用单片机产生方波、锯齿波、三角波、梯形波,频率可调
#include
#defineucharunsignedchar
#defineuintunsignedint
unsignedcharx=0,m=0,y=128;
sbitWR_DA=P2^1;
sbitCS_DA=P2^0;//DA与 单片机 的接口
sbitS0=P3^0;//波形选择,每次按下将产生不同的波形
sbitS1=P3^1;//频率减
sbitS2=P3^2;//频率加
sbitS3=P3^3;//调节方波的占空比
ucharcodeSinTab[256]={0x80,0x83,0x86,0x89,0x8d,0x90,0x93,0x96,0x99,0x9c,0x9f,0xa2,0xa5,0xa8,0xab,0xae,0xb1,0xb4,0xb7,0xba,0xbc,0xbf,0xc2,0xc5
,0xc7,0xca,0xCC,0xcf,0xd1,0xd4,0xd6,0xd8,0xda,0xdd,0xdf,0xe1,0xe3,0xe5,0xe7,0xe9,0xea,0xec,0xee,0xef,0xf1,0xf2,0xf4,0xf5
,0xf6,0xf7,0xf8,0xf9,0xfa,0xfb,0xfc,0xfd,0xfd,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xfd
,0xfd,0xfc,0xfb,0xfa,0xf9,0xf8,0xf7,0xf6,0xf5,0xf4,0xf2,0xf1,0xef,0xee,0xec,0xea,0xe9,0xe7,0xe5,0xe3,0xe1,0xde,0xdd,0xda
,0xd8,0xd6,0xd4,0xd1,0xcf,0xcc,0xca,0xc7,0xc5,0xc2,0xbf,0xbc,0xba,0xb7,0xb4,0xb1,0xae,0xab,0xa8,0xa5,0xa2,0x9f,0x9c,0x99
,0x96,0x93,0x90,0x8d,0x89,0x86,0x83,0x80,0x80,0x7c,0x79,0x76,0x72,0x6f,0x6c,0x69,0x66,0x63,0x60,0x5d,0x5a,0x57,0x55,0x51
,0x4e,0x4c,0x48,0x45,0x43,0x40,0x3d,0x3a,0x38,0x35,0x33,0x30,0x2e,0x2b,0x29,0x27,0x25,0x22,0x20,0x1e,0x1c,0x1a,0x18,0x16
,0x15,0x13,0x11,0x10,0x0e,0x0d,0x0b,0x0a,0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x02,0x01,0x00,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x02,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x0a,0x0b,0x0d,0x0e,0x10,0x11,0x13,0x15
,0x16,0x18,0x1a,0x1c,0x1e,0x20,0x22,0x25,0x27,0x29,0x2b,0x2e,0x30,0x33,0x35,0x38,0x3a,0x3d,0x40,0x43,0x45,0x48,0x4c,0x4e
,0x51,0x55,0x57,0x5a,0x5d,0x60,0x63,0x66,0x69,0x6c,0x6f,0x72,0x76,0x79,0x7c,0x80};
voiddelayms(uintt)
uinti;
while(t--)
for(i=0;i《125;i++);//对于11.0592M时钟,约延时1ms
voiddelay(uintt)
uinti;
for(i=t;i》0;i--);
voidtime0_init()
TMOD|=0x01;//定时器设置16位
TH0=-50000/256;
TL0=-50000%256;//初始化值
ET0=1;
TR0=1;
EA=1;
voidtime0_int(void)interrupt1
TR0=0;//关闭定时器
TH0=-50000/256;
TL0=-50000%256;//重装初值
if(S0==0)
delayms(10);//按键消抖
if(S0==0)m++;
while(!S0);//松手检测
if(S1==0)
delayms(10);
if(S1==0)x=x+1;
while(!S1);//松手检测
if(S2==0)
delayms(10);
if(S2==0)x=x-1;
while(!S2);//松手检测
if(S3==0)
delayms(10);
if(S3==0)y=y+5;
while(!S3);//松手检测
if(y》254)y=0;
if(m》5)m=0;
if(x》50)x=0;
TR0=1;//启动定时器
voidfangbo()//方波
uchari,j;
j=255-y;
CS_DA=0;
WR_DA=0;
for(i=y;i》0;i--)
P0=0;
delay(x);
while(j--)
P0=255;
delay(x);
voidjuchi()//锯齿波
uchari;
CS_DA=0;
WR_DA=0;
for(i=255;i》0;i--)
P0=i;
delay(x);
voidsanjiao()//三角波
uchari;
CS_DA=0;
WR_DA=0;
for(i=0;i《255;i++)
P0=i;
delay(x);
while(i--)
P0=i;
delay(x);
voidtixing()//梯形波
uchari=255,j,k;
CS_DA=0;
WR_DA=0;
while(i--)
P0=i;
delay(x);
for(j=0;j《100;j++)
P0=0;
delay(x);
for(k=0;k《255;k++)
P0=k;
delay(x);
voidsin()//正弦波
uchara;
CS_DA=0;
WR_DA=0;
for(a=0;a《255;a++)
P0=SinTab[a];
delay(x);
main()
time0_init();
while(1)
switch(m)
case0:
fangbo();//方波
break;
case1:
juchi();//锯齿波
break;
case2:
sanjiao();//三角波
break;
case3:
sin();//正弦波
break;
case4:
tixing();//梯形波
break;
default:fangbo();
