#include
#defineuint8unsignedchar
#defineuint16unsignedint
#defineFOSC16000000
uint16BAUD=9600;
uint16TEMP_Alert=1000;
//字地址0-255(只取低8位)
//位地址0-255(只取低8位)
/*CRC高位字节值表*/
constuint8codeauchCRCHi[]={
0x00,0xC1,0x81,0x40,0x01,0xC0,0x80,0x41,0x01,0xC0/**/,
0x80,0x41,0x00,0xC1,0x81,0x40,0x01,0xC0,0x80,0x41,
0x00,0xC1,0x81,0x40,0x00,0xC1,0x81,0x40,0x01,0xC0,
0x80,0x41,0x01,0xC0,0x80,0x41,0x00,0xC1,0x81,0x40,
0x00,0xC1,0x81,0x40,0x01,0xC0,0x80,0x41,0x00,0xC1,
0x81,0x40,0x01,0xC0,0x80,0x41,0x01,0xC0,0x80,0x41,
0x81,0x40,0x00,0xC1,0x81,0x40,0x01,0xC0,0x80,0x41,
0x00,0xC1,0x81,0x40,0x01,0xC0,0x80,0x41,0x01,0xC0,
0x80,0x41,0x00,0xC1,0x81,0x40,0x00,0xC1,0x81,0x40,
0x01,0xC0,0x80,0x41,0x01,0xC0,0x80,0x41,0x00,0xC1,
0x81,0x40,0x01,0xC0,0x80,0x41,0x00,0xC1,0x81,0x40,
0x01,0xC0,0x80,0x41,0x00,0xC1,0x81,0x40,0x01,0xC0,
/*CRC低位字节值表*/
constuint8codeauchCRCLo[]={
0x00,0xC0,0xC1,0x01,0xC3,0x03,0x02,0xC2,0xC6,0x06/**/,
0x07,0xC7,0x05,0xC5,0xC4,0x04,0xCC,0x0C,0x0D,0xCD,
0x0F,0xCF,0xCE,0x0E,0x0A,0xCA,0xCB,0x0B,0xC9,0x09,
0x08,0xC8,0xD8,0x18,0x19,0xD9,0x1B,0xDB,0xDA,0x1A,
0x1E,0xDE,0xDF,0x1F,0xDD,0x1D,0x1C,0xDC,0x14,0xD4,
0xD5,0x15,0xD7,0x17,0x16,0xD6,0xD2,0x12,0x13,0xD3,
0x11,0xD1,0xD0,0x10,0xF0,0x30,0x31,0xF1,0x33,0xF3,
0xF2,0x32,0x36,0xF6,0xF7,0x37,0xF5,0x35,0x34,0xF4,
0x3C,0xFC,0xFD,0x3D,0xFF,0x3F,0x3E,0xFE,0xFA,0x3A,
0x3B,0xFB,0x39,0xF9,0xF8,0x38,0x28,0xE8,0xE9,0x29,
0xEB,0x2B,0x2A,0xEA,0xEE,0x2E,0x2F,0xEF,0x2D,0xED,
0xEC,0x2C,0xE4,0x24,0x25,0xE5,0x27,0xE7,0xE6,0x26,
0x22,0xE2,0xE3,0x23,0xE1,0x21,0x20,0xE0,0xA0,0x60,
0x61,0xA1,0x63,0xA3,0xA2,0x62,0x66,0xA6,0xA7,0x67,
0xA5,0x65,0x64,0xA4,0x6C,0xAC,0xAD,0x6D,0xAF,0x6F,
0x6E,0xAE,0xAA,0x6A,0x6B,0xAB,0x69,0xA9,0xA8,0x68,
0x78,0xB8,0xB9,0x79,0xBB,0x7B,0x7A,0xBA,0xBE,0x7E,
0x7F,0xBF,0x7D,0xBD,0xBC,0x7C,0xB4,0x74,0x75,0xB5,
0x77,0xB7,0xB6,0x76,0x72,0xB2,0xB3,0x73,0xB1,0x71,
0x70,0xB0,0x50,0x90,0x91,0x51,0x93,0x53,0x52,0x92,
0x96,0x56,0x57,0x97,0x55,0x95,0x94,0x54,0x9C,0x5C,
0x5D,0x9D,0x5F,0x9F,0x9E,0x5E,0x5A,0x9A,0x9B,0x5B,
0x99,0x59,0x58,0x98,0x88,0x48,0x49,0x89,0x4B,0x8B,
0x8A,0x4A,0x4E,0x8E,0x8F,0x4F,0x8D,0x4D,0x4C,0x8C,
0x44,0x84,0x85,0x45,0x87,0x47,0x46,0x86,0x82,0x42,
0x43,0x83,0x41,0x81,0x80,0x40
uint16TempRegister;//用于测试字址址16
uint8localAddr=0x01;//单片机控制板的地址
uint8sendCount;//发送字节个数
uint8receCount;//接收到的字节个数
//uint8sendPosi;//发送位置
uint8xdatareceBuf[1];
uint8xdatasendBuf[1];
voidcheckComm0Modbus(void);
uint16getRegisterVal(uint16addr,uint16*tempData);
uint16setRegisterVal(uint16addr,uint16tempData);
voidswitch_BAUD(uint16value);
/*****************************波特率调整函数********************************/
////函数功能:调整串口通信波特率
////串口工作在工作方式1,即8位波特率可变模式
switch(value)
case0x0001:{BAUD=9600;break;}
case0x0002:{BAUD=14400;break;}
case0x0003:{BAUD=19200;break;}
TR1=0;//停止定时器1
ES=0;//关闭串口中断
TH1=TL1=-(FOSC/12/32/BAUD);//设置波特率
TR1=1;//开启定时器1
ES=1;//使能串口中断
/*************************************end************************************/
/***************************CRC校验码生成函数********************************/
////函数功能:生成CRC校验码
////本代码中使用查表法,以提高运算速度
uint16crc16(uint8*puchMsg,uint16usDataLen)
uint8uchCRCHi=0xFF;/*高CRC字节初始化*/
uint8uchCRCLo=0xFF;/*低CRC字节初始化*/
uint16uIndex;/*CRC循环中的索引*/
while(usDataLen--)/*传输消息缓冲区*/
uIndex=uchCRCHi^*puchMsg++;/*计算CRC*/
uchCRCHi=uchCRCLo^auchCRCHi[uIndex];
uchCRCLo=auchCRCLo[uIndex];
return(uchCRCLo《《8|uchCRCHi);
}//uint16crc16(uint8*puchMsg,uint16usDataLen)
/*******************************串口发送函数********************************/
////函数功能:将数据包通过串口发送至主机
////有待修改。..。..
//开始发送
voidBegin_send(void)
uint16i=0;
while(sendCount--)
SBUF=sendBuf[i++];
while(!TI);
/********从机响应主机问询函数,functioncode:03,读取多个寄存器值********/
////函数功能:丛机根据串口接收到的数据包receBuf[]里面的内容,根据被读取寄存器
////的起始地址和读取的寄存器个数,去读相应的寄存器的值,并将读取的数据以MODBUS
////响应数据的标准格式打包,经过串口发送到主机。数据包格式同上。
//////////////询问数据包格式:
/////////////////////////receBuf[0]receBuf[1]receBuf[2]receBuf[3]receBuf[4]receBuf[5]receBuf[6]receBuf[7]
//询问数据格式:receBuf[]={从站地址,功能码,起始地址高位,起始地址低位,寄存器数高位,寄存器数低位,校验码低位,校验码高位}
//////////////响应数据包格式:
/////////////////////////sendBuf[0]sendBuf[1]sendBuf[[2]sendBuf[3]sendBuf[4]sendBuf[5]。..receBuf[6]receBuf[7]
//响应数据格式:receBuf[]={从站地址,功能码,字节计数,数据1,数据2,数据3,。..校验码低位,校验码高位}
voidreadRegisters(void)
uint8addr;
uint8tempAddr;
uint16crcData;
uint8readCount;
uint8byteCount;
uint16i;
uint16tempData=0;
//addr=(receBuf[2]《《8)+receBuf[3];
//tempAddr=addr&0xfff;
addr=receBuf[3];
tempAddr=addr;
//readCount=(receBuf[4]《《8)+receBuf[5];//要读的个数
readCount=receBuf[5];
byteCount=readCount*2;//每个寄存器内容占高,低两个字节
for(i=0;i{
getRegisterVal(tempAddr,&tempData);
sendBuf[i+3]=tempData》》8;
sendBuf[i+4]=tempData&0xff;
sendBuf[0]=localAddr;
sendBuf[1]=3;//functioncode:03
sendBuf[2]=byteCount;
byteCount+=3;//加上前面的地址,功能码,地址共3+byteCount个字节
crcData=crc16(sendBuf,byteCount);
sendBuf[byteCount]=crcData&0xff;//CRC代码低位在前
byteCount++;
sendBuf[byteCount]=crcData》》8;//高位在后
sendCount=byteCount+1;//例如byteCount=49,则sendBuf[]中实际上有49+1个元素待发
Begin_send();
}//voidreadRegisters(void)
/********从机响应主机问询函数,functioncode:16,设置多个寄存器值*********/
////函数功能:丛机根据串口接收到的数据包receBuf[]里面的内容,根据被强制寄存器
////的起始地址,去设置相应寄存器的值,响应数据包同询问数据包
////的内容相同,经过串口发送到主机。
/////////////////////////receBuf[0]receBuf[1]receBuf[2]receBuf[3]receBuf[4]receBuf[5]receBuf[6]receBuf[7]receBuf[8]。..receBuf[9]receBuf[10]
//询问数据格式:receBuf[]={从站地址,功能码,起始地址高位,起始地址低位,寄存器数高位,寄存器数低位,字节计数,数据高位,数据低位,。..校验码低位,校验码高位}
//响应数据包内容为除去询问数据包中的字节计数和数据高低位的其他内容
voidpresetMultipleRegisters(void)
uint8addr;
uint8tempAddr;
uint8byteCount;
uint8setCount;
uint16crcData;
uint16tempData;
uint8i;
addr=receBuf[3];
tempAddr=addr&0xff;
//setCount=(receBuf[4]《《8)+receBuf[5];
setCount=receBuf[5];
byteCount=receBuf[6];
for(i=0;i{
tempData=(receBuf[i*2+7]《《8)+receBuf[i*2+8];//待设置寄存器值
setRegisterVal(tempAddr,tempData);
sendBuf[1]=16;//functioncode:16
sendBuf[2]=addr》》8;//寄存器地址高位
sendBuf[3]=addr&0xff;//寄存器地址低位
sendBuf[4]=setCount》》8;//待设置寄存器数量高位
sendBuf[5]=setCount&0xff;//待设置寄存器数量低位
crcData=crc16(sendBuf,6);//生成CRC校验码
sendBuf[6]=crcData&0xff;//CRC代码低位在前
sendBuf[7]=crcData》》8;//高位在后
sendCount=8;
Begin_send();
}//voidpresetMultipleRegisters(void)
/*************************查询uart接收的数据包内容函数**************************/
////函数功能:丛机根据串口接收到的数据包receBuf[1]里面的内容,即functioncode执行
////相应的命令
uint16crcData;
uint16tempData;
if(receCount》4)
switch(receBuf[1])
case3://读取保持寄存器(一个或多个)
if(receCount》=8)//从询问数据包格式可知,receCount应该等于8
{//接收完成一组数据
//应该关闭接收中断
if(receBuf[0]==localAddr)//核对地址
crcData=crc16(receBuf,6);//核对校验码
if(crcData==receBuf[7]+(receBuf[6]《《8))
if(receBuf[1]==3)
{//读取保持寄存器(一个或多个)
readRegisters();
receCount=0;
break;
case16://设置多个寄存器
tempData=(receBuf[4]《《8)+receBuf[5];
tempData=tempData*2;//数据个数
tempData+=9;//从询问数据包格式可知,receCount应该等于9+byteCount
if(receCount》=tempData)
crcData=crc16(receBuf,tempData-2);
if(crcData==(receBuf[tempData-2]《《8)+receBuf[tempData-1])
presetMultipleRegisters();
receCount=0;
break;
default:break;
}//voidcheckComm0(void)
/*******************************读取寄存器内容函数**************************/
////函数功能:根据寄存器地址读取相应寄存器内容
//取寄存器值返回0表示成功
uint16result=0;
uint16tempAddr;
switch(tempAddr&0xff)
case0x00:{*tempData=TempRegister;break;}//读取01开关A温度
case0x01:{*tempData=TempRegister;break;}//读取01开关A温度
case0x02:{*tempData=TempRegister;break;}//读取01开关A温度
case0x03:{*tempData=TempRegister;break;}//读取01开关周边温度
case0x04:{*tempData=TempRegister;break;}//读取02开关A温度
case0x05:{*tempData=TempRegister;break;}//读取02开关A温度
case0x06:{*tempData=TempRegister;break;}//读取02开关A温度
case0x07:{*tempData=TempRegister;break;}//读取02开关周边温度
case0x08:{*tempData=TempRegister;break;}//读取03开关A温度
case0x09:{*tempData=TempRegister;break;}//读取03开关A温度
case0x0a:{*tempData=TempRegister;break;}//读取03开关A温度
case0x0b:{*tempData=TempRegister;break;}//读取03开关周边温度
case0x0c:{*tempData=TempRegister;break;}//读取04开关A温度
case0x0d:{*tempData=TempRegister;break;}//读取04开关A温度
case0x0e:{*tempData=TempRegister;break;}//读取04开关A温度
case0x0f:{*tempData=TempRegister;break;}//读取04开关周边温度
case0x10:{*tempData=TempRegister;break;}//读取05开关A温度
case0x11:{*tempData=TempRegister;break;}//读取05开关A温度
case0x12:{*tempData=TempRegister;break;}//读取05开关A温度
case0x13:{*tempData=TempRegister;break;}//读取05开关周边温度
case0x14:{*tempData=TempRegister;break;}//读取06开关A温度
case0x15:{*tempData=TempRegister;break;}//读取06开关A温度
case0x16:{*tempData=TempRegister;break;}//读取06开关A温度
case0x17:{*tempData=TempRegister;break;}//读取06开关周边温度
case0x18:{*tempData=TempRegister;break;}//读取07开关A温度
case0x19:{*tempData=TempRegister;break;}//读取07开关A温度
case0x1a:{*tempData=TempRegister;break;}//读取07开关A温度
case0x1b:{*tempData=TempRegister;break;}//读取07开关周边温度
case0x1c:{*tempData=TempRegister;break;}//读取08开关A温度
case0x1d:{*tempData=TempRegister;break;}//读取08开关A温度
case0x1e:{*tempData=TempRegister;break;}//读取08开关A温度
case0x1f:{*tempData=TempRegister;break;}//读取08开关周边温度
case0x20:{*tempData=TempRegister;break;}//读取09开关A温度
case0x21:{*tempData=TempRegister;break;}//读取09开关A温度
case0x22:{*tempData=TempRegister;break;}//读取09开关A温度
case0x23:{*tempData=TempRegister;break;}//读取09开关周边温度
case0x24:{*tempData=TempRegister;break;}//读取10开关A温度
case0x25:{*tempData=TempRegister;break;}//读取10开关A温度
case0x26:{*tempData=TempRegister;break;}//读取10开关A温度
case0x27:{*tempData=TempRegister;break;}//读取10开关周边温度
case0x28:{*tempData=TempRegister;break;}//读取11开关A温度
case0x29:{*tempData=TempRegister;break;}//读取11开关A温度
case0x2a:{*tempData=TempRegister;break;}//读取11开关A温度
case0x2b:{*tempData=TempRegister;break;}//读取11开关周边温度
case0x2c:{*tempData=TempRegister;break;}//读取12开关A温度
case0x2d:{*tempData=TempRegister;break;}//读取12开关A温度
case0x2e:{*tempData=TempRegister;break;}//读取12开关A温度
case0x2f:{*tempData=TempRegister;break;}//读取12开关周边温度
case0x30:{*tempData=TempRegister;break;}//读取13开关A温度
case0x31:{*tempData=TempRegister;break;}//读取13开关A温度
case0x32:{*tempData=TempRegister;break;}//读取13开关A温度
case0x33:{*tempData=TempRegister;break;}//读取13开关周边温度
case0x34:{*tempData=TempRegister;break;}//读取14开关A温度
case0x35:{*tempData=TempRegister;break;}//读取14开关A温度
case0x36:{*tempData=TempRegister;break;}//读取14开关A温度
case0x37:{*tempData=TempRegister;break;}//读取14开关周边温度
case0x38:{*tempData=TempRegister;break;}//读取15开关A温度
case0x39:{*tempData=TempRegister;break;}//读取15开关A温度
case0x3a:{*tempData=TempRegister;break;}//读取15开关A温度
case0x3b:{*tempData=TempRegister;break;}//读取15开关周边温度
case0x3c:{*tempData=TempRegister;break;}//读取16开关A温度
case0x3d:{*tempData=TempRegister;break;}//读取16开关A温度
case0x3e:{*tempData=TempRegister;break;}//读取16开关A温度
case0x3f:{*tempData=TempRegister;break;}//读取16开关周边温度
case0x40:{*tempData=TempRegister;break;}//读取17开关A温度
case0x41:{*tempData=TempRegister;break;}//读取17开关A温度
case0x42:{*tempData=TempRegister;break;}//读取17开关A温度
case0x43:{*tempData=TempRegister;break;}//读取17开关周边温度
case0x44:{*tempData=TempRegister;break;}//读取18开关A温度
case0x45:{*tempData=TempRegister;break;}//读取18开关A温度
case0x46:{*tempData=TempRegister;break;}//读取18开关A温度
case0x47:{*tempData=TempRegister;break;}//读取18开关周边温度
case0x48:{*tempData=TempRegister;break;}//读取19开关A温度
case0x49:{*tempData=TempRegister;break;}//读取19开关A温度
case0x4a:{*tempData=TempRegister;break;}//读取19开关A温度
case0x4b:{*tempData=TempRegister;break;}//读取19开关周边温度
case0x4c:{*tempData=TempRegister;break;}//读取20开关A温度
case0x4d:{*tempData=TempRegister;break;}//读取20开关A温度
case0x4e:{*tempData=TempRegister;break;}//读取20开关A温度
case0x4f:{*tempData=TempRegister;break;}//读取20开关周边温度
case0x50:{*tempData=TempRegister;break;}//读取21开关A温度
case0x51:{*tempData=TempRegister;break;}//读取21开关A温度
case0x52:{*tempData=TempRegister;break;}//读取21开关A温度
case0x53:{*tempData=TempRegister;break;}//读取21开关周边温度
case0x54:{*tempData=TempRegister;break;}//读取22开关A温度
case0x55:{*tempData=TempRegister;break;}//读取22开关A温度
case0x56:{*tempData=TempRegister;break;}//读取22开关A温度
case0x57:{*tempData=TempRegister;break;}//读取22开关周边温度
case0x58:{*tempData=TempRegister;break;}//读取23开关A温度
case0x59:{*tempData=TempRegister;break;}//读取23开关A温度
case0x5a:{*tempData=TempRegister;break;}//读取23开关A温度
case0x5b:{*tempData=TempRegister;break;}//读取23开关周边温度
case0x5c:{*tempData=TempRegister;break;}//读取24开关A温度
case0x5d:{*tempData=TempRegister;break;}//读取24开关A温度
case0x5e:{*tempData=TempRegister;break;}//读取24开关A温度
case0x5f:{*tempData=TempRegister;break;}//读取24开关周边温度
case0x60:{*tempData=TempRegister;break;}//读取25开关A温度
case0x61:{*tempData=TempRegister;break;}//读取25开关A温度
case0x62:{*tempData=TempRegister;break;}//读取25开关A温度
case0x63:{*tempData=TempRegister;break;}//读取25开关周边温度
case0x64:{*tempData=TempRegister;break;}//读取26开关A温度
case0x65:{*tempData=TempRegister;break;}//读取26开关A温度
case0x66:{*tempData=TempRegister;break;}//读取26开关A温度
case0x67:{*tempData=TempRegister;break;}//读取26开关周边温度
case0x68:{*tempData=TempRegister;break;}//读取27开关A温度
case0x69:{*tempData=TempRegister;break;}//读取27开关A温度
case0x6a:{*tempData=TempRegister;break;}//读取27开关A温度
case0x6b:{*tempData=TempRegister;break;}//读取27开关周边温度
case0x6c:{*tempData=TempRegister;break;}//读取28开关A温度
case0x6d:{*tempData=TempRegister;break;}//读取28开关A温度
case0x6e:{*tempData=TempRegister;break;}//读取28开关A温度
case0x6f:{*tempData=TempRegister;break;}//读取28开关周边温度
case0x70:{*tempData=TempRegister;break;}//读取29开关A温度
case0x71:{*tempData=TempRegister;break;}//读取29开关A温度
case0x72:{*tempData=TempRegister;break;}//读取29开关A温度
case0x73:{*tempData=TempRegister;break;}//读取29开关周边温度
case0x74:{*tempData=TempRegister;break;}//读取30开关A温度
case0x75:{*tempData=TempRegister;break;}//读取30开关A温度
case0x76:{*tempData=TempRegister;break;}//读取30开关A温度
case0x77:{*tempData=TempRegister;break;}//读取30开关周边温度
case0x78:{*tempData=localAddr;break;}//读取设备地址
case0x79:{*tempData=BAUD;break;}//读取串口通信波特率
case0x7a:{*tempData=TEMP_Alert;break;}//读取报警温度上限
case0x7b:{*tempData=TempRegister;break;}//读取年寄存器
case0x7c:{*tempData=TempRegister;break;}//读取月寄存器
case0x7d:{*tempData=TempRegister;break;}//读取日寄存器
case0x7e:{*tempData=TempRegister;break;}//读取时寄存器
case0x7f:{*tempData=TempRegister;break;}//读取分寄存器
case0x80:{*tempData=TempRegister;break;}//读取秒寄存器
default:break;
returnresult;
}//uint16getRegisterVal(uint16addr,uint16&data)
/*******************************设置寄存器内容函数**************************/
////函数功能:根据寄存器地址设置相应寄存器内容
//设置寄存器值返回0表示成功
uint16result=0;
uint16tempAddr;
case0x78:{localAddr=tempData;break;}//设置设备地址,设备地址初始值为0x01
case0x79:{
BAUD=tempData;
switch_BAUD(BAUD);
break;
}//设置串口通信波特率,串口通信波特率寄存器值为1:9600,2:14400,3:19200,初始值为1
//设置报警温度上限,报警温度值存储方式:精确到0.1°C,以扩大10倍的数值放在寄存器里面,例如温度值为100.1,则读写值为1001
case0x7a:{TEMP_Alert=tempData;break;}
case0x7b:{TempRegister=tempData;break;}//设置年寄存器
case0x7c:{TempRegister=tempData;break;}//设置月寄存器
case0x7d:{TempRegister=tempData;break;}//设置日寄存器
case0x7e:{TempRegister=tempData;break;}//设置时寄存器
case0x7f:{TempRegister=tempData;break;}//设置分寄存器
case0x80:{TempRegister=tempData;break;}//设置秒寄存器
default:break;
returnresult;
end
