Cypress 公司的CY8CLED16 EZ-Color系列是HBLED控制器,支持高达16路LED通路,每路的分辨率高达32位.M8C处理器工作速度高达24MHz,工作电压3.0V-5.25V,材用片内的开关模式泵可使电压低至1.0V,工作温度从-40度到85度C. CY8CLED16具有灵活的接口,可编程的引脚配置,以及灵活的片上存储器,主要应用在LCD背景光,通用照明,建筑物照明,照相机/手机闪光等.本文介绍了CY8CLED16主要特性,方框图, 数字系统和模拟系统方框图, 4路LED演示板电路图和所用材料清单.
Cypress EZ-Color family of devices offers the ideal control solution for High Brightness LED applications requiring intelligent dimming control. EZ-Color devices combine the power and flexibility of PSoC (Programmable System-on-Chip™); with Cypress PrISM (precise illumination signal modulation) modulation technology providing lighting designers a fully customizable and integrated lighting solution platform.
The EZ-Color family supports up to 16 independent LED channels with up to 32 bits of resolution per channel, enabling lighting designers the flexibility to choose the LED array size and color quality. PSoC Express software, with lighting specific drivers, can significantly cut development time and simplify implementation of fixed color points through temperature and LED binning compensation. EZ-Colors virtually limitless analog
and digital customization allow for simple integration of features in addition to intelligent lighting, such as Battery Charging, Image Stabilization, and Motor Control during the development process. These features, along with Cypress best-in-class quality and design support, make EZ-Color the ideal choice for intelligent HB LED control applications.
CY8CLED16主要特性:
■ HB LED Controller
Configurable Dimmers Support up to 16 Independent LED Channels
8-32 Bits of Resolution per Channel
Dynamic Reconfiguration Enables LED Controller plus other Features; Battery
Charging, Motor Control…
■ Visual Embedded Design, PSoC Express
LED Based Express Drivers
• Binning Compensation
• Temperature Feedback
• DMX512
■ PrISM Modulation Technology
Reduces Radiated EMI
Reduces Low Frequency Blinking
■ Powerful Harvard Architecture Processor
M8C Processor Speeds to 24 MHz
3.0 to 5.25V Operating Voltage
Operating Voltages down to 1.0V using On-Chip Switch Mode Pump (SMP)
Industrial Temperature Range: -40℃ to +85℃
■ Programmable Pin Configurations
25 mA Sink on all GPIO
Pull up, Pull down, High Z, Strong, or Open Drain Drive Modes on all GPIO
Up to eight Analog Inputs on GPIO
Configurable Interrupt on all GPIO
■ Advanced Peripherals (PSoC Blocks)
16 Digital PSoC Blocks Provide:
• 8 to 32-Bit Timers, Counters, and PWMs
• Up to 2 Full-Duplex UART
• Multiple SPI™ Masters or Slaves
• Connectable to all GPIO Pins
12 Rail-to-Rail Analog PSoC Blocks Provide:
• Up to 14-Bit ADCs
• Up to 9-Bit DACs
• Programmable Gain Amplifiers
• Programmable Filters and Comparators
Complex Peripherals by Combining Blocks
■ Flexible On-Chip Memory
32K Flash Program Storage 50,000 Erase/Write Cycles
2K SRAM Data Storage
In-System Serial Programming (ISSP)
Partial Flash Updates
Flexible Protection Modes
EEPROM Emulation in Flash
■ Complete Development Tools
Free Development Software
• PSoC Designer™
• PSoC Express™
Full-Featured, In-Circuit Emulator and Programmer
Full Speed Emulation
Complex Breakpoint Structure
128 KBytes Trace Memory
CY8CLED16典型应用:
■ LCD Backlight
■ Large Signs
■ General Lighting
■ Architectural Lighting
■ Camera/Cell Phone Flash
■ Flashlights
图1.CY8CLED16方框图
图2.CY8CLED16数字系统方框图
图3.CY8CLED16模拟系统方框图
4路LED演示板
4 Channel LED Demo Board
Cypress pSOC controller based 4-Channel High Power LED Driver Board
图4.4路LED演示板电路图(1)
图5.4路LED演示板电路图(2)
图6.4路LED演示板电路图(3)
