单片机 > 单片机程序设计 > 详情
51单片机计算器源程序 可发送给上位机 可红外
发布时间:2023-03-23 发布时间:
单片机源程序如下:
#include"lcd12864.h"
#include"reg52.h"
#include"i2c.h"
#include"math.h"
sbit IRIN=P3^2;
int app=0;
unsigned char IrValue[6];
unsigned char Time;
unsigned char code smgduan[17]={
0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0X76};
void chuan()
TMOD=0X20;
TH1=0XFD;
TL1=0XFD;
TR1=1;
REN=1;
SM0=1;
SM1=1;
void delay(unsigned int i)
while(i--);
void IrInit()
IT0=1;//下降沿触发
EX0=1;//打开中断0允许
EA=1; //打开总中断
IRIN=1;//初始化端口
char hongwai()
if((smgduan[IrValue[2]/16]==0x06)&&(smgduan[IrValue[2]%16]==0x7d))
return '0';
if((smgduan[IrValue[2]/16]==0x3f)&&(smgduan[IrValue[2]%16]==0x39))
return '1';
if((smgduan[IrValue[2]/16]==0x06)&&(smgduan[IrValue[2]%16]==0x7f))
return '2';
if((smgduan[IrValue[2]/16]==0x6d)&&(smgduan[IrValue[2]%16]==0x79))
return '3';
if((smgduan[IrValue[2]/16]==0x3f)&&(smgduan[IrValue[2]%16]==0x7f))
return '4';
if((smgduan[IrValue[2]/16]==0x06)&&(smgduan[IrValue[2]%16]==0x39))
return '5';
if((smgduan[IrValue[2]/16]==0x6d)&&(smgduan[IrValue[2]%16]==0x77))
return '6';
if((smgduan[IrValue[2]/16]==0x66)&&(smgduan[IrValue[2]%16]==0x5b))
return '7';
if((smgduan[IrValue[2]/16]==0x6d)&&(smgduan[IrValue[2]%16]==0x5b))
return '8';
if((smgduan[IrValue[2]/16]==0x66)&&(smgduan[IrValue[2]%16]==0x77))
return '9';
if((smgduan[IrValue[2]/16]==0x3f)&&(smgduan[IrValue[2]%16]==0x6f))
return '+';
if((smgduan[IrValue[2]/16]==0x06)&&(smgduan[IrValue[2]%16]==0x6d))
return '-';
if((smgduan[IrValue[2]/16]==0x66)&&(smgduan[IrValue[2]%16]==0x4f))
return '/';
if((smgduan[IrValue[2]/16]==0x66)&&(smgduan[IrValue[2]%16]==0x3f))
return 'x';
if((smgduan[IrValue[2]/16]==0x3f)&&(smgduan[IrValue[2]%16]==0x07))
return '=';
if((smgduan[IrValue[2]/16]==0x66)&&(smgduan[IrValue[2]%16]==0x07))
return '.';
if((smgduan[IrValue[2]/16]==0x66)&&(smgduan[IrValue[2]%16]==0x7d))
return 'p';
if((smgduan[IrValue[2]/16]==0x66)&&(smgduan[IrValue[2]%16]==0x6d))
return '|';
else return 0xff;
main()
char i,sign,s,j,k,h=0;
unsigned char num;
char temp[16]; //最大输入16个
bit firstflag;
double a=0,b=0;
chuan();
IrInit();
LCD_Init();
// LCD_Write_com(0x01); //清屏
while(1)
{ if(app==1)
{num=hongwai();
app=0;
else
num = KeyPro();
if(num!=0xff)
if(j == 0)
j=1;
if(num=='|')
a=At24c02Read(1);
firstflag = 1;
if(('+' == num) || ('-' == num) || ('x' == num) || ('/' == num) || ('=' == num)|| ('p' == num))
if(num=='p')
LCD_Write_Char(i,0,num);
i++;
h=1;
else
{k=0;
if(firstflag==0) //flag=1为第一个数,0为第二个数
sscanf(temp,"%f " ,&a);
firstflag = 1;
if(h==1)
a=a*a;
else
{sscanf(temp," %f " ,&b);
if(h==1)
b=b*b;}
for(s = 0;s<16;s++)
temp[s] = 0;
i++ ;
if(num != '=')
sign = num;
else
{ j=0;
i=0;
firstflag = 0;
switch(sign)
case '+' :a = a+b;break;
case '-' :a = a-b;break;
case 'x' :a = a*b;break;
case '/' :a = a/b;break;
default:break;
//LCD_Write_Char(1,1,answer);
At24c02Write(1,a); //在地址1内写入数据num
sprintf(temp,"%.2f",a); //输出浮点型,无用的0不输出
Write_String(0,3,temp);//显示到液晶屏
for(s=0;temp[s]!='
stm32f4 - 时钟树分析配置
