在本文中,我们将了解如何直接从智能合约生成Java Wrapper类以与Java中的智能合约进行交互。
从智能合约生成Java Wrapper类有不同的方法:
1. Web3j命令行工具和solc
2. Web3j命令行工具和Truffle构建生成的工件
3. web3j-maven-plugin
4. web3j-gradle-plugin
为了演示如何使用上述方法,本教程使用以下智能合约将文档公证到以太坊区块链上的注册表中。
DocumentRegistry.sol
pragma solidity ^0.5.6;
* @dev Smart Contract responsible to notarize documents on the Ethereum Blockchain
contract DocumentRegistry {
struct Document {
address signer; // Notary
uint date; // Date of notarization
bytes32 hash; // Document Hash
* @dev Storage space used to record all documents notarized with metadata
mapping(bytes32 =》 Document) registry;
* @dev Notarize a document identified by its 32 bytes hash by recording the hash, the sender and date in the registry
* @dev Emit an event Notarized in case of success
* @param _documentHash Document hash
function notarizeDocument(bytes32 _documentHash) external returns (bool) {
registry[_documentHash].signer = msg.sender;
registry[_documentHash].date = now;
registry[_documentHash].hash = _documentHash;
emit Notarized(msg.sender, _documentHash);
return true;
* @dev Verify a document identified by its hash was noterized in the registry.
* @return bool if document was noterized previsouly in the registry
function isNotarized(bytes32 _documentHash) external view returns (bool) {
return registry[_documentHash].hash == _documentHash;
* @dev Definition of the event triggered when a document is successfully notarized in the registry
event Notarized(address indexed _signer, bytes32 _documentHash);
web3j命令行工具和solc
第一种方法使用solc生成Smart合约ABI和bytecode,并将这两个文件作为输入提供给web3j-cli以生成Wrapper。
1、安装solc并验证版本
安装solc并运行以下命令以确保solc版本大于或等于0.5.6(智能合约中指定的版本)。
$ solc --version
solc, the solidity compiler commandline interface
Version: 0.5.9+commit.c68bc34e.Linux.g++
2、安装Web3J CLI
要安装web3j cli,请从项目存储库的“发布”页面的“下载”部分下下载zipfile/tarball,或通过homebrew为MacOS用户或通过aur为Arch Linux用户下载zipfile/tarball。
brew tap web3j/web3j
brew install web3j
web3j
要通过zipfile运行,解压缩并运行二进制文件,您可能还需要将二进制文件添加到PATH中:
$ unzip web3j-4.3.0.zip
creating: web3j-4.3.0/lib/
inflating: web3j-4.3.0/lib/core-1.0.2-all.jar
creating: web3j-4.3.0/bin/
inflating: web3j-4.3.0/bin/web3j
inflating: web3j-4.3.0/bin/web3j.bat
$ 。/web3j-《version》/bin/web3j
_ _____ _ _
| | |____ (_) (_)
__ _____| |__ / /_ _ ___
\ \ /\ / / _ \ ‘_ \ \ \ | | | / _ \
\ V V / __/ |_) |.___/ / | _ | || (_) |
\_/\_/ \___|_.__/ \____/| |(_)|_| \___/
_/ |
|__/
Usage: web3j version|wallet|solidity 。..
3、使用solc编译智能合约
给定我们的Solidity文件DocumentRegistry.sol,solc 《sol》 --bin --abi --optimize -o 《output》命令编译智能合约并在同一目录中生成两个新文件:
$ solc DocumentRegistry.sol --bin --abi --optimize -o 。/
Compiler run successful. Artifact(s) can be found in directory 。/.
$ ls -l
total 12
-rw-rw-r-- 1 gjeanmart gjeanmart 565 Jun 24 13:42 DocumentRegistry.abi
-rw-rw-r-- 1 gjeanmart gjeanmart 676 Jun 24 13:42 DocumentRegistry.bin
-rw-rw-r-- 1 gjeanmart gjeanmart 1488 Jun 24 13:40 DocumentRegistry.sol
DocumentRegistry.bin:二进制文件,智能合约的字节码
DocumentRegistry.abi:智能合约的ABI(应用程序二进制接口),它以JSON格式定义接口。
4、使用web3j-cli生成包装器
使用ABI和bytecode(在步骤3中生成)和web3j-cli(在步骤2中安装),我们现在可以使用以下命令生成我们的智能合约的Java Wrapper:
web3j solidity generate -a=《abiFile》 -b=《binFile》 -o=《destinationFileDir》 -p=《packageName》
示例:
$ web3j solidity generate -a DocumentRegistry.abi
-b DocumentRegistry.bin -o 。
-p me.gjeanmart.tutorials.javaethereum.wrapper
_ _____ _ _
| | |____ (_) (_)
\ \ /\ / / _ \ ’_ \ \ \ | | | / _ \
_/ |
|__/
Generating me.gjeanmart.tutorials.javaethereum.wrapper.DocumentRegistry 。.. File written to 。
因此,您应该看到生成到文件夹/.java中的Java Wrapper文件,您可以将其复制到项目的src / main / java /文件夹中。
。/me/gjeanmart/tutorials/javaethereum/wrapper/DocumentRegistry.java
Web3j命令行工具和Truffle artefacts
Truffle是最著名的框架之一,可帮助您使用以太坊开发、测试和部署。 我们可以使用Truffle使用Web3j命令行工具生成的artefacts来创建wrapper类。
1、安装Truffle
Truffle可作为npm wrapper提供。
$ npm install truffle -g
- Fetching solc version list from solc-bin. Attempt #1
+ truffle@5.0.24
added 27 packages from 439 contributors in 11.636s
$ truffle version
Truffle v5.0.24 (core: 5.0.24)
Solidity v0.5.0 (solc-js)
Node v10.15.3
Web3.js v1.0.0-beta.37
2、初始化新的Truffle项目
要初始化Truffle项目,请在新文件夹中使用truffle init命令。该命令创建文件夹contract /,migration /和test /,以及文件truffle-config.js。
$ mkdir truffle
$ cd truffle
$ truffle init
? Preparing to download
? Downloading
? Cleaning up temporary files
? Setting up box
Unbox successful. Sweet!
Commands:
Compile: truffle compile
Migrate: truffle migrate
Test contracts: truffle test
$ ls -l
total 20
drwxrwxr-x 2 gjeanmart gjeanmart 4096 Jun 24 14:25 contracts
drwxrwxr-x 2 gjeanmart gjeanmart 4096 Jun 24 14:25 migrations
drwxrwxr-x 2 gjeanmart gjeanmart 4096 Jun 24 14:25 test
-rw-rw-r-- 1 gjeanmart gjeanmart 4233 Jun 24 14:25 truffle-config.js
3、将合同添加到文件夹合约中
将智能合约源documentregistry.sol复制到文件夹contracts中。
4、编译合约
使用命令truffle compile编译智能合约,此命令生成一个新的文件夹build/contracts/,其中包含每个编译的智能合约的truffle artefact。
$ truffle compile
Compiling your contracts.。.
》 Compiling 。/contracts/DocumentRegistry.sol
》 Compiling 。/contracts/Migrations.sol
》 Artifacts written to /home/gjeanmart/workspace/tutorials/java-ethereum-wrapper/truffle/build/contracts
》 Compiled successfully using:
- solc: 0.5.8+commit.23d335f2.Emscripten.clang
$ ls -l build/contracts/
total 136
-rw-rw-r-- 1 gjeanmart gjeanmart 79721 Jun 24 14:33 DocumentRegistry.json
-rw-rw-r-- 1 gjeanmart gjeanmart 54043 Jun 24 14:33 Migrations.json
5、从Truffle Artefact生成智能合约Java Wrapper
最后,web3j-cli提供了一种方法,可以使用以下命令直接从truffle编译的Truffle artefact结果生成Wrapper:
$ web3j truffle generate 。/build/contracts/DocumentRegistry.json -o 。 -p me.gjeanmart.tutorials.javaethereum.wrapper
_ _____ _ _
| | |____ (_) (_)
_/ |
|__/
因此,您应该看到生成到《packagefolders》 /。java_文件夹中的Java Wrapper文件,您可以将其复制到项目的src / main / java /文件夹中。
注意:使用Truffle,您可以做的比本文中显示的更多,例如部署脚本(迁移)、多网络配置、测试、调试。
web3j-maven-plugin
下一个解决方案比前两个解决方案更优雅,因为我们不必安装webj-cli并将文件复制到源文件夹。我们可以使用Maven和web3j-maven-plugin直接在Java项目中使用此方法。以下步骤假定您已创建Maven项目。
1、先决条件
$ solc --version
2、将智能合约复制到文件夹src / main / resources中
将Smart Contract源DocumentRegistry.sol复制到Maven项目的src / main / resources文件夹中。
3、配置Maven以在generate-sources阶段生成Wrapper
在此步骤中,我们配置两个Maven插件:
web3j - Maven的插件
第一个插件与前两个方法相同,但与Maven集成。首先,我们将插件配置为在进入项目的generate-sources阶段时自动执行。
其次我们配置插件参数:
· packageName:要应用于生成的Wrapper类的包名称
· sourceDestination:目标文件夹,用于移动生成的Wrapper类
· soliditySourceFiles:在何处查找Smart Contract源文件
建立辅助性Maven的插件
第二个插件将sourceDestination文件夹添加到类路径中,以便我们可以导入生成的Wrapper类
pom.xml
《build》
《plugins》
《plugin》
《groupId》org.web3j《/groupId》
《artifactId》web3j-maven-plugin《/artifactId》
《version》4.2.0《/version》
《executions》
《execution》
《id》generate-sources-web3j《/id》
《phase》generate-sources《/phase》
《goals》
《goal》generate-sources《/goal》
《/goals》
《configuration》
《packageName》me.gjeanmart.tutorials.javaethereum.contracts.generated《/packageName》
《sourceDestination》${basedir}/target/generated-sources/contracts《/sourceDestination》
《soliditySourceFiles》
《directory》${basedir}/src/main/resources《/directory》
《includes》
《include》**/*.sol《/include》
《/includes》
《/soliditySourceFiles》
《/configuration》
《/execution》
《/executions》
《/plugin》
《plugin》
《groupId》org.codehaus.mojo《/groupId》
《artifactId》build-helper-maven-plugin《/artifactId》
《executions》
《execution》
《id》add-source《/id》
《goals》
《goal》add-source《/goal》
《/goals》
《configuration》
《sources》
《source》${basedir}/target/generated-sources/contracts《/source》
《/sources》
《/configuration》
《/execution》
《/executions》
《/plugin》
《/plugins》
《/build》
4、运行Maven生成源
最后,使用mvn clean package(包括generate-sources阶段)构建Maven项目。因此,我们可以看到Java Wrapper已生成到/target/generated-sources/contracts/me/gjeanmart/tutorials/javaethereum/contracts/generated/DocumentRegistry.java并自动添加到类路径中。
Web3J Gradle插件
最后一个方法与之前使用Maven的方法类似,但使用的是Gradle。
1、先决条件
$ solc --version
2、将智能合约放入文件夹src / main / solidity
将Smart Contract源DocumentRegistry.sol复制到Gradle项目的src / main / solidity文件夹中。
3、配置Gradle以在构建期间生成Wrapper首先将web3j-gradle插件导入build.gradle文件。
plugins {
id ’org.web3j‘ version ’4.3.0‘
然后我们可以配置插件来为生成的wrapper类指定包名称和目标文件夹:
web3j {
generatedPackageName = ’me.gjeanmart.tutorials.javaethereum.contracts.generated‘
generatedFilesBaseDir = “$buildDir/contracts”
要使用系统安装的solc版本而不是与插件捆绑的版本,请将以下行添加到build.gradle:
solidity {
executable = “solc”
build.gradle
* This file was generated by the Gradle ’init‘ task.
* This generated file contains a sample Java Library project to get you started.
* For more details take a look at the Java Libraries chapter in the Gradle
* user guide available at https://docs.gradle.org/5.0/userguide/java_library_plugin.html
plugins {
// Apply the java-library plugin to add support for Java Library
id ’java-library‘
repositories {
// Use jcenter for resolving your dependencies.
// You can declare any Maven/Ivy/file repository here.
jcenter()
dependencies {
// This dependency is exported to consumers, that is to say found on their compile classpath.
api ’org.apache.commons:commons-math3:3.6.1‘
// This dependency is used internally, and not exposed to consumers on their own compile classpath.
implementation ’com.google.guava:guava:26.0-jre‘
implementation ’org.web3j:core:4.3.0‘
// Use JUnit test framework
testImplementation ’junit:junit:4.12‘
web3j {
solidity {
executable = “solc”
4、执行gradle构建
在最后一步中,我们使用。/gradlew tasks执行构建--all并验证我们生成的wrapper类是否已生成。
