On Semi NCP3065 MR16 LED 1-5W驱动解决方案
On Semi公司的NCP3065是高达1.5A恒流开关稳压器,输入电压从3.0V到40V,反馈电压235mV,工作频率可调整到高达250kHz,逐个周期限流,主要用在汽车照明,大功率LED驱动器,恒流源已急低压LED照明.本文介绍NCP3065主要特性, 方框图, 典型降压应用电路, 降压演示板应用电路和材料清单, 升压演示板应用电路和材料清单,以及1-5W MR16 LED驱动GreenPoin解决方案框图,应用电路和材料清单.
NCP3065, NCV3065: Up to 1.5 A Constant Current Switching Regulator for LEDs The NCP3065 is a monolithic switching regulator designed to deliver constant current for powering high brightness LEDs. The device has a very low feedback voltage of 235 mV (nominal) which is used to regulate the average current of the LED string. In addition, the NCP3065 has a wide input voltage up to 40 V to allow it to operate from 12 Vac or 12 Vdc supplies commonly used for lighting applications as well as unregulated supplies such as Lead Acid batteries. The device can be configured in a controller topology with the addition of an external transistor to support higher LED currents beyond the 1.5 A rated switch current of the internal transistor. The NCP3065 switching regulator can be configured in StepDown (Buck) and StepUp (boost) topologies with a minimum number of external components.
NCP3065主要特性:
Integrated 1.5 A Switch
Input Voltage Range from 3.0 V to 40 V
Low Feedback Voltage of 235 mV
CyclebyCycle Current Limit
No Control Loop Compensation Required
Frequency of Operation Adjustable up to 250 kHz
Operation with All Ceramic Output Capacitors or No Output Capacitance
Analog and Digital PWM Dimming Capability
Internal Thermal Shutdown with Hysteresis
Automotive Version Available
NCP3065应用:
Automotive and Marine Lighting
High Power LED Driver
Constant Current Source
Low Voltage LED Lighting
(Landscape, Path, Solar, MR16 Replacement)
图1.NCP3065方框图
图2.NCP3065典型降压应用电路
图3.NCP3065降压演示板应用电路
材料清单(BOM):
