单片机 > 单片机程序设计 > 详情
51单片机模拟I2C总线程序
发布时间:2025-02-12 发布时间:
#include
#include
sbit  led=P1^0;
sbit  led2=P1^1;
sbit scl=P3^5;  //24c02 SCL
sbit sda=P3^4;  //24c02 SDA
sbit DOG=P1^7;  //狗
uchar x24c02_read(uchar address);
 //从24c02的地址address中读取一个字节数据
void x24c02_write(uchar address,uchar info);
  //向24c02的address地址中写入一字节数据info
void x24c02_init();   //24c02初始化子程序
void delay1(uchar x);
void flash();
void x24c01_init();
void start();
void stop();
void writex(uchar j);
uchar readx();
void clock();
   uint i;
   for(i=0;i   DOG=~DOG;
void flash()
   uchar u;
   DOG=~DOG;
void x24c02_init()
   scl=1; flash(); sda=1; flash();
void start()
   sda=1; flash(); scl=1; flash(); sda=0; flash(); scl=0; flash();
void stop()
   sda=0; flash(); scl=1; flash(); sda=1; flash();
   uchar i,temp;
   temp=j;
   for (i=0;i<8;i++){
      temp=temp<<1; scl=0; flash(); sda=CY; flash(); scl=1; flash();
   scl=0; flash(); sda=1; flash();
uchar readx()
   uchar i,j,k=0;
   for (i=0;i<8;i++){
      if (sda==1) j=1;
      else j=0;
      k=(k<<1)|j; scl=0;
   flash(); return(k);
void clock()
   uchar i=0;
   scl=1; flash();
   while ((sda==1)&&(i<255))i++;
   scl=0; flash();
   uchar i;
   start(); writex(0xa0);
   clock(); writex(address);
   clock(); start();
   writex(0xa1); clock();
   i=readx(); stop();
   delay1(10);
   return(i);
   EA=0;
   clock(); writex(info);
   clock(); stop();
   EA=1;
   delay1(50);
                            main  (){
                          uchar data a=2,b=10,c=0;
                             x24c02_init();
                             x24c02_write(a,b);
                             delay1(200);
                             c=x24c02_read(a);
                             if(c==b)led=0;
                             led2=0;
