1.编写驱动,主要为Lcd驱动和触摸屏驱动:
lcd驱动实现画点函数LCD2410_SetPixel(x,y,c)。对dm2410实验板上的lcd,左上为原点(0,0)
触摸屏驱动计算出触摸屏的坐标(x,y),对dm2410实验板上的触摸屏,左下为原点,但不一定是(0,0)
2.触摸屏校准:
测出左下最小坐标minX,minY和右上最大坐标maxX,maxY
如下填写GUITouchConf.h:
#define GUI_TOUCH_AD_LEFT minX
#define GUI_TOUCH_AD_TOP maxY
#define GUI_TOUCH_AD_RIGHT maxX
#define GUI_TOUCH_AD_BOTTOM minY
#define GUI_TOUCH_SWAP_XY 0
#define GUI_TOUCH_MIRROR_X 1
#define GUI_TOUCH_MIRROR_Y 1
3.如下填写GUIConf.h:
#define GUI_OS (1) /* Compile with multitasking support */
#define GUI_SUPPORT_TOUCH (1) /* Support a touch screen (req. win-manager) */
#define GUI_SUPPORT_UNICODE (1) /* Support mixed ASCII/UNICODE strings */
#define GUI_SUPPORT_CHINESE (1)
#define GUI_DEFAULT_FONT &GUI_Font6x8
#define GUI_ALLOC_SIZE 22500 /* Size of dynamic memory ... For WM and memory devices*/
#define GUI_WINSUPPORT 1 /* Window manager package available */
#define GUI_SUPPORT_MEMDEV 1 /* Memory devices available */
#define GUI_SUPPORT_AA 1
4.如下填写LCDConf.h:
#define LCD_XSIZE (800) /* X-resolution of LCD, Logical coor. */
#define LCD_YSIZE (480) /* Y-resolution of LCD, Logical coor. */
#define LCD_BITSPERPIXEL (16)
#define LCD_CONTROLLER 1
#define LCD_SWAP_RB_0 1
5.ucgui与lcd驱动函数的连接:
在LCDWin.c中,去掉无用的头文件包含。
#define SETPIXEL(x, y, c) LCD2410_SetPixel(x, y, c)
#define GETPIXEL(x, y) LCD2410_GetPixel(x,y)
即将“LCDSIM_XX”改成“LCD2410_XX”,这两个函数位于lcd驱动文件中。
6.某些编译器不会初始化全局变量,因此做如下事:
1)修改如下函数为:(位于GUICore.c)
static void _InitContext(GUI_CONTEXT* pContext) {
memset(pContext,0,sizeof(GUI_CONTEXT));//add
#if GUI_SUPPORT_MEMDEV
GUI_SelectLCD();
#else
LCD_SetClipRectMax();//LCD_L0_GetRect
#endif
pContext->pLCD_HL = &LCD_HL_APIList;
pContext->pAFont = GUI_DEFAULT_FONT;
pContext->pClipRect_HL = &GUI_Context.ClipRect;
pContext->PenSize = 1;
pContext->DrawMode = GUI_DRAWMODE_NORMAL;//add
pContext->TextMode = GUI_TEXTMODE_NORMAL;//add
pContext->TextAlign = GUI_TA_LEFT|GUI_TA_TOP;//add
pContext->AA_HiResEnable = 0;//add
/* Variables in WM module */
#if GUI_WINSUPPORT
pContext->hAWin = WM_GetDesktopWindow();
#endif
/* Variables in GUI_AA module */
pContext->AA_Factor = 3;
LCD_SetBkColor(GUI_DEFAULT_BKCOLOR);
LCD_SetColor(GUI_DEFAULT_COLOR);
2)自己编写如下函数:
void MyInit()
IsInitialized = 0;//MemDev
_IsInited = 0;//Win
WM__CreateFlags = 0;
GUI_CURSOR_pfTempHide = NULL;
GUI_Context.hDevData = 0;
WM__hCapture=0;
WM__hWinFocus=0;
WM_pfPollPID = 0;
WM_pfHandlePID = 0;
GUI_pfTimerExec = 0;
_KeyMsgCnt = 0;
该函数应在GUI_Init()调用之前调用。
7.由于没有加入ucos操作系统,自己编写如下函数模拟延时:
int ost = 0;
void My_X_Delay(int p)
int i = 0;
int j=0;
for(i=0; i
8.修改如下函数,接入lcd的初始化:(位于LCD.c)
int LCD_Init(void) {
int r;
GUI_DEBUG_LOG("\nLCD_Init...");
if ((r = LCD2410_Init()) != 0) //LCD2410_Init(),设置lcd寄存器
return r;
#if LCD_NUM_DISPLAYS > 1
if ((r = LCD_L0_1_Init()) != 0)
return r;
#endif
LCD_InitLUT();
/* Clear video memory */
LCD_SetDrawMode(GUI_DRAWMODE_REV);
LCD_FillRect(0,0, GUI_XMAX, GUI_YMAX);
LCD_SetDrawMode(0);
/* Switch LCD on */
LCD_On();
return 0;
9.如下修改GUI_X.c:
int GUI_X_GetTime(void)
return 0;
// return OSTimeGet();
void GUI_X_Delay(int ms)
// OSTimeDly(ms);
int i=0;
for(i=0; i
void GUI_X_ExecIdle(void) {
GUI_X_Delay(1);
void GUI_X_Unlock(void)
// OSSemPost(DispSem);
void GUI_X_Lock(void)
// U8 err;
// OSSemPend(DispSem, 0, &err);
U32 GUI_X_GetTaskId(void)
// if(bGUIInitialized){
// return ((INT32U)(OSTCBCur->OSTCBPrio)); /* < 64(è???ó??è??) */
// else{
return 100; /* ??òa±£?¤>64?′?é */
void GUI_X_InitOS(void)
// DispSem = OSSemCreate(1);
void GUI_X_ErrorOut(const char *s){}
void GUI_X_Warn(const char *s){}
* GUI_X_Init()
* Note:
* GUI_X_Init() is called from GUI_Init is a possibility to init
* some hardware which needs to be up and running before the GUI.
* If not required, leave this routine blank.
void GUI_X_Init(void) {
SetTsInterrupt(); //此处接入触摸屏的中断设置
GUI_TOUCH_SetDefaultCalibration();//关键函数
int GUI_TOUCH_X_MeasureX(void) {
return TX;
int GUI_TOUCH_X_MeasureY(void){
return TY;
void GUI_TOUCH_X_ActivateX(void) {}
void GUI_TOUCH_X_ActivateY(void) {}
void GUI_X_Log(const char *s) {}
10.为了响应触摸屏,做如下事:
1)在触摸屏中断中,获得触摸坐标后,应调用如下函数:
GUI_TOUCH_Exec();
2)如下修改函数 GUI_TOUCH_Exec():
void GUI_TOUCH_Exec(void) {
#ifndef WIN32
static U8 ReadState;
int x,y;
/* calculate Min / Max values */
if (xyMinMax[GUI_COORD_X].Min < xyMinMax[GUI_COORD_X].Max) {
xMin = xyMinMax[GUI_COORD_X].Min;
xMax = xyMinMax[GUI_COORD_X].Max;
} else {
xMax = xyMinMax[GUI_COORD_X].Min;
xMin = xyMinMax[GUI_COORD_X].Max;
if (xyMinMax[GUI_COORD_Y].Min < xyMinMax[GUI_COORD_Y].Max) {
yMin = xyMinMax[GUI_COORD_Y].Min;
yMax = xyMinMax[GUI_COORD_Y].Max;
} else {
yMax = xyMinMax[GUI_COORD_Y].Min;
yMin = xyMinMax[GUI_COORD_Y].Max;
/* Execute the state machine which reads the touch */
//switch (ReadState) {
//case 0:
yPhys = TOUCH_X_MeasureY();
// TOUCH_X_ActivateY(); /* Prepare X- measurement */
// ReadState++;
// break;
//default:
xPhys = TOUCH_X_MeasureX();
// TOUCH_X_ActivateX(); /* Prepare Y- measurement */
/* Convert values into logical values */
#if !GUI_TOUCH_SWAP_XY /* Is X/Y swapped ? */
x = xPhys;
y = yPhys;
#else
x = yPhys;
y = xPhys;
#endif
if ((x
GUI_TOUCH_StoreUnstable(-1,-1);
} else {
x = AD2X(x);
y = AD2Y(y);
GUI_TOUCH_StoreUnstable(x,y);
/* Reset state machine */
//ReadState=0;
// break;
#endif /* WIN32 */
注:若发现显示较慢,看看是否开启了Cache。也可适当修改DrawBitmap函数。
