main.c
#include
#include "intrins.h"
#include "Max7219.h"
uchar code laji[][8]={
{0x18,0x24,0x42,0x42,0x7E,0x42,0x42,0x42},//A
{0x7C,0x42,0x42,0x7C,0x42,0x42,0x42,0x7C},//B
{0x3C,0x42,0x40,0x40,0x40,0x40,0x42,0x7C},//C
{0x7C,0x42,0x42,0x42,0x42,0x42,0x42,0x7C},//D
/*n毫秒的延时程序*/
/*void Delay_xms(uint x)
uint i,j;
for(i=0;i for(j=0;j<112;j++); }*/ void main() { uchar i,j; //Delay_xms(50); MAX7219Init(); while(1) { for(j=0;j<8;j++) { for(i=0;i { Max7219WR(j+1,laji[i][j]); } CS=1; _nop_(); CS=0; //Delay_xms(100); } } } Max7219.h #ifndef _Max7219_H_ #define _Max7219_H_ #define uchar unsigned char #define uint unsigned int #define number 4 //点阵级联个数 #define lum 5 //亮度级别,0-F,共16级 //定义Max7219端口 sbit CLK = P2^2; //时钟 Max7219_pin sbit CS = P2^1; //锁存 sbit DIN = P2^0; //数据 //向MAX7219 写入地址和数据 void Max7219WR(uchar addr,uchar dat) { uchar n=8; CLK=0; CS=0; //CS=0有效,CS=1锁存 /*发送数据 高位先发*/ while(n--) { DIN = addr & 0x80; CLK=1; addr <<= 1; CLK=0; } n=8; /*发送数据 高位先发*/ while(n--) { DIN = dat & 0x80; CLK=1; dat <<= 1; CLK=0; } } void MAX7219Init() { uchar i,j; for(i=0;i<5;i++) // { for(j=number;j>0;j--) switch(i) { case 0:Max7219WR(0x09, 0x00); break; //译码方式:BCD码 不译码 case 1:Max7219WR(0x0A, lum); break; //亮度 0-15 共16级 case 2:Max7219WR(0x0B, 0x07); break; //扫描界限;8位显示 case 3:Max7219WR(0x0C, 0x01); break; //掉电模式:0,普通模式:1 case 4:Max7219WR(0x0F, 0x00); break; //显示测试:1;测试结束,正常显示:0 } CS=1; _nop_(); CS=0; //每写入四次给一个锁存脉冲 } } #endif
