unsigned char RunMode;
void Delay1ms(unsigned int count)
unsigned int i,j;
for(i=0;i
for(j=0;j<120;j++);
unsigned char code LEDDisplayCode[] = { 0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8, //0~7
0x80,0x90,0x88,0x83,0xC6,0xA1,0x86,0x8E,0xFF};
void Display(unsigned char Value)
P3 = LEDDisplayCode[Value];
void LEDFlash(unsigned char Count)
unsigned char i;
bit Flag;
for(i = 0; i
Flag = !Flag;
if(Flag)
Display(RunMode);
else
Display(0x10);
Delay1ms(100);
Display(RunMode);
unsigned char GetKey(void)
unsigned char KeyTemp,CheckValue,Key = 0x00;
CheckValue = P2&0x32;
if(CheckValue==0x32)
return 0x00;
Delay1ms(10);
KeyTemp = P2&0x32;
if(KeyTemp==CheckValue)
return 0x00;
if(!(CheckValue&0x02))
Key|=0x01;
if(!(CheckValue&0x10))
Key|=0x02;
if(!(CheckValue&0x20))
Key|=0x04;
return Key;
unsigned int TimerCount,SystemSpeed,SystemSpeedIndex;
void InitialTimer2(void)
T2CON = 0x00; //16 Bit Auto-Reload Mode
TH2 = RCAP2H = 0xFC; //重装值,初始值 TL2 = RCAP2L = 0x18;
ET2=1; //定时器 2 中断允许
TR2 = 1; //定时器 2 启动
EA=1;
unsigned int code SpeedCode[]={ 1, 2, 3, 5, 8, 10, 14, 17, 20, 30,
40, 50, 60, 70, 80, 90, 100, 120, 140, 160,
180, 200, 300, 400, 500, 600, 700, 800, 900,1000};//30
void SetSpeed(unsigned char Speed)
SystemSpeed =SpeedCode[Speed];
void LEDShow(unsigned int LEDStatus)
P1 = ~(LEDStatus&0x00FF);
P0 = ~((LEDStatus>>8)&0x00FF);
void InitialCPU(void)
RunMode = 0x00;
TimerCount = 0;
SystemSpeedIndex = 10;
P1 = 0x00;
P0 = 0x00;
P2 = 0xFF;
P3 = 0x00;
Delay1ms(500);
P1 = 0xFF;
P0 = 0xFF;
P2 = 0xFF;
P3 = 0xFF;
SetSpeed(SystemSpeedIndex);
Display(RunMode);
//Mode 0
unsigned int LEDIndex = 0;
bit LEDDirection = 1,LEDFlag = 1;
void Mode_0(void)
LEDShow(0x0001<
LEDIndex = (LEDIndex+1);
//Mode 1
void Mode_1(void)
LEDShow(0x8000>>LEDIndex);
//Mode 2
void Mode_2(void)
if(LEDDirection)
LEDShow(0x0001<
else
if(LEDIndex==15)
LEDDirection = !LEDDirection;
//Mode 3
void Mode_3(void)
if(LEDDirection)
LEDShow(~(0x0001<
else
LEDShow(~(0x8000>>LEDIndex));
if(LEDIndex==15)
//Mode 4
void Mode_4(void)
if(LEDDirection)
if(LEDFlag)
LEDShow(0xFFFE<
else
LEDShow(~(0x7FFF>>LEDIndex));
else
if(LEDFlag)
LEDShow(0x7FFF>>LEDIndex);
else
LEDShow(~(0xFFFE<
if(LEDIndex==15)
if(LEDDirection) LEDFlag = !LEDFlag;
//Mode 5
void Mode_5(void)
if(LEDDirection)
LEDShow(0x000F<
else
LEDShow(0xF000>>LEDIndex);
if(LEDIndex==15)
//Mode 6
void Mode_6(void)
if(LEDDirection)
LEDShow(~(0x000F<
else
LEDShow(~(0xF000>>LEDIndex));
if(LEDIndex==15)
//Mode 7
void Mode_7(void)
if(LEDDirection)
LEDShow(0x003F<
else
LEDShow(0xFC00>>LEDIndex);
if(LEDIndex==9)
//Mode 8
void Mode_8(void)
LEDShow(++LEDIndex);
void TimerEventRun(void)
if(RunMode==0x00)
Mode_0();
else if(RunMode ==0x01)
Mode_1();
else if(RunMode ==0x02)
Mode_2();
else if(RunMode ==0x03)
Mode_3();
else if(RunMode ==0x04)
Mode_4();
else if(RunMode ==0x05)
Mode_5();
else if(RunMode ==0x06)
Mode_6();
else if(RunMode ==0x07)
Mode_7();
else if(RunMode ==0x08)
Mode_8();
void Timer2(void) interrupt 5 using 3
TF2 = 0; //中断标志清除( Timer2 必须软件清标志!)
if(++TimerCount>=SystemSpeed)
TimerCount = 0;
TimerEventRun();
unsigned char MusicIndex = 0;
void KeyDispose(unsigned char Key)
if(Key&0x01)
LEDDirection = 1;
LEDIndex = 0;
LEDFlag = 1;
RunMode = (RunMode+1)%9;
Display(RunMode);
if(Key&0x02)
if(SystemSpeedIndex>0)
--SystemSpeedIndex;
else
LEDFlash(6);
if(Key&0x04)
if(SystemSpeedIndex<28)
++SystemSpeedIndex;
else
LEDFlash(6);
main()
unsigned char Key;
InitialCPU();
InitialTimer2();
while(1)
Key = GetKey();
if(Key!=0x00)
KeyDispose(Key);
