#include
#include
#include"NRF24L01.h"
//#define Open_TX
#define Open_RX
typedef unsigned char uint8; /* defined for unsigned 8-bits integer variable 无符号8位整型变量 */
typedef signed char int8; /* defined for signed 8-bits integer variable 有符号8位整型变量 */
typedef unsigned short uint16; /* defined for unsigned 16-bits integer variable 无符号16位整型变量 */
typedef signed short int16; /* defined for signed 16-bits integer variable 有符号16位整型变量 */
typedef unsigned int uint32; /* defined for unsigned 32-bits integer variable 无符号32位整型变量 */
typedef signed int int32; /* defined for signed 32-bits integer variable 有符号32位整型变量 */
typedef float fp32; /* single precision floating point variable (32bits) 单精度浮点数(32位长度) */
typedef double fp64; /* double precision floating point variable (64bits) 双精度浮点数(64位长度) */
extern uint8_t RX_BUF[];
extern uint8_t TX_BUF[];
void motorrun();
uint8 HandleKey();
uint8 KEY_Release;
uint32 i,MS1;
#define KEY1_Press ((keys & 0x03) == 3)
#define KEY1_Pressed ((keys & 0x03) == 2)
#define KEY1_Release ((keys & 0x03) == 1)
#define KEY1_Released ((keys & 0x03) == 0)
int main(void)
//nRF24L01_Config();
//usartInit();
uint8 keys = 0;
nRF24L01_Initial();
while(1)
#ifdef Open_TX
keys=HandleKey();
if(KEY1_Release)
TX_BUF[0]=0x55;
NRF24L01_Send();
if(TX_BUF[0]==0x55)
for(i=1;i<100;i++)
PORTB &=~ (1<
PORTB |= (1<
//printf("rnSend data:0x%xrn",TX_BUF[0]);
_delay_ms(5000);
#else
PORTD &=~(1<
_delay_ms(2000);
if(RX_BUF[0]==0X55)
motorrun();
while(1);
#endif
uint8 HandleKey(void)
static uint8 key1laststa = 1,pressure = 0;
uint8 ret = 0;
DDRB &= ~(1 << PB1);
if(PINB & (1 << PB1)) //KEY1
ret = (ret & ~(0x03 << 0)) | (0x00 << 0);
if(key1laststa == 0) //release
ret = (ret & ~(0x03 << 0)) | (0x01 << 0);
key1laststa = 1;
else
ret = (ret & ~(0x03 << 0)) | (0x02 << 0);
if(key1laststa == 1) //press
ret = (ret & ~(0x03 << 0)) | (0x03 << 0);
key1laststa = 0;
return ret;
void motorrun()
PORTD |=(1<
PORTC |= (1 << PC0);
_delay_ms(20);
PORTC &=~ (1 << PC0);
_delay_ms(20);
