. Configurable power, analog, digital, and interconnect circuitry enables a high level of integration in a host of industrial, commercial, and consumer LED lighting applications.
This architecture integrates programmable analog and digital blocks to enable the user to create customized peripheral configurations that match the requirements of each individual application. Additionally, the device includes a fast CPU, Flash program memory, SRAM data memory, and configurable I/O in a range of convenient pinouts and packages.
The PowerPSoC architecture, as illustrated in the block diagrams, comprises five main areas: PSoC core, digital system, analog system, system resources, and power peripherals which include power FETs, hysteretic controllers, current sense amplifiers,and PrISM/PWM modulators. Configurable global busing combines all the device resources into a complete custom system. The PowerPSoC family of devices have 10-port I/Os that connect to the global digital and analog interconnects, providing access to eight digital blocks and six analog blocks.
CY8CLED04D0x 主要特性:
■ Integrated Power Peripherals
Four internal 32V low side N-Channel power FETs
RDS(ON)C 0.5Ω for 1.0A devices
Up to 2 MHz configurable switching frequency
Four hysteretic controllers
Independently programmable upper and lower thresholds
Programmable minimum on/off timers
Four low side gate drivers with programmable drive strength
Four precision high side current sense amplifiers
Three 16-bit LED dimming modulators: PrISM, DMM, and PWM
Six fast response (100 ns) voltage comparators
Six 8-bit reference DACs
Built-in switching regulator eliminates external 5V supply
Multiple topologies including floating load buck, floating load buck-boost, and boost
■ M8C CPU Core
Processor speeds up to 24 MHz
■ Advanced Peripherals (PSoC® Blocks)
Capacitive sensing application capability
DMX512 interface
DALI interface
I2C master or slave
Full-duplex UARTs
Multiple SPI masters or slaves
Integrated temperature sensor
Up to 12-bit ADCs
6 to 12-bit incremental ADCs
Up to 9-bit DACs
Programmable gain amplifiers
Programmable filters and comparators
8 to 32-bit timers and counters
Complex peripherals by combining blocks
Configurable to all GPIO pins
■ Programmable Pin Configurations
25 mA sink on all GPIO and function pins
Pull up, pull down, high Z, strong, or open drain drive modes on all GPIO and function pins
Up to 10 analog inputs on GPIO
Two 30 mA analog outputs on GPIO
Configurable interrupt on all GPIO
■ Flexible On-chip Memory
16K Flash program storage 50,000 erase and write cycles
1K SRAM data storage
In-System Serial Programming (ISSP)
Partial Flash updates
Flexible protection modes
EEPROM emulation in Flash
■ Complete Development Tools
Free development software: PSoC Designer 5.0
Full featured, In-Circuit Emulator and Programmer
Full speed emulation
Complex breakpoint structure
128 kBytes trace memory
■ Visual Embedded Design
LED based express drivers
Binning compensation
Temperature feedback
CY8CLED04D0x应用:
Stage LED lighting
Architectural LED lighting
General purpose LED lighting
Automotive and emergency vehicle LED lighting
Landscape LED lighting
Display LED lighting
Effects LED lighting
Signage LED lighting
■ Device Options
CY8CLED04D0x
Four internal FETs with 0.5A and 1.0A options
Four external gate drivers
CY8CLED03D0x
Three internal FETs with 0.5A and 1.0A options
Three external gate drivers
CY8CLED04G01
CY8CLED03G01
■ 56-pin QFN Package
图1.CY8CLED04D0x PowerPSoC 架构方框图
图2.CY8CLED04D0x 逻辑方框图
