#include
#define Stop 0 //宏定义,停止
#define Left 1 //宏定义,左转
#define Right 2 //宏定义,右转
sbit ControlPort = P1^0; //舵机信号端口
sbit KeyLeft = P1^1; //左转按键端口
sbit KeyRight = P1^2; //右转按键端口
sbit KeyStop = P1^3; //归位按键端口
unsigned char TimeOutCounter = 0,LeftOrRight = 0; //TimeOutCounter:定时器溢出计数 LeftOrRight:舵机左右旋转标志
void InitialTimer ( void )
TMOD=0x10; //定时/计数器1工作于方式1
TH1 = ( 65535 - 500 ) / 256; //0.25ms
TL1 = ( 65535 - 500 ) % 256;
EA=1; //开总中断
ET1=1; //允许定时/计数器1 中断
TR1=1; //启动定时/计数器1 中断
void ControlLeftOrRight ( void ) //控制舵机函数
if( KeyStop == 0 )
while ( !KeyStop ); //使标志等于Stop(0),在中断函数中将用到
LeftOrRight = Stop;
if( KeyLeft == 0 )
while ( !KeyLeft ); //使标志等于Left(1),在中断函数中将用到
LeftOrRight = Left;
if( KeyRight == 0 )
while ( !KeyRight ); //使标志等于Right(2),在中断函数中将用到
LeftOrRight = Right;
void main ( void ) //主函数
InitialTimer();
for(;;)
ControlLeftOrRight();
void Timer1 ( void ) interrupt 3 //定时器中断函数
TimeOutCounter ++;
switch ( LeftOrRight )
case 0 : //为0时,舵机归位,脉宽1.5ms
if( TimeOutCounter <= 6 )
ControlPort = 1;
else
ControlPort = 0;
break;
case 1 : //为1时,舵机左转,脉宽1ms(理论值),实际可以调试得出
if( TimeOutCounter <= 2 )
ControlPort = 1;
else
ControlPort = 0;
break;
case 2 : //为2时,舵机右转,脉宽2ms(理论值),实际可以调试得出
if( TimeOutCounter <= 10 )
ControlPort = 1;
else
ControlPort = 0;
break;
default : break;
if( TimeOutCounter == 80 ) //周期20ms(理论值),比较可靠,最好不要修改
TimeOutCounter = 0;
