单片机 > 单片机程序设计 > 详情
c51按位运算符
发布时间:2025-12-24 发布时间:
#include
#include
unsigned moveright(unsigned value, int n);
unsigned moveleft(unsigned value, int n);
main()
 unsigned a;
 int n;
 SCON = 0x50;
TMOD |= 0x20;
TH1 = 0xf3;
TR1 = 1;
TI = 1;
 printf("请数入一个8进制数:");
 scanf("%o", &a);
 printf("请输入要位移的位数:");
 scanf("%d", &n);
 if(n>0)
 printf("循环右移的结果为:%o\n", moveright(a,n));
 else
  n=-n;
  printf("循环左移的结果为:%o\n", moveleft(a,n));
unsigned moveright(unsigned value, int n)        //循环右移
 unsigned z;
 z=(value>>n)|(value< return z;
unsigned moveleft(unsigned value, int n)         //循环左移
 unsigned z;
 z=(value<>(16-n));
 return z;
STDIO.H
Prototypes for standard I/O functions.
Copyright (c) 1988-2002 Keil Elektronik GmbH and Keil Software, Inc.
All rights reserved.
#ifndef __STDIO_H__
#define __STDIO_H__
#ifndef EOF
 #define EOF -1
#endif
#ifndef NULL
 #define NULL ((void *) 0)
#endif
#ifndef _SIZE_T
 #define _SIZE_T
 typedef unsigned int size_t;
#endif
#pragma SAVE
#pragma REGPARMS
extern char _getkey (void);
extern char getchar (void);
extern char ungetchar (char);
extern char putchar (char);
extern int printf   (const char *, ...);
extern int sprintf  (char *, const char *, ...);
extern int vprintf  (const char *, char *);
extern int vsprintf (char *, const char *, char *);
extern char *gets (char *, int n);
extern int scanf (const char *, ...);
extern int sscanf (char *, const char *, ...);
extern int puts (const char *);
#pragma RESTORE
#endif
REG51.H
Header file for generic 80C51 and 80C31 microcontroller.
#ifndef __REG51_H__
#define __REG51_H__
/*  BYTE Register  */
sfr P0   = 0x80;
sfr P1   = 0x90;
sfr P2   = 0xA0;
sfr P3   = 0xB0;
sfr PSW  = 0xD0;
sfr ACC  = 0xE0;
sfr B    = 0xF0;
sfr SP   = 0x81;
sfr DPL  = 0x82;
sfr DPH  = 0x83;
sfr PCON = 0x87;
sfr TCON = 0x88;
sfr TMOD = 0x89;
sfr TL0  = 0x8A;
sfr TL1  = 0x8B;
sfr TH0  = 0x8C;
sfr TH1  = 0x8D;
sfr IE   = 0xA8;
sfr IP   = 0xB8;
sfr SCON = 0x98;
sfr SBUF = 0x99;
/*  BIT Register  */
/*  PSW   */
sbit CY   = 0xD7;
sbit AC   = 0xD6;
sbit F0   = 0xD5;
sbit RS1  = 0xD4;
sbit RS0  = 0xD3;
sbit OV   = 0xD2;
sbit P    = 0xD0;
/*  TCON  */
sbit TF1  = 0x8F;
sbit TR1  = 0x8E;
sbit TF0  = 0x8D;
sbit TR0  = 0x8C;
sbit IE1  = 0x8B;
sbit IT1  = 0x8A;
sbit IE0  = 0x89;
sbit IT0  = 0x88;
/*  IE   */
sbit EA   = 0xAF;
sbit ES   = 0xAC;
sbit ET1  = 0xAB;
sbit EX1  = 0xAA;
sbit ET0  = 0xA9;
sbit EX0  = 0xA8;
/*  IP   */
sbit PS   = 0xBC;
sbit PT1  = 0xBB;
sbit PX1  = 0xBA;
sbit PT0  = 0xB9;
sbit PX0  = 0xB8;
/*  P3  */
sbit RD   = 0xB7;
sbit WR   = 0xB6;
sbit T1   = 0xB5;
sbit T0   = 0xB4;
sbit INT1 = 0xB3;
sbit INT0 = 0xB2;
sbit TXD  = 0xB1;
sbit RXD  = 0xB0;
/*  SCON  */
sbit SM0  = 0x9F;
sbit SM1  = 0x9E;
sbit SM2  = 0x9D;
sbit REN  = 0x9C;
sbit TB8  = 0x9B;
sbit RB8  = 0x9A;
sbit TI   = 0x99;
sbit RI   = 0x98;
#endif
$NOMOD51
;  This file is part of the C51 Compiler package
;  Copyright (c) 1988-2002 Keil Elektronik GmbH and Keil Software, Inc.
;  STARTUP.A51:  This code is executed after processor reset.
;  To translate this file use A51 with the following invocation:
;     A51 STARTUP.A51
;  To link the modified STARTUP.OBJ file to your application use the following
;  BL51 invocation:
;     BL51 , STARTUP.OBJ
;  User-defined Power-On Initialization of Memory
;  With the following EQU statements the initialization of memory
;  at processor reset can be defined:
;               ; the absolute start-address of IDATA memory is always 0
IDATALEN        EQU     80H     ; the length of IDATA memory in bytes.
XDATASTART      EQU     0H      ; the absolute start-address of XDATA memory
XDATALEN        EQU     0H      ; the length of XDATA memory in bytes.
PDATASTART      EQU     0H      ; the absolute start-address of PDATA memory
PDATALEN        EQU     0H      ; the length of PDATA memory in bytes.
;  Notes:  The IDATA space overlaps physically the DATA and BIT areas of the
;          8051 CPU. At minimum the memory space occupied from the C51
;          run-time routines must be set to zero.
;  Reentrant Stack Initilization
;  The following EQU statements define the stack pointer for reentrant
;  functions and initialized it:
;  Stack Space for reentrant functions in the SMALL model.
IBPSTACK        EQU     0       ; set to 1 if small reentrant is used.
IBPSTACKTOP     EQU     0FFH+1  ; set top of stack to highest location+1.
;  Stack Space for reentrant functions in the LARGE model.
XBPSTACK        EQU     0       ; set to 1 if large reentrant is used.
XBPSTACKTOP     EQU     0FFFFH+1; set top of stack to highest location+1.
;  Stack Space for reentrant functions in the COMPACT model.
PBPSTACK        EQU     0       ; set to 1 if compact reentrant is used.
PBPSTACKTOP     EQU     0FFFFH+1; set top of stack to highest location+1.
;  Page Definition for Using the Compact Model with 64 KByte xdata RAM
;  The following EQU statements define the xdata page used for pdata
;  variables. The EQU PPAGE must conform with the PPAGE control used
;  in the linker invocation.
PPAGEENABLE     EQU     0       ; set to 1 if pdata object are used.
PPAGE           EQU     0       ; define PPAGE number.
PPAGE_SFR       DATA    0A0H    ; SFR that supplies uppermost address byte
;               (most 8051 variants use P2 as uppermost address byte)
; Standard SFR Symbols
ACC     DATA    0E0H
B       DATA    0F0H
SP      DATA    81H
DPL     DATA    82H
DPH     DATA    83H
                NAME    ?C_STARTUP
?C_C51STARTUP   SEGMENT   CODE
?STACK          SEGMENT   IDATA
                RSEG    ?STACK
                DS      1
                EXTRN CODE (?C_START)
                PUBLIC  ?C_STARTUP
                CSEG    AT      0
?C_STARTUP:     LJMP    STARTUP1
                RSEG    ?C_C51STARTUP
STARTUP1:
IF IDATALEN <> 0
                MOV     R0,#IDATALEN - 1
                CLR     A
IDATALOOP:      MOV     @R0,A
                DJNZ    R0,IDATALOOP
ENDIF
IF XDATALEN <> 0
                MOV     DPTR,#XDATASTART
                MOV     R7,#LOW (XDATALEN)
  IF (LOW (XDATALEN)) <> 0
                MOV     R6,#(HIGH (XDATALEN)) +1
  ELSE
                MOV     R6,#HIGH (XDATALEN)
  ENDIF
                CLR     A
XDATALOOP:      MOVX    @DPTR,A
                INC     DPTR
                DJNZ    R7,XDATALOOP
                DJNZ    R6,XDATALOOP
ENDIF
IF PPAGEENABLE <> 0
                MOV     PPAGE_SFR,#PPAGE
ENDIF
IF PDATALEN <> 0
                MOV     R0,#LOW (PDATASTART)
                MOV     R7,#LOW (PDATALEN)
                CLR     A
PDATALOOP:      MOVX    @R0,A
                INC     R0
                DJNZ    R7,PDATALOOP
ENDIF
IF IBPSTACK <> 0
EXTRN DATA (?C_IBP)
                MOV     ?C_IBP,#LOW IBPSTACKTOP
ENDIF
IF XBPSTACK <> 0
EXTRN DATA (?C_XBP)
                MOV     ?C_XBP,#HIGH XBPSTACKTOP
                MOV     ?C_XBP+1,#LOW XBPSTACKTOP
ENDIF
IF PBPSTACK <> 0
EXTRN DATA (?C_PBP)
                MOV     ?C_PBP,#LOW PBPSTACKTOP
ENDIF
                MOV     SP,#?STACK-1
; This code is required if you use L51_BANK.A51 with Banking Mode 4
; EXTRN CODE (?B_SWITCH0)
;               CALL    ?B_SWITCH0      ; init bank mechanism to code bank 0
                LJMP    ?C_START
                END
