Linux的应用程序要想访问内核必须使用系统调用从而实现从usr模式转到svc模式。在arm中,这个过程是通过swi(或者和它等价的指令)来实现模式转换的。
相关文件:
bionic/libc/unistd/open.c
bionic/libc/arch-arm/syscalls/__open.S
linux/arch/arm/kernel/entry-common.S
linux/arch/arm/kernel/entry-armv.S
linux/arch/arm/kernel/entry-header.S
相关调用过程:
int open(const char *pathname, int flags, ...); bionic/libc/unistd/open.c
__open bionic/libc/arch-arm/syscalls/__open.S
__open:
.save {r4, r7}
stmfd sp!, {r4, r7}
ldr r7, =__NR_open
swi #0
ldmfd sp!, {r4, r7}
movs r0, r0
bxpl lr
b __set_syscall_errno
vector_swi linux/arch/arm/kernel/entry-common.S
adr tbl, sys_call_table @ load syscall table pointer
cmp scno, #NR_syscalls @ check upper syscall limit
adr lr, BSYM(ret_fast_syscall) @ return address
ldrcc pc, [tbl, scno, lsl #2] @ call sys_* routine
sys_call_table 系统调用跳转表,里面保存了各个系统调用实现的地址。
.type sys_call_table, #object
ENTRY(sys_call_table)
#include "calls.S"
