摘要: /********************************************************************************************************** File : LCD12864.c* Hardware Environment: DVK501 F320 EX* Build Environment : Silicon LABs 3 ...
* File : LCD12864.c
* Hardware Environment: DVK501 && F320 EX
* Build Environment : Silicon LABs 3.42.00 / uVision3 V3.80 20100913
* Version :
* By : Su Wei Feng
*(c) Copyright 2005-2010, WaveShare
*/zixunimg/eeworldimg/www.waveshare.net
*All Rights Reserved
#define _DVK501_F320_EX_
#include
#include <..>
#include <..>
#include <..>
void main(void)
PCA0MD &= ~0x40; //Clear watchdog timer enable
XBR1 = 0x40;
clock_external();
delay_ms(100);
SPI_Init();
st7920LcdInit();
showLine(2,1,lcd_buffer,"深圳微雪电子");
showLine(2,2,lcd_buffer,"WaveShare.net");
refreshLCD(lcd_buffer);
while(1);
* File : ws_lcd_st7920_port.h
* Version :
* By : Su Wei Feng
* (c) Copyright 2005-2010, WaveShare
* /zixunimg/eeworldimg/www.waveshare.net
* All Rights Reserved
#ifndef _WS_LCD_ST7920_PORT_H
#define _WS_LCD_ST7920_PORT_H
void st7920LcdInit(void);
void spiSendChar(uchar send_char);
void sendCodeST7920(uchar Lcd_code);
void sendDataST7920(uchar Lcd_data);
void refreshLCD(const uchar *lcd_stack);
void decToAscii(uchar* str,uint dec,uchar width);
void hexToAscii(uchar* str,uint hex,uchar width);
void showLine(const uchar x,const uchar y,uchar* lcd_stack,char * str,...);
uchar idata lcd_buffer[64];
/*Hardware Environment:DVK501 && F320 EX*/
#if defined(_DVK501_F320_EX_)
sbit CS_LCD = P0^7;
void SPI_Init(void)
XBR0 |= 0x03;
P0SKIP |= 0x80;
P0MDOUT |= 0xC1;
SPI0CFG = 0x40;
SPI0CN = 0x01;
SPI0CKR = 0x05;
#else
#warning "No SPI!"
#endif
#include <..>
#endif /*_WS_LCD_ST7920_PORT_H*/
* File : ws_lcd_st7920.h
* Version :
* By : Su Wei Feng
#ifndef _WS_LCD_ST7920_H
#define _WS_LCD_ST7920_H
#include
#include
#define LCD_DELAY() delay_us(75)
sendCodeST7920(0x30);
sendCodeST7920(0x0C);
sendCodeST7920(0x01);
sendCodeST7920(0x02);
sendCodeST7920(0x80);
delay_ms(2);
memset(lcd_buffer,' ',sizeof(lcd_buffer));
SPIF = 0;
SPI0DAT = send_char;
while (!SPIF);
Software simulation SPI
/*void spiSendChar(uchar send_char)
uchar i;
for(i=8;i>0;i--)
if(send_char & (1 << (i-1)))
RW_SID = 1;
else
RW_SID = 0;
delay_us(10);
E_CLK = 1;
delay_us(10);
E_CLK = 0;
delay_us(10);
/*CS_LCD = 1;
delay_us(10);*/
spiSendChar(0xF8);
spiSendChar(Lcd_code & 0xF0);
spiSendChar((Lcd_code << 4));
LCD_DELAY();
/*delay_us(10);
CS_LCD = 0;*/
/*CS_LCD = 1;
delay_us(10);*/
spiSendChar(0xFA);
spiSendChar(Lcd_data & 0xF0);
spiSendChar((Lcd_data << 4));
LCD_DELAY();
/*delay_us(10);
CS_LCD = 0;*/
uchar addr;
for(addr=0;addr<16;addr++)
sendDataST7920(*(lcd_stack + addr));
for(addr=32;addr<48;addr++)
for(addr=16;addr<32;addr++)
for(addr=48;addr<64;addr++)
while(width)
switch(width)
case 5:
*str = (dec / 10000 + '0');
dec %= 10000;
break;
case 4:
*str = (dec / 1000 + '0');
dec %= 1000;
break;
case 3:
*str = (dec / 100 + '0');
dec %= 100;
break;
case 2:
*str = (dec / 10 + '0');
dec %= 10;
break;
case 1:
*str = (dec + '0');
break;
default: *str = '0';
width--;
str++;
uint tmp;
while(width)
switch(width)
case 4:
tmp = (hex >> 12);
if(tmp > 9) *str = tmp + ('A' - 10);
else *str = tmp + '0';
break;
case 3:
tmp = (hex >> 8) & 0x000F;
break;
case 2:
tmp = (hex >> 4) & 0x000F;
break;
case 1:
tmp = hex & 0x000F;
break;
width--;
str++;
void showLine(const uchar x,const uchar y,uchar *lcd_stack,char *str,...)
uchar coordinate = 16 * y + x;
va_list marker;
va_start(marker,str); // Initialize variable arguments.
while(*str != '
