第一、波特率要设置相同。
第二、要在PC机上的设备管理器里把USB转232串口设置为COM2,并且波特率要设置的和软件里写的一样。
如下是写的测试程序,精简了通信部分。
51单片机上的通信程序
#include
#define uchar unsigned char
#define uint unsigned int
uchar code cgf1[10] = {"CHINA"};
uchar code cgf2[10] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
main()
uchar i,j;
TMOD = 0x20;
TH1 = 0x0e6;TL1 = 0x0e6;
TR1 = 1;
SCON = 0x50;
P1 = 0x3f;
lcd_reset();
while(1)
RI = 0;
while(!RI);
i = SBUF;
i = i&0x0f;
lcd_display(0,0,15,13);
delay(3000);
//P1 = cgf2[i];
RI = 0;
for(j = 0;j<200;j++);
TI = 0;
SBUF =cgf1[i];
while(!TI);
TI = 0;
PC机上通信程序(用Turboc2.0编译就行)
#include
#include
#include
#include
#include
void port(void)
outportb(0x2fb,0x80);
outportb(0x2f8,0x60);
outportb(0x2f9,0);
outportb(0x2fb,0x03);
void send(unsigned char s)
unsigned char x;
outportb(0x2f8,s);
begin:
x = inportb(0x2fd);
x = x&0x20;
if(x == 0)goto begin;
unsigned char data()
unsigned char a;
bgin:
a = inportb(0x2fd);
a = a&0x01;
if(a != 1)goto bgin;
else
a = inportb(0x2f8);
return(a);
void main(void)
int i;
unsigned char c,b;
b = ';
system("cls");
port();
puts("PC USE COM1 1200b/s,press A to exit");
puts("89c51 fosc = 12MHz");
puts("input(0-9)");
while(1)
c = getchar();
if(c == 97)
exit(0);
else
{if(c >= 0x30 && c <= 0x39)
send(c);
b = data();
puts("STC89c51 send
printf(" %c
",b);
for(i = 0;i<2000;i++);
补充:如果用vc些outportb、inputb可以用_inp、_outp。可以阅览msdn
