#include
#define uchar unsigned char
#define uint unsigned int
uint sec=0; //秒变量
uint cnt=0; //计数变量
uint on=0; //启停状态变量
uchar str1[16]="The time: sec"; //这里所有字符串长度一定 ,以便消除不确定显示码指针跑偏导致显示异常
uchar start[16]=" start ";
uchar stop[16]=" stop ";
#include "1602.h"
void port_init()
PORTA=0xff;
DDRA=0xff;
PORTB=0xff;
DDRB=0xff;
PORTD=0xff;
DDRD=0xff;
void init()
MCUCR=0x0a;
GICR=0xc0;
SREG=0x80;
void time0_init()
TCCR0=0x03;
TIMSK=0x01;
TCNT0=0x83;
void showtime(uint time)
displayonechar(10,0,(time/10)+48);
displayonechar(11,0,(time%10)+48);
void main()
port_init();
//1602设备初始化
delay(15);
writecmd(0x38);
delay(5);
writecmd(0x38);
delay(5);
writecmd(0x38);
writecmd(0x80);
writecmd(0x01);
writecmd(0x06);
writecmd(0x0c);
delay(500);
//初始化结束
init();
time0_init();
while(1)
displaychar(0,0,str1);
showtime(sec); //显示时间值(秒) 重复覆盖这2位 达到显示效果
delay(20);
#pragma vector = 0x24 //定时器0 溢出 (定时秒)
__interrupt void time0()
TCNT0=0x83;
if(on==1) //启动标志
cnt++;
if(cnt==1000)
sec++;cnt=0;
if(sec>100)sec=0;
#pragma vector = 0x04 //INT0中断服务程序
__interrupt void int0()
on=1;
writecmd(0x01); // 清屏
displaychar(0,1,start); //显示启动字符
displaychar(0,0,str1); //显示原来字符
showtime(sec);
#pragma vector = 0x08 //INT1中断服务程序
__interrupt void int1()
on=0;
writecmd(0x01); //清屏
displaychar(0,1,stop); //显示停止字符
showtime(sec);
